Old 09-04-2013, 06:20 AM   #376
BOXER957
BOXER957's Avatar
Re: Project truck dream 65"
Originally Posted by lenguini View Post
Ill mention the offer to my bodyman...you never know !
Yes,raising the seat height 2 inches with the Silverado seats made all the difference for room.I still have a couple inches of head room and am able to stretch my legs out to the firewall.You may want to consider mounting after market pedals as I did.
The original plan was to re-engineer the firewall and move it out into the engine bay 3 inches which would have been a real p.i.t.a.,so I opted for this.
Cheers,
Ed.
I was considering the same thing (extending the firewall) Glad to know raising the seat worked, that is a little...easier. What did you use for pedals? I saw where you said you had relocated them but you didn't give a lot of detail or pics. Thanks BTW how do I link my build thread to my messages? Any clue?
Nice EASY project, no problem....until I get home why is that? My build: http://67-72chevytrucks.com/vboard/s...d.php?t=595078
BOXER957 is offline   Reply With Quote
Old 09-08-2013, 12:34 PM   #377
lenguini
lenguini's Avatar
The pedals were Big Al's,.I mounted the Gas pedal in the v of the steering column hole you will have to build a block to space it out enough so it wont interfere with the bulge in the steel around the column.I also bent the brake arm to the right for a more comfortable location.
I'm not to sure on how to do the link to messages,you can contact the forum and they can help you with this.
Cheers,
Ed.
Always a place in my heart for old Chevy trucks:
My build thread-project truck dream 65"
http://67-72chevytrucks.com/vboard/s...d.php?t=510863
lenguini is offline   Reply With Quote
Old 09-09-2013, 12:46 AM   #378
lenguini
lenguini's Avatar
I ordered my serpentine system Friday morn from Nick at Prolific Designs.Nick worked with me on my one off design for the main engine plate along with my many other concerns and questions I had.
A special thanks Nick !
I looked at many systems and really wanted one that had a belt tensioner incorporated in with it,that was it's a simple belt change with no guess work adjusting it up.I chose this system as it mounts off the water pump so it's nice and simple.
I cant wait to get it !
Yesterday and today being Sunday and I routed my hood release cable through holes I drilled up and under the upper rad support flange. This was a real trial getting the holes made,but well worth it in the end.
So I temporarily hooked up the cable after making a post and slightly modifying the release,that will be welded tomorrow.
I tested it and it worked great.Now the idea of the post is to bring the cable up high enough into the rad support body so that its completely hidden.
After the rad support is painted,I will put rubber grommets in the holes as some electrical will be routed through here as well which will explain the oversize holes.
I just noticed in the top pic what appeared to be the coating on the cable shaved off(I just ran out to the shop to check )....,was only excess primer I spotted over the new holes.Thank God ! That would have peed me off !!
Old 09-11-2013, 12:55 AM   #379
lenguini
lenguini's Avatar
I ordered my valve covers/breathers and wire looms earlier today. Aluminum Polished 4 1/4 tall finned,matching looms for that old school look. I'm finally getting some closure on engine parts I have been trying to decide on for a year now...,its amazing how many hours I have spent.(wasted)on this stuff
I'm currently trying to decide on a brand of an H.E.I. distributor with an integral coil.I was going to go with the Mini style but that means an external coil...,no thanks.It has been proven that an external does not perform as well and will hang off the firewall or cover up the new endurashine intake,so I guess that's a no brainer !
Mid day,I ordered my transmission crossmember.I found the one that will work best for my Truck on Alan's build.
Thanks Alan,I always appreciate your help !
Spent some time in the shop tonight bolting the hood mech back into place.I had the post welded yesterday morn and a hook tab welded today(this morning on the way to work)that I made last night for a return spring for the cable pull.I think that made sense ?
Old 09-17-2013, 12:05 AM   #380
lenguini
lenguini's Avatar
Valve covers,wire looms and their vortec mounts showed up today ! I'm really happy with the product,there are a few on the market so you never know for sure until you receive them.
I'm thinking about powdercoating in between the fins on both covers and looms in a semi-gloss black.
Should have the hood finished by the weekend,so once more bolt it in place and fab up a safety latch in case the claw ever fails.
Ill post some pic's of it soon.
Old 09-17-2013, 09:01 AM   #381
BOXER957
BOXER957's Avatar
Always liked the old time finned valve covers. Looks nice, will look even better on the motor!
Old 09-18-2013, 12:05 AM   #382
lenguini
lenguini's Avatar
I looked at many and these seemed to catch my eye.I was thinking of matching endurashine covers to my intake,but they were shorter at 3 1/2 and a concern with roller rocker clearance.
Guess its time to look at an air cleaner...,round or oval with a tall filter.
Old 09-18-2013, 07:03 AM   #383
BOXER957
BOXER957's Avatar
I'm thinking of changing mine out, I found tall finned covers and a caddy style cleaner that's finned down the center......just gotta remember where I saw them....The set together looked sweet.
Old 09-29-2013, 12:17 AM   #384
lenguini
lenguini's Avatar
The hood is now complete.The center of the hood has been reworked and smoothed.I'm trying to retain some of the original look and just clean it up now that the original hood release is no longer present.
Old 09-29-2013, 12:36 AM   #385
lenguini
lenguini's Avatar
All of the factory holes in the front and rear brace have been welded and smoothed.This is going to make a big difference when its sprayed ! Looks a'lot cleaner,well worth the time and effort.
The new hood release pin mount has been boxed and smoothed.There was the option of cutting out the entire area and reforming it,but once again to keep the brace semi original is a much cooler look in my opinion.
Old 09-29-2013, 04:07 AM   #386
BOXER957
BOXER957's Avatar
Very nice
Old 09-29-2013, 08:50 PM   #387
lenguini
lenguini's Avatar
Very nice
Thanks,I appreciate it.Tonight I'm working out a design for a secondary safety latch system in the event the new latch should ever fail.Its never any fun when the hood springs open doing 80mph !
There should be enough room at the front or side of the latch pin box to mount it.
Old 09-29-2013, 10:38 PM   #388
lenguini
lenguini's Avatar
Here's some pics of the rad support covers mounted back in place.The passenger side originally had a small cutaway for the rad overflow hose.
Because I wanted the covers to match both sides,the passenger side was reworked with a piece welded in along with the factory bead straitened.
The rad overflow now runs to the overflow tank.
Old 09-30-2013, 07:04 AM   #389
BOXER957
BOXER957's Avatar
Truck is looking sweet, why didn't you keep the original latch as the safety?
Old 09-30-2013, 11:21 PM   #390
lenguini
lenguini's Avatar
Making one out of aluminum and milling out the center.A much better look,fit and function.
Old 10-03-2013, 01:17 AM   #391
lenguini
lenguini's Avatar
I got the door panels back from Elgin today....,wrapped in the same color and grain as the seats.I was thinking earlier of painting them,glad I went this route.
I'm really happy that all the contours in the panels show up so well under the wrap,thats what I was hoping for
Old 10-03-2013, 03:03 AM   #392
McMurphy
McMurphy's Avatar
Oh hell yeah..... this is coming along REAL nice!
I am totally on board with the clean look you have going on here; nicely done
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 10-03-2013, 10:26 PM   #393
lenguini
lenguini's Avatar
Thanks my friend,Its nice to finally have things rolling along at a fast pace now !
Old 10-04-2013, 06:09 AM   #394
BOXER957
BOXER957's Avatar
Love the wrap, was going to do the same on mine but couldn't find leather seats. I'm down with the stainless buttonheads too, I get them by the box from a wholesaler right up the street. Looking great!
Old 10-07-2013, 01:17 AM   #395
lenguini
lenguini's Avatar
Thanks for the good words. The fastners are actually the factory phillips head repainted.
Old 10-07-2013, 01:30 AM   #396
lenguini
lenguini's Avatar
I spent a couple hours in the shop today and I think I have the template for the rad cover roughed out to where I'm happy with it.
Going to make it out of stainless rather than aluminum as it will take a little more abuse.
Old 10-20-2013, 01:53 PM   #397
lenguini
lenguini's Avatar
Here my heads are getting prepped for screw in studs.With more lift this is an absolute necessity ,not to keen on the idea of pinning.
The trans crossmember arrived today.I have reason to believe a trip to the machine shop may be in order as these are close but may require a 1" to 2" block to make all level.Ill know for sure once I move my motor mounts ahead to allow for the tall valve covers and HEI distributor with integral coil.
I have done my research and to date have decided with the Petronix flame thrower distrib.Performance wise,it looks to be the best choice and still made in the USA unlike most others.
Old 10-20-2013, 04:21 PM   #398
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Truck is looking awesome! Love it! Can't wait to see the 283 finished! I'm watching this one!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-20-2013, 10:31 PM   #399
lenguini
lenguini's Avatar
Thanks,I appreciate it.The engine however is a 383 stroker,I tossed the idea of the 283 a year or so ago as it just wouldn't produce the torque and horsepower I wanted.
Should end up with just over 400hp and 420 to 430 torque.It will be complete and on the dyno at the end of this month.....,and yes there will be pics of that for certain !
Old 10-20-2013, 10:46 PM   #400
Jeff La
Good clean build, waiting for it to all come together, it'll be awesome.
Jeff La is offline   Reply With Quote
