12-22-2013, 01:58 PM | #1 |
67-72 parts collector,…
Re: Porterbuilt Dropmember
One more,...
12-22-2013, 03:26 PM | #2 | |
12-22-2013, 02:00 PM | #3 |
My favorite,...
12-22-2013, 03:08 PM | #4 |
A well designed suspension will keep the camber straight up and down for a larger range of the suspension travel. Lowering the vehicle is using some of that travel. Look at lowered imports and you will almost always see the tires at an angle. They don't have much suspension to start with.
A truck has more travel and the Porterbuilt design keeps the wheel vertical through most if not all the wheel travel including laying it out if it has big enough tires and rims. If it had old school 15" rims and smaller tires you would probably see the wheels angle in. There is a sweet spot where the truck will handle better with the suspension lowered. When I was ordering for my '57 I was told 6" or so. Some people run it lower and don't seem to have issues. |
12-22-2013, 04:48 PM | #5 |
Thanks loife99 I understand now lol
12-22-2013, 04:52 PM | #6 |
thotfulspot, so if I run 20x8.5 in the front with 235/35/20 tires I shouldn't see a lot of wheel lean? Will I have problems in my turns with tire rub or can that be solved by adjusting ride height?
12-22-2013, 05:07 PM | #7 | |
This is all in the suspension design. Stock crossmember with bags, or a Dropmember will yield different results completely. Wheel width and baskspcing will also have to be adjusted depending on what suspension you have up front.
12-22-2013, 05:16 PM | #8 |
I'm going to run with Porterbuilt Extreme dropmember in front and back. What kind of backspacing should i run? 5 inch is what I was thinking.
12-22-2013, 05:22 PM | #9 | |
8.5" wide wheel up front,... needs a 5.25"-5.75" bs with stock length a-arms.
12-22-2013, 05:28 PM | #10 |
Thanks for the info man!
12-22-2013, 05:35 PM | #11 |
I have so many questions with this build and will start a thread when I get further in on the build, but right now I am trying to start at the frame. Suspension work is always a pain in my butt ( considering I'm a mechanic on heavy haul trucks ) so when I think of suspension work I instantly curse and get out the torch and hammer lol! I have never built a restored a vehicle so it has all been a learning experience for me.
I have a guy at my work that used to build show cars, trucks, and bikes that were award winning when he lived in Vegas, so he gets most of my questions. Trying to get him to help me with my build or even pointers on painting my truck is like pulling teeth! |
12-23-2013, 09:14 AM | #12 |
Love those Delmo video's!!!
12-23-2013, 11:18 AM | #13 |
Square
is the shock running through the control arms? if so, cool.
Squarebody Syndicate |
12-23-2013, 11:21 AM | #14 |
This one received the coil-over kit. Del is building another Unibody with the airbag set-up.
On the airbag set-up the front clip is similar to the 55-59 Chevy kit. The shock runs outboard behind the upper control arm.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
12-23-2013, 12:23 PM | #15 |
Badass!!!
12-23-2013, 10:30 PM | #16 |
I love the PB logo on the 4 link brackets!
-Rus |
12-23-2013, 10:37 PM | #17 |
It's the new logo for 2014!
12-23-2013, 10:51 PM | #18 |
Its awesome!
-Rus |
12-23-2013, 11:04 PM | #19 |
Tot Roddin'
I agree... Love the new logo.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-23-2013, 11:10 PM | #20 |
Thanks guys!
12-24-2013, 12:18 AM | #21 |
Sweeeeeet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
12-24-2013, 08:20 AM | #22 |
What year fords are you going to cover?
12-24-2013, 10:08 AM | #23 |
Awesome job Nathan now I need some more info I already have some customers lined up but one is looking to do a trailing arm setup coil over rear. Thanks again Paul
12-24-2013, 11:11 AM | #24 |
Registered Cruiser
Nate, the Ford kits are turning out killer!! 67-72chevytrucks.com may have to let the Ford guys occupy some "front seating", cuz the Ford guys are going to eat this stuff up!!
Ford or Chevy... If it's cool, I'm in
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
12-24-2013, 11:38 AM | #25 |
Current plans include 53-72.
