Old 08-17-2016, 05:30 PM   #1
ELMatador
ELMatador's Avatar
Re: 63 C10 SWB Dropmember Build
Hey, GoaterAz I'll post a picture of the way I did mine here shortly
ELMatador is offline   Reply With Quote
Old 08-17-2016, 08:06 PM   #2
GoaterAz
GoaterAz's Avatar
Originally Posted by Pro Performance View Post
Thanks man!
I don't sell anything like that, but I just bought a small heim from McMasterCarr.com which bolted directly to the pedal assembly. I would look at what heims are available, as most are 3/8-16 if I remember right.
Its getting closer to the good cruising weather!
Awesome, thank you for the direction.
The picture helped greatly, thanks for passing along!
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline   Reply With Quote
Old 08-17-2016, 07:29 PM   #3
ELMatador
ELMatador's Avatar
I just used a heim joint, some all thread cut to the desired length, a coupler and some jamb nuts.
Old 10-06-2016, 08:37 PM   #4
Pro Performance
Pro Performance's Avatar
Quick video of our trip to the Pleasanton Goodguys show this last August.
https://youtu.be/O2UnKM-Hg5s
Pro Performance is offline   Reply With Quote
Old 10-10-2016, 02:16 AM   #5
1hihum
You have a set of slosh tubs in your truck now don't you? How about some pics! Great video by the way.
1hihum is offline   Reply With Quote
Old 10-10-2016, 11:06 AM   #6
Pro Performance
Thanks!
Here is a pic of the Slosh Tubz installed.
Old 10-10-2016, 08:52 PM   #7
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Looks really great Travis!!!
Modges'66 is offline   Reply With Quote
Old 10-20-2016, 05:21 PM   #8
Pro Performance
Thanks!
Old 10-20-2016, 05:25 PM   #9
Pro Performance
The rear axle seals were leaking, so I decided to pull the bed to make things easier. At the same time, I wanted to relocate my computer and VU4 to be better accessible. Just in case I needed access and the truck was unable to lift. This is what I came up with for a solution.
I Uses the AccuAir ECU/VU4 mount, then adapted one of our aluminum tube clamp bracket from an offload product we manufacturer. Think it turned out pretty well. Still have yet to finish, but will try and post pics when done.
Ignore the dirt and dust... it is a driver. lol
Old 10-21-2016, 01:55 AM   #10
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Nice Travis,
Great looking adaptation, it helps me visualize ways to do mine. Love to see more pics with an overall view when you finish up, and I'll have to think about other ways that bracket could be used.
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 10-21-2016, 10:52 AM   #11
Pro Performance
Thanks!
I will post some pictures up when finished. For now, here is a little wider angle.
Old 10-23-2016, 03:26 PM   #12
Twisted78SS
Wide n'Low
Thanks!
Thanks Travis, that helps already.
Yet another item for the next project.. I'm thinking I have to change it's name from Trippin Hazard to Some Assy Required. lol
Air Force Retired
Old 10-21-2016, 05:36 PM   #13
aggie91
I'm just glad to be here!
aggie91's Avatar
Glad to see that you clean up the top of that tank! lol
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-21-2016, 06:53 PM   #14
Pro Performance
lol... You caught me.
I did, and needed to tighten the bolts and think that is why it was "sweating" like that. On a side note, this was a pump assembly I installed, not Boyd, so I may have not tightened them quite enough to begin with. Always good to take the trucks apart and do a routine check on everything.
Old 12-15-2016, 10:57 AM   #15
Pro Performance
Ended up switching the radiator out to a Entropy due to the dual fans. I think that will work better in the summer in keeping the condenser cooler for the AC system.
Old 12-16-2016, 12:59 AM   #16
Captainfab
60-66 Nut
That is a good looking radiator and fan combo
Old 02-16-2017, 11:05 PM   #17
Pro Performance
Unfortunately have decided to put the truck up for sale. I have found a new project, that will haul the family a little better. Can't keep both... need to sell one to start the other.
Old 02-17-2017, 04:05 AM   #18
ELMatador
ELMatador's Avatar
�� say it isn't so!
