View Poll Results: Exotic wood bed or skinned smooth?
Wood? 164 78.10%
Metal? 46 21.90%
Voters: 210. You may not vote on this poll
Old 07-14-2014, 02:55 PM   #376
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Wild C10 project
Originally Posted by bruce casilio View Post
Hay guys I was wondering if anyone on here is from Arkansas? If so do u no if there is someone around here that can upholster the dash after I make the 67 dash fit. That way it will match up with the 99 door panels? Thanks for any help
Bruce, I'm not too far away here in Sherwood, I'll ask around and let you know. Awesome build so far.
Brannon - sorry to here about your son, I hope things work out for you and your family.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 07-14-2014, 03:44 PM   #377
bruce casilio
Thanks. I no there is a lot of places in Arkansas that do good interior work. But I work so much I don't have time for much else! Lol
bruce casilio is offline   Reply With Quote
Old 07-15-2014, 09:21 PM   #378
Brannon yazell
Brannon yazell's Avatar
Ok, here's pics of the 400 sbc that was in the original 67' truck I had started with. When I bought the truck the motor and 700R4 trans were fresh rebuilds and ran great. Bruce ended up w it after all the trading, well decided it would look great under the hood of this build w a lil TLC. Going for that old school look.. In these pics it's already ground down, was red..
Brannon yazell is offline   Reply With Quote
Old 07-15-2014, 09:24 PM   #379
Brannon yazell
Here's the MSD EFI setup that I picked up for a real good deal...
Old 07-15-2014, 09:27 PM   #380
Brannon yazell
1970 z-28 double hump heads....I hate posting these pics cause the motor looks horrible right now. Thinking on going w a gun metal charcoal color on the motor and accents against the black..
Old 07-17-2014, 09:29 PM   #381
Brannon yazell
Guess nobody likes my 400 sbc idea...this motor was full of torque and pulled hard all the way to bout 5300 rpm. Was a fresh rebuild so really don't want to pull the heads to see if they bored it to a 406, not sure why they wouldn't at that stage. It's a roller motor w a good cam. Plans are to get it painted gun metal grey with the batwing caddi/olds air breather on top to give that nostalgic look...
Brannon Yazell
67' C10 mated w/ a 01' Silverado, extreme custom
2015 Chevy 2500 Z71 LTZ Crew Cab
MSA, Motorsports Authority, Rigid Industries, Magnaflow, Michigan Metal Works, Raceline, BASF, Street Trucks
http://67-72chevytrucks.com/vboard/s...d.php?t=624964
Old 07-17-2014, 10:19 PM   #382
I'm sure any engine you guys do will be outta site considering what is going into the body.
BTW, I like those valve covers.
Old 07-17-2014, 11:25 PM   #383
Brannon yazell
More work on the roof..
Old 07-17-2014, 11:26 PM   #384
Brannon yazell
Old 07-17-2014, 11:27 PM   #385
Brannon yazell
Old 07-17-2014, 11:27 PM   #386
Brannon yazell
Old 07-17-2014, 11:28 PM   #387
Brannon yazell
Old 07-17-2014, 11:28 PM   #388
Brannon yazell
Old 07-17-2014, 11:29 PM   #389
Brannon yazell
Old 07-17-2014, 11:30 PM   #390
Brannon yazell
Old 07-17-2014, 11:30 PM   #391
Brannon yazell
Old 07-18-2014, 07:50 AM   #392
jjzepplin
jjzepplin's Avatar
Nice work!
I like the 400 idea but then I love tellin people it's a high torque 265ci.
Then I lite the tires with a tap of the gas pedal.
Besides you already have it and you can always upgrade later.
And it would be easy on the budget.
I say use it!
Are you sure it's a 400?
What are the casting #'s?
Oh and most pistons will have the .030 stamped into the top indicating the bore.
If it hasn't been run much it will still be visible through a spark plug hole possibly.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-18-2014, 08:45 AM   #393
Brannon yazell
Originally Posted by jjzepplin View Post
Nice work!
I say use it!
Already ran the codes...1975 block
Old 07-18-2014, 09:01 AM   #394
BigDaddyV
BigDaddyV's Avatar
Killer build bud, I'm along for the ride!
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 07-18-2014, 09:13 AM   #395
jjzepplin
jjzepplin's Avatar
That's a good block.
Same as mine.
How about the heads?
I used the stock heads but punched them to 2.02's
And had the bowls worked for the new valves.
It has been a very reliable engine.
Of course there was a lot more than that done to it but blah blah.
Old 07-18-2014, 10:16 AM   #396
Brannon yazell
Same as mine.
Glad to hear...the heads are casting #3927186 69' to 70' Z28 64cc. I haven't measured the valves, probably still stock. I was impressed with it in the 67'
Brannon Yazell
Old 07-18-2014, 03:37 PM   #397
Brannon yazell
Third brake light is gone...
Old 07-18-2014, 03:38 PM   #398
Brannon yazell
Old 07-18-2014, 03:39 PM   #399
Brannon yazell
Old 07-18-2014, 08:41 PM   #400
Brannon yazell
And more welding on the roof, then on to the doors.
bagged, c10, ls1, shaved, swap
