06-26-2014, 10:43 PM | #376 |
Re: My Luxurious late model truck (not so much)
I've got the husky liners in my 1996 Z71... I like them a lot and they've saved me carpet from tons of grease/mud... A little degreaser and a pressure washer cleans them up from the worst conditions.
Austin 1996 Chevrolet K1500 Silverado 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
06-27-2014, 07:22 AM | #377 | |
Watch out for your cornhole !
Or the more molded Huskyliner liners ?
06-27-2014, 10:01 AM | #378 |
Molded for the win!!! The edges are curled so all the dirt and debris doesn't slid off of the mat into the carpet. They're dirty right now. Just washed the truck and headed to the beach so I'll clean them when I get back
06-27-2014, 01:09 PM | #379 |
Austin, I'm really considering going with the big flat Husky liners rather than the molded ones. I have the flat ones in my Honda and really like them. Mainly, I've heard the edges of the molded ones will tend to roll up over time. I think that would bug me.
Today's update is minor since its yard work day here at the house. I can't sneak in too much work due to time constraints. The truck is getting near roadworthy so I've been trying to address anything that might cause me to fail inspection. One of those things is the air cleaner housing. This truck falls into a crappy window in the Texas inspection laws where it has to be smogged and pass a visual inspection. I say crappy window because vehicles 25 years old and older just get a safety inspection. And vehicles with OBD2 (95 and newer) get a safety inspection and code check. But, this being 2014, any vehicle between 1990 and 1995 year models has to be smogged. Come December 31st, the truck will turn 25 years old and never need smogged again, but nevertheless I need to get it done this year. So, part of the visual inspection is for the inspector to verify that all emission equipment is in place and connected. The problem here lies with my exhaust manifold. Remember I had bought new exhaust manifolds since my originals were cracked. The new repro manifold was so poorly built that the heat stove wouldn't even allow me to screw a spark plug into number 2 cylinder. So I had to remove the entire heat shield. That leaves me with an air filter housing with a big hose connection on the bottom of it, but no hose to connect to it. That's a sure failure point. So..... Cut Make filler piece and weld in place Sand carefully and powdercoat so the patch is invisible. Final product. I went with semi gloss powder on the air cleaner base and 80% gloss on the lid for contrast. Now, will this legally pass inspection according to the letter of the law ? No. But, it's been my experience that inspectors work on so many different cars that when they lift a hood, anything that is completely missing isn't noticed. Things like disconnected hoses or equipment partially installed tends to catch their attention, not something that is gone and shows no reasonable sign of ever being there. It's all bullsh1t anyway. The truck still has to pass the sniffer. Who cares if I have a team of mules hitched up under the hood as long as the tailpipe is clean. Pure bullsh1t. I hold it all in contempt because when I got my last GMT400 truck the previous guy had removed the smog pump and stuck bolts in the A.I.R. hoses. I would up removing the hoses and all signs of the smog pump completely and the truck still passed sniffer test with almost no measurable emissions at all. That shows me this stuff wasn't terribly well designed to start with.
06-27-2014, 01:38 PM | #380 |
Nice job on the cleaner! Wish I could weld a patch that well that it didn't need filler to look that smooth.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
06-27-2014, 08:27 PM | #381 |
That patch wasn't a slam dunk by any means. I have a thick filler primer powdercoat that I apply and cure then sand with a DA sander and 80 grit to smooth out the imperfections. Then the black powder on top of that.
06-27-2014, 08:37 PM | #382 |
Ok, maybe I'm only 98% as impressed. Still a great looking end product.
06-28-2014, 09:02 AM | #383 |
Thanks for sharing the air cleaner mod.
I have a project today! |
06-28-2014, 10:05 AM | #384 |
And I thought I was the only one out smarting the state inspections.... Between that and the straight through cat on the other truck I got a good chuckle this morning haha.
06-28-2014, 11:18 AM | #385 |
I fixt that for you
06-28-2014, 12:30 PM | #386 |
06-29-2014, 12:16 PM | #387 |
I took today off from truck work to tidy up some stuff around the shop.
I had restored my bench vise awhile back So today I dug around my scrap pile and came up with enough stuff to build a stand for it. An old GM flywheel, some 3/8 plate and a length of 2 3/8" oil field drill pipe. And of course AnnieDog had to wander through just as I snapped that picture.
06-29-2014, 12:31 PM | #388 |
Canine Photobomb....
06-29-2014, 12:42 PM | #389 |
Nice vise!!!
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
06-29-2014, 01:04 PM | #390 |
Thank you. Its a Wilton manufactured in 1947. All my buddies were laughing when I bought it at a swap meet. I gave 20 bucks for it and had to schlep that heavy thing all the way across to my space from the other side. They cracked many a joke at my expense for buying something heavy.
06-29-2014, 01:15 PM | #391 | |
06-29-2014, 02:12 PM | #392 |
I know the pieces fit
Yeah, that was a steal. Apparently the word is out on Wilton's, they seem to fetch big numbers on CL and ebay. I gave up finding one at a decent price.
06-29-2014, 06:48 PM | #393 | |
I have to give it to you lugging that thing across a car meet/show deserves a medal.
06-29-2014, 06:59 PM | #394 |
This hasn't happened to me, but apparently some of the Chinese junk will break if you start beating on them, and unfortunately most of it is mfg'd there now anyway. Something USA made from back when it was built to last a lifetime fetches top dollar now.
06-29-2014, 07:13 PM | #395 |
I didn't even realize what I was buying at the time. I just saw a solid quality USA made vise. The guy was asking 25, I offered 20 and he bit. Then I had to lug the thing a long way back to my swap meet space. I only later found out what a Wilton was and how to find the manufacture date on it. It probably a legit 80-100 dollar vise. I did have to put new jaws in it though, which were 50 dollars for them alone.
06-29-2014, 07:55 PM | #396 |
The Chinese ones are junk... I broke one, wasn't even hammering on it what a piece of dung.
06-29-2014, 10:06 PM | #397 | |
Score on the vise. That's a nice solution on the door panels, that wood strip. Good thinkin' and execution. Too funny at the OCD comments... I get stuck on so many things cuz some little thing just 'has to be fixed even tho' it's gonna take me 2 more hours and won't really matter'. Tho' I'll know it and it'll bug me. Thanks as always for the information sharing. -W Last edited by Woogeroo; 06-30-2014 at 01:56 AM. |
06-30-2014, 07:43 AM | #398 |
Woog, I'm glad to hear I'm not the only one that suffers from the OCD deal. It's got to be right or I just can't tolerate it anymore.
I finished the vise stand so turn the page on that project. I guess I'll go over to my insurance office today and put insurance on the 4x4. I'm kind of running out of excuses to not drive the thing.
06-30-2014, 12:27 PM | #399 |
Well it's now 100% road legal.
Drives good. No problems. No issues so far.
06-30-2014, 12:45 PM | #400 |
Sweet!
