01-07-2015, 10:37 AM | #376 |
67cheby
Re: Slosh Tubz SEMA 2015 Build "BOOSTED BERTHA"
Hammer and dolly to lay the door skin back down flat
Started tacking about 4 inches apart and 2 tacks at a time until it was finished , blowing it with the air gun between runs and letting it cool. I still have warpage ??? I will pull out the low spots with the stud welder I guess....I would love to take a class on welding in patch panels to see how to do it without getting the warping ! Speaker hole and 500 mirror holes next ! |
01-07-2015, 11:28 AM | #377 |
What you've done so far looks good! Are you sure the warping was from welding or was it from grinding? Grinding too long, or with a lot of pressure can cause heat build up and warped panels. Your tack spacing sounds good, but you can always try to space it out more if you think that caused warping.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
01-07-2015, 11:43 AM | #378 | |
67cheby
01-07-2015, 11:48 AM | #379 |
Mike, nice repair job...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
01-07-2015, 12:58 PM | #380 |
done a nice job on re-attaching that doorskin
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
01-07-2015, 08:04 PM | #381 |
It's hard to notice any warping in your work, with that gnarly speaker hole staring at you.
JK |
01-08-2015, 02:38 AM | #382 |
60-66 Nut
Someone else. Here is his website.
http://tdtrunniondesign.com/ This is the member. http://67-72chevytrucks.com/vboard/member.php?u=104810
01-08-2015, 08:07 AM | #383 |
sub'd, this is going to be awesome to follow!
01-08-2015, 08:21 AM | #384 |
Great job on your door patch. I will be doing both my doors here real soon. It looks to be as much of a pain in the A$$ as I expected.
I am curious to see how you go about fixing the speaker hole. My holes look exactly the same. I was thinking of cutting them out square and then making a patch panel with the correct lines to weld back in by making a template in layers of mdf that I can beat the metal into shape with the correct lines to match the door.
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
01-08-2015, 08:36 AM | #385 |
there are some wide plier like tools for straightening and bending back the fold ontoo the inner door again
that makes the job a little eazier but its still a lot of fiddly work to get the edge to look good again i think it allso depends on how original you want te door to look on the edges you could grind away on the fold part of the bend untill you see the 3 layers then cut off wat you replace including the folded over part of the outer doorskin of the bottom of the inner door and instead of bending the doorskin fold over back you can (spot?)weld all around in stages (prevent too mush heat buildup) grinding the weld smooth and keep grinding or sanding on the edge untill the gap is even all round as whell just dont expect to be able to reskin the doors after that unless you grind the inside of the door off again too it is possible to make the edges / inside of the doors look like there made from one piece that way (no edges visible from the folded over metal and stuff like that ) kindah like wat they did to welds on the old choppers make it look like it was moulded out of one piece
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 01-08-2015 at 08:45 AM. |
01-08-2015, 10:33 AM | #386 |
What you did with the door looks good & proper. With that large speaker hole you might have used a copper "chill block" to absorb some of the weld heat when re-welding. It typically would require an extra set of hands ... to move it along with your welding. On other places I prefer a cold bucket of water & a facecloth. When you weld the area, typically, it expands, so the cold wet cloth will bring it back into shape (shrinking it). It's not 100% but it does a good job. Air blow it after to dry it out.
Just my 2 cents worth ... dig'n what you've done & r doing ... R46 |
01-08-2015, 11:00 AM | #387 | ||||
67cheby
ThankS !
gracias senor ! LOL Quote:
Thanks man, I hope everyone enjoys it as much as I am ! Quote:
01-08-2015, 11:03 AM | #388 |
67cheby
Ok here is the speaker hole filler fix.
Marked off and cut the speaker holes out of the original doors Moved the cut pieces over to the donor door and marked the patterns off |
01-08-2015, 11:06 AM | #389 |
67cheby
Welded in and smoothed off
The passenger side came out way nicer then the drivers side, however none of this will be seen after a little body work. The interior shop Urban Customs is building full length door panels but I just couldn't leave the holes ! The passenger door bottom doesn't need replaced, it only had a few pin holes in it. I just carefully welded up those small holes |
01-08-2015, 11:12 AM | #390 |
Nothing wrong with those repairs ...
R46 |
01-08-2015, 02:44 PM | #391 |
Will we be seeing a set of slosh tubes in the research and development stages on the build?
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
01-08-2015, 02:57 PM | #392 |
67cheby
Thank you !
You know you will ! Very soon ! |
01-08-2015, 03:40 PM | #393 |
If so....ill buy the first set.
01-08-2015, 03:42 PM | #394 |
67cheby
you got it , keep in touch !
01-08-2015, 05:44 PM | #395 |
01-08-2015, 08:19 PM | #396 |
67cheby
No I still have her $4500 is what I have her on craigslist for ! Thank you !
01-08-2015, 09:14 PM | #397 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Killer work on the inner doors!
Don't even start to question the quality of your skills!!!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
01-08-2015, 11:46 PM | #398 |
Great work so far! Your making me want to tackle the same areas on my truck!
01-09-2015, 10:18 AM | #399 | |
67cheby
It really wasn't nearly as bad as I thought ! |
01-09-2015, 11:10 AM | #400 |
Your build, repairs, ideas continue to both impress, inspire and motivate me.
Seeing your speaker hole repair, I now feel the need to find a pair of repair sections for my doors, where the holes are present, but not in use. I like the idea of closing and painting the holes in metal. If I did not do that, I was going to make up covered panels with carpeting on them. Looking forward to seeing how little wage I can initiate when I start welding, as I am always impatient, and in a hurry to get stuff done.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
