12-30-2014, 10:40 AM | #376 |
Re: "Project Orangepeel" 52 A.D
Here is a quick update..
Pic #1 are of the new calipers I got in. They were supposed to be bare when ordered. (after about 3 weeks they called and sent these for the same price) I picked them up from (Performance online) dual piston design. Pic #2. Rotors and calipers sitting together. I know the "Bling" of the calipers is a little much for this project but they didn't cost any extra...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
12-30-2014, 10:49 AM | #377 |
Back to the Build...
Pic #1. The passenger side molding in progress, still need to do some trimming at the bottom transition. Pic #2. I also picked up a 1 piece headliner it is made from ABS plastic.. I shopped around for a bit to get the best price $140.00 for the piece. Might be a bit pricey to some but very little trimming and it was in... It has a leather texture on the face of it. Simply paint it to match you interior.. Mark...
12-30-2014, 11:57 AM | #378 |
where did you end up getting your headliner I have been shopping around for one as well and yours sounds like a winner
12-30-2014, 01:15 PM | #379 |
Nice work Mark. Easy headliner deal...Rod Doors use to have something like that though I believe they went out of business.
Like the calipers. Did the package come with mounting brackets? Looking forward to more updates. |
12-30-2014, 02:15 PM | #380 |
looking good, calipers look cool. headliner sure beats the cardboard ones.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
12-30-2014, 06:05 PM | #381 |
Nice headliner Mark, indeed looks like leather.
Nice brakes also!! Aren't you going a bit too fast???? Hardly keeping up with your posts
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
12-30-2014, 07:19 PM | #382 |
Picked it up from (Oldchevytrucks.com) part #UPH164 is was $148.00 it was cheaper than any other company at the time..
Mark...
12-30-2014, 07:25 PM | #383 |
Not sure if they had been bought out or what but you can still find their stuff online. (this maybe their's)
The calipers are GM D52 style bolt right on Brother!!!
12-30-2014, 07:27 PM | #384 |
99..it absolutely does....they get a drop of water and poof!! blow up and fall apart lol..
12-30-2014, 07:28 PM | #385 |
IDK about going to fast....can't get enough done haha..
12-31-2014, 07:57 PM | #386 |
A bit of an update..
Pic #1. If you remember me saying I didn't like the rounded edge at the bottom of the garnish molding, so I squared it off on both so the lines look better. Pic #2. The molding has some larger than desired gaps along the dash so I will address this next. Again using 1/8" round bar to clean it up...also the red piece is a mockup of the center cover I'll make..
12-31-2014, 08:02 PM | #387 |
Pic #1. another view of the drivers side..
Pic #2. Starting to get the bar tacked in place.. I will use the Tig to do my final weld. (I will also keep the moldings screwed down in place while welding and cooling stages to keep from moving) Mark...
12-31-2014, 08:59 PM | #388 |
That looks really good...nice attention to detail!!
And thanks for the additional info on the headliner and calipers. Happy New Year Mark! |
01-01-2015, 01:27 PM | #389 |
Thanks A. D.
Slow process but worth it...
01-02-2015, 11:15 AM | #390 |
Happy New Years to everyone!!
01-02-2015, 11:23 AM | #391 |
Pic #1. a closer look of the molding and round bar.
Pic #2. after all the welding,grinding and metal finish was done..
01-02-2015, 02:56 PM | #392 |
came out nice, too bad so many people will miss subtleties like this. All apart of the process though, some stuff gets noticed and the feedback feels good, other things overlooked and as long as it suits your mind, that is the payoff.
01-02-2015, 03:30 PM | #393 |
Nice detail and a steady grinding hand. Agree with 99, most will miss this...and it looks good!
01-03-2015, 12:23 PM | #394 |
I 100% agree with you on that!!!
A Ton of work for small detail but it looks better to the Man behind the wheel HAHA!!
01-03-2015, 12:23 PM | #395 |
Again ,Thank You Sir!!
01-03-2015, 12:28 PM | #396 |
Last pic of the drivers side..
Pic #2. (not very clear) is of the center cover. This is welded to the passenger side molding on the backside and basically holds the drivers side down so no need for a fastener.. Till next time.. Mark...
01-06-2015, 11:21 AM | #397 |
This is an Idea I had in my head.....
Rather than using the stock rear view mirror arm and mount I wanted to make my own to play along with the rest of the interior.. Pic #1. The template for the mount plate. (this will cover the gap between the upper molding and screw into both sides) Pic #2. after I transferred to metal...
01-06-2015, 11:25 AM | #398 |
Here is the the upper plate after drilling and also after they had been cut and welded together to fit the molding...
I used 18 gauge metal for the upper plate..
01-06-2015, 11:31 AM | #399 |
Pic #1. So after I did all the work making the first one it felt a bit flimsy so I decided to make a new one from 1/8"
This time it was one piece (I bent it to match the first piece) transferred to the 1/8. Pic #2. The final look of the upper plate... Onto the arm.. Mark...
01-06-2015, 12:17 PM | #400 |
nice subtle touches
