Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-19-2018, 06:10 PM   #376
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Buried to Bagged 1972 2wd
Originally Posted by Slick67 View Post
That sounds sexual!
I wouldn’t kick her out of bed
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-19-2018, 07:20 PM   #377
Chulisohombre
Chulisohombre's Avatar
Dash is very cool. Going ultra retro. Maybe you said but what's that out if?
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 09-26-2018, 01:49 PM   #378
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thank you, it is out of a 1955 Bel Air. Had to be stretched 9.5 inches, but it fits.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 09-27-2018, 07:08 PM   #379
Chulisohombre
Ok thx. I thought it looked like a 50s dash. Very cool
Old 09-28-2018, 10:12 AM   #380
Sac
Looking killer!
I know you are running 22x8.5 & 22x12's.. What are your tire specs?
Green Survivor Father/Son Truck
<SeveredTies>
Sac is offline   Reply With Quote
Old 10-04-2018, 07:35 AM   #381
mcbassin
Still Learning
mcbassin's Avatar
Looks great!
mcbassin is offline   Reply With Quote
Old 10-31-2018, 07:59 PM   #382
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks man!
Originally Posted by Sac View Post
Looking killer!
Thank you sir!
305/40-22 outback 265/40-20 upfront.
Originally Posted by mcbassin View Post
Looks great!
Thank you sir, it's been a crazy build so far!
Old 10-31-2018, 09:20 PM   #383
Slick67
Sofa King Crazy!!
Slick67's Avatar
After getting the front clip on and half way aligned it looks like a project!!
Fitting those Slosh Tubz under the hood. I had a fitment issue but a quick call to Mike and POW, done!!!
Still have a ton to do just on the front clip but it is coming along.
Old 11-01-2018, 07:46 AM   #384
jjzepplin
jjzepplin's Avatar
Ok then. Tic toc.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 11-01-2018, 11:47 AM   #385
jaros44sr
jaros44sr's Avatar
JMHO but, if you're doing a 2WD it should look like this thread
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-01-2018, 12:02 PM   #386
olrosa
olrosa's Avatar
Nice, nice, nice
olrosa is offline   Reply With Quote
Old 11-08-2018, 08:28 AM   #387
mcbassin
Still Learning
mcbassin's Avatar
Very nice!
Old 11-28-2018, 04:48 PM   #388
72gmguy
72gmguy's Avatar
Did you figure out what to do with the cowl along the bottom of the windshield? I've been curious for a while what you decided. This thing is incredible!
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 12-11-2018, 06:26 PM   #389
Slick67
Sofa King Crazy!!
Slick67's Avatar
Originally Posted by jjzepplin View Post
Ok then. Tic toc.
I know, right!?!?
Lol, the how to thread!!
Originally Posted by olrosa View Post
Nice, nice, nice
Thank you Sir!
Very nice!
Thanks Brotha!
Yes sir I did. I'll get some pics up for ya a little later tonight or tomorrow. It was pretty simple once I figured it out. Happy to share!!
Old 12-11-2018, 07:03 PM   #390
Slick67
Sofa King Crazy!!
Slick67's Avatar
Roadster cowl customization in 5 easy steps!!! I really hope this helps someone out!
Mark where your cowl should be cut to match the A-pillar.
First the back portion of the cowl was cut off and relief cuts where made from the back toward the front. I took out about 1.25" at the rear and none across the center of the cowl. I cut out excess metal until both pieces butted together nicely. This gives you a flatter surface than stock.
I cut out the fresh air vents on the cowl and replaced it with 18 gauge metal. I made the metal concave to match the cowl then used a shrinker/stretcher to get it to bend properly to match the compound curve from side to side.
I worked a little short hair fiberglass into the cuts then went over that with some trusty bondo to get it to look halfway decent.
After a small amount of sanding I got it very close but still feel a small dip where the inside relief cut was made. A little more pookie on it, and it should be good! For the record, I'm not a bodyman!!
Old 12-11-2018, 09:50 PM   #391
lks dcvn
lks dcvn's Avatar
That's pretty nice work for a non-body man. Looks awesome!
lks dcvn is offline   Reply With Quote
Old 12-12-2018, 12:32 AM   #392
jjzepplin
jjzepplin's Avatar
Oh now that's funny- For the record.
Old 01-17-2019, 05:07 PM   #393
Slick67
Sofa King Crazy!!
Slick67's Avatar
I gave it a shot!!!
Definitely not a body man!! But I'll try anything once!!
Old 01-23-2019, 05:29 PM   #394
Slick67
Sofa King Crazy!!
Slick67's Avatar
Excuse all the junk in the background. Just wanted to post a picture showing the shaved cowl. It makes the whole truck look different.
I have been working to get the dash, door, fender, body and custom sail panel on the door aligned. This is turning into a hassle but it will be worth it in the end.
Old 01-23-2019, 09:02 PM   #395
Chulisohombre
Looks awesome. All the lines are coming together nicely.
Old 09-17-2019, 10:18 AM   #396
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thank you sir!!
Old 09-17-2019, 11:08 AM   #397
Slick67
Sofa King Crazy!!
Slick67's Avatar
I have not done much to the Blazer lately, but that is about to change!! This is the concept I have in mind and if it flows together it may be what happens. I am going for the old Corvette look. Thoughts?
Old 09-17-2019, 11:33 AM   #398
Joseog83
Joseog83's Avatar
Attachment 1939648
Attachment 1939649
Have never seen that before! Would look killer!!
Joseog83 is offline   Reply With Quote
Old 09-17-2019, 11:42 AM   #399
Slick67
Sofa King Crazy!!
Slick67's Avatar
This is the reason my Blazer has not been getting much attention. I bought this little 78 GMC and put some time in on it. She is cool, just not old enough.
Name:  20190525_152518 - Copy.jpg
Old 09-17-2019, 11:43 AM   #400
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks man! Just trying to think outside the box and bring cool stuff to the custom world!!
