Old 12-22-2020, 09:56 PM   #376
SkinnyG
SkinnyG's Avatar
Re: SkinnyG's '61 Apache
Sprayed some more epoxy on parts/spots I missed.
Measured the old angle strips (1" tall) and the new angle strips (1-1/8" tall), then did some math for the raised bed floor, plus the thickness of the composite boards (15/16" vs 3/4" pine) to figure out where the new strips need to be mounted.
Drilled holes for plug welding the new strips.
Removed one offending fender bolt (offender?) which is right where the strip needs to go.
Hung the doors on the cab, and sat on some lumber to make some vroom vroom noises.
Placed the inner fenders and front fenders just to gaze once again at the awesome hard park height. Hoping to get the bed on soon.
General tidying of the shop.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-23-2020, 10:32 AM   #377
SCOTI
SCOTI's Avatar
All that sheet metal hanging & no images for your peeps? That's such a tease.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-23-2020, 10:40 AM   #378
88Stanger
88Stanger's Avatar
ummm... ya must agree fully!!!!! WE ARE DYING HERE!!!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 12-23-2020, 02:58 PM   #379
53Sparky
53Sparky's Avatar
How'd you get so productive? That's a month's worth of work for me! I'm lucky if I get part way through the vroom vroom noises before I'm out of time. And general tidying of the shop? Please! That never happens.
We'll burn that bridge when we get there
My current project: Rust Therapy 62 C10
Numbers 6:24-26
53Sparky is offline   Reply With Quote
Old 12-23-2020, 04:40 PM   #380
SkinnyG
SkinnyG's Avatar
I guess I shouldn't also tell you that before I went into the shop at all yesterday, I snow-blowed the driveway to the house and around back to the shop.
Also cut down and chopped up my neighbour's low growing pine which didn't withstand the heavy dump of snow (and was now blocking shop access), then hauled all the evidence to the dump.
All the while wondering what the hell I did to my back, because it hurt to move, and Robaxacet wasn't helping. I move even more like the old man I am. Sweeping the shop is easy "productivity" when I'm in pain.
As of now, it's 12:37pm, and so far I made bed floor risers out of 2x4x0.120" rectangular tubing, which also required TIG-welding my bandsaw blade back together (this is the 3rd repair I've done, and then it broke again almost right after!). Also made some 4" extenders to move the "step" mount lower.
Home Depot called to say the composite decking is in. Once I finish my tea, I'll head down. And pick up another bandsaw blade, too.
Oh, and you guys are a tough audience. I wanted to post a pic with the bed on, but here you go:
Old 12-23-2020, 08:32 PM   #381
cwcarpenter98
cwcarpenter98's Avatar
Oh yeah, that's gonna be super nice!
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 12-24-2020, 01:46 PM   #382
SkinnyG
SkinnyG's Avatar
Home Depot couldn't find the Trex boards, so I went home. I called this morning to see if they found them, and they had, so I went down again.
Looks like forklift operator tagged something immobile, and chipped two boards and broke another, so another length is ordered, but I brought what would work home. Be a couple weeks for the replacement to come in.
And, it seems my '77 is now stuck on "turn right" mode. Not sure what's up with that - steering box issue?
Old 12-24-2020, 06:59 PM   #383
SkinnyG
SkinnyG's Avatar
Found the "turn right" problem on my '77. This was unexpected.
Old 12-24-2020, 08:27 PM   #384
53Sparky
53Sparky's Avatar
That's not good! Glad you're safe. Was it sheared off?
Numbers 6:24-26
Old 12-24-2020, 08:56 PM   #385
jayoldschool
Moderator
I had alignment shims fall out of a Caprice once. Drove ok, but the right spindle would move fore and aft about an inch and a half when on/off the brakes. Apparently it's pretty common. My cross shaft bolt stayed in, though...
jayoldschool is offline   Reply With Quote
Old 12-24-2020, 09:13 PM   #386
cwcarpenter98
Oh dang, that's sketchy
Christian Carpenter
Old 12-24-2020, 09:46 PM   #387
SCOTI
SCOTI's Avatar
Bolt/stud rot away?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-24-2020, 11:41 PM   #388
SkinnyG
SkinnyG's Avatar
Not rotted at all. Shank is cherry, and the clean break has zero corrosion at all on it. Not sure why it failed.
In other news:
Boards just set in place with strips for that "feel good" moment:
Old 12-25-2020, 01:21 AM   #389
SCOTI
SCOTI's Avatar
I like the board set-up. Wish they came in 'to spec' widths. I couldn't find anything available in wider widths when I searched.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-25-2020, 01:28 AM   #390
SkinnyG
SkinnyG's Avatar
Fascia board come in 8" or 12" width, but the 3/4" thick fascia boards I found didn't come in colours I wanted, and the colours I wanted were either 1/2" or 9/16" thick.
Fascia boards would have cost me $650CDN, whereas these deck boards were $240CDN, which is cheaper than buying white oak in raw planks (zero waste for the Trex).
To fit these boards meant having an extra skid strip.
Old 12-25-2020, 02:18 AM   #391
SCOTI
SCOTI's Avatar
Yep.... Sounds like what I learned. You can find one aspect you want @ the cost of another....
The 'better' widths didn't come with color options desired.
Color options limited width choices or thickness of the planks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-25-2020, 08:51 PM   #392
88Stanger
88Stanger's Avatar
In other news:
Oh ya, now I really like this!!!
Old 12-26-2020, 10:40 PM   #393
SkinnyG
SkinnyG's Avatar
Started welding it back together today.
Added my 4" floor riser at the rear. Turns out the Trex decking is 0.850". Spot welds mean less warping.
Old 12-27-2020, 10:47 PM   #394
SkinnyG
SkinnyG's Avatar
Nothing photo-worthy of today's adventure in the shop.
I dressed up some pin holes and welds, epoxy primed over the shiny metal area, attached the bed header and wire-wheeled the fasteners.
Also dragged out the gas tank (S10 EFI Blazer tank), contemplated how to attach it, and braced the rear frame ends together in anticipation of cutting out a crossmember.
Also primered the welds on the floor patch.
Old 12-27-2020, 11:50 PM   #395
cwcarpenter98
That's some nice progress. I like your way of filling in that area caused by raising the bed floor
Christian Carpenter
Old 12-28-2020, 12:41 PM   #396
SCOTI
SCOTI's Avatar
x2
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-28-2020, 10:05 PM   #397
SkinnyG
SkinnyG's Avatar
Bed supports now located at their new height:
4" Bed risers, made of 2x4" rectangular tubing:
I need to lower the step braces 4" as well. Thank you GM, for being drunk and disorderly on the assembly line:
Old 12-28-2020, 10:50 PM   #398
72cs20
You're really showing some serious skill. Thanks for posting the videos too!
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 12-29-2020, 12:18 PM   #399
88Stanger
88Stanger's Avatar
Damn fine work sir!!! i am inspired with some ideas from this!!!
Old 12-29-2020, 09:23 PM   #400
SkinnyG
SkinnyG's Avatar
I lengthened the Step Brackets by adding a 4" length of 2x4" box tubing, with one end cut off. I then transposed the mounting holes 4" down.
I also fully welded the bottom "stand" of the bed brace since I want to hide the bed mounting bolts. These are merely spot welded from the factory, as the whole shebang is clamped down by carriage bolts - but I don't want that.
The step was shortened by removing the box brace underneath, and I cut 14.5" out, removing some stress-fractured holes.
The undercoating was wire-wheeled off (knotted wheel on an angle-grinder), and the step was clamped to my welding table (1/2" plate steel), washed with lacquer thinner and TIG welded with zero filler (though I kept a length of 0.023" MIG wire in my hand for the three spots that needed it).
I went TIG on this, because TIG welds are so much more malleable than MIG welded, and if I needed to correct any misalignment of the "beads" I wanted it to be easy. MIG tends to crack as you beat on it. I went -against- Oxy-Acetylene, as I'm finding it harder to work with such a large Heat Affected Zone. With TIG I set it on pulse to keep the heat down.
