11-08-2019, 07:13 PM | #376 | |
Re: 1969 K10 CST Full Restoration
Where did you source the red hub dials from?
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858 |
11-08-2019, 07:29 PM | #377 |
I'm trying....
A picture is worth a thousand words as they say...check out post #10. They are NOS and my brother found them either on Craigslist or eBay....I'm not 100% sure which now. They weren't red...(NOS red dials are another set of hen's teeth that we couldn't come up with). They were yellow, but only a mean person with a knife would know that now...or someone with an internet connection...and eyes to see post #10.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
11-08-2019, 08:38 PM | #378 |
as of now, a set is on our for sale section
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-09-2019, 07:05 PM | #379 | |
11-09-2019, 09:44 PM | #380 |
I'm trying....
Don't sweat it. Definitely 15373 Flame Red. I took an original dial in to match it. It's a pretty solid match.
11-10-2019, 11:27 PM | #381 |
I'm trying....
Several things accomplished this weekend...still a longer check off list than I'd like. I'll try and post more pics tomorrow, but this was the highlight of the weekend (see link below). Started on the first try. These are her first spins. Started filming a few seconds after she caught and I was confident she was holding her water so to speak. Sounded pretty good for no carb or timing tweaks.
https://vimeo.com/372279353
11-11-2019, 12:53 AM | #382 |
Amazing... looks and sounds smooth for a first start!
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
11-11-2019, 10:41 AM | #383 |
Proprietor of Dale's Corner
Nice!!! It's alive!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
11-12-2019, 08:47 AM | #384 |
Carpe manana
Take a victory cruise beer run to celebrate back at the shop!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
11-12-2019, 11:18 PM | #385 |
I'm trying....
Thanks. It was amazing actually. But I'll take a win where I can get it.
Got a pulse and breathing...just got to get her on her feet! If I can ever master a double flare we will my friend.
11-12-2019, 11:36 PM | #386 |
I'm trying....
As I'd previously noted we had a coolant leak associated with the top radiator hose. It is not a revelation that tower clamps are not ideal. I ordered fresh clamps (because they just really seem like a one shot deal). The first set were supposedly Wittek clamps. I picked up a set of date coded ones this time around, also labeled Wittek (they were not marketed as NOS and I am under no illusion that they are) but they seemed more substantial than the first set. I lightly lubricated the inner surface of the clamps and positioned them right behind the bead on the metal radiator pipe and similarly on the thermostat housing and radiator outlet. We ran her for a fair bit last night and topped off the coolant. So far so good.
11-12-2019, 11:53 PM | #387 |
I'm trying....
We got the cowl, antenna and wipers on over the weekend. The transmission was painted black and installed, and the antenna wire got routed. We didn't get the distributor 180 degrees off this time...but we did get the the wiper transmission 180 off. Luckily we checked it before the wipers went on...but unfortunately we didn't check it until the cowl with the hood to cowl seal was fully installed. Practice makes perfect as they say. Another thing I'll get to do over is the AC vacuum reservoir canister. I didn't notice it until I watched the first start video, but we dinged it fitting the hood. Of course I blame Classic Auto Air...we sent a box/bracket/canister that came off this cab. Not sure what I got back-but it didn't quite clear. Fortunately I think Roger Koop is going to be able to hook me up with a replacement. We had a bit of a weep at the oil line connection to the gauge. Tonight I trimmed the line and replaced the nut and ferrule-hopefully that sorts it...and Eric got the splash guards installed. The goal is to be on the road this weekend.
11-15-2019, 11:08 PM | #388 |
I started reading this thread from page one about a month ago, love everything about this truck. Keep it up, and best of luck with the final tidbits. Gorgeous truck!
11-16-2019, 05:35 PM | #389 | |
I'm trying....
Thank you very much. It's been mostly fun. Inching toward the end.
11-16-2019, 05:47 PM | #390 |
I'm trying....
Nicest guy ever hooked us up with some NOS bullseye back up lenses. Got the rear brake lines re-bent. I just had too much downward bend in my first set at the spring bolts. My batting average on those double flares definitely went up as I went along. But it's still pretty low. Went through a bit of line to get those two done. Added the black center to the front caps at Pete's rightful urging. I believe they came both ways...but this makes them more symmetrical with the rears.
11-16-2019, 05:56 PM | #391 |
I'm trying....
Eric got the inner fenders in and detailed, and went through final panel tweaks. We spent the majority of yesterday evening working a to-do list that weirdly seem to shrink and grow at the same time. The big accomplishment before bed time was getting the brakes bled.
11-16-2019, 06:11 PM | #392 |
I'm trying....
It was too wet to try and get her out this morning, and there was still a lot left to do...so we made use of the time. We don't have every single i dotted or t crossed (and also the Dawgs kickoff was at 3:30) so we didn't push it to put her on the road today. But after lunch we were able put her in gear and drive her outside under her own power. It was nice to see her in sunshine. Maybe we can log some miles tomorrow.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 11-16-2019 at 11:43 PM. |
11-16-2019, 06:53 PM | #393 |
I'm excited for you. It's quite something to realize all the work into a project when it's sitting in the sun waiting for a ride. Congrats.
11-16-2019, 07:20 PM | #394 |
Carpe manana
Amazing! Great work guys. Happy for you. Let us know how the maiden voyage goes and may there be many enjoyable miles.
Anticipation is already building for your return the ring with the k20 after a well earned break.
11-16-2019, 08:14 PM | #395 |
Great looking truck!
11-16-2019, 08:30 PM | #396 | |
I'm trying....
Thanks.
11-16-2019, 08:33 PM | #397 |
I'm trying....
Thanks Pete. And thanks for all your help. It'll be a while yet before we start the K20. I'm mailing this back to you...I think it's your turn now. I see you still collecting parts.
11-16-2019, 08:55 PM | #398 |
I'm trying....
Speaking of thanks....the resource that this board is to us cannot be overstated. The generosity of spirit, support and collective knowledge is extraordinary. Learning is one of the best parts of this kind of thing and we learned a lot on this build. Of course we're not completely finished and I'll keep posting here, but I do feel like it's time to say thanks to all of you that helped will parts, info, or a kind word. Thanks OLDYELLOW for putting up with me and for your maniacal commitment to slick paint. And thanks to the mythical Hay Man 17 for finding us a real deal 69 KE SWB to work on.
If I've missed someone I apologize...but thanks to you all: DeadheadNM Dirt’s72 FirstOwner69 southern parts Chipflyer LockDoc Roger Koop uncle Jaros44sr Austinjay 2014sierraAT Ol Blue K20 1rippen6 smbrouss70 1972 Jimmy 72 tigger CTENTA1 AASmedic Chulisohombre JJH Jimmy 4x41971SWB lks dcvn rowdy11 tristan rustytruck50 Sand Wrench davischevy 72K5CSTDarkOlive 68Gold/white cebra chewychevy67 4burbon Madkidd007 argonaut Yerboogieman weim55 1971Stepside 70STOVEBOLT notsolo Medina MDPotter 69CST4x4SWB 1956cameo 402Bowtie Martyt 68bowtie 70LonghornCST RCbowtie69 cornerstone regan wilson Kronald_70GMC harrisoncole4 69cam And thanks to Molly (non-member) for being the best shop dog ever.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." Last edited by IronCanine; 11-16-2019 at 11:37 PM. |
11-16-2019, 09:07 PM | #399 |
Only wish I had more proper parts to give you, maybe on the next one I’ll have some stuff laying around
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
11-16-2019, 10:41 PM | #400 |
Another high quality build! You guys are impressive in your level of detail and the speed of the build. I enjoy seeing a truck that looks like it just rolled off the assembly line. Hope you’re able to spend some time riding in it, does your shop dog like going on rides?
71 C10 72 K20 72 K10 Super Kirk |
Tags |
1969, 4x4, cst, k10, swb |
