Old 11-13-2019, 08:45 AM   #3976
Marty68
Re: What did you do with your truck today, Part 3
paying a local race fab rod shop.. a bunch... to me there is a value to have a receipt from reputable shop for that work. AND if i don't do it it will be drive able sooner. he does this for a living and does great work.
new coil rear suspension. wheel opening is 26" 245/60/15 tires
MII tubular A Arms front no coil overs or bags. it will be 1" lower than rear 235/60/15
all new brake lines master cylinder and booster under floor
Power steering
keeping original steering column. it will be cut down and a plastic bushing made for the bottom.wife said NO WAY to loosing original wheel.
I may get it back before thanksgiving.
i am researching and deciding weather or not to relocate gas tank to rear? mustang? or re install one in the cab. i will measure and evaluate. currently had half barrels in bed for fuel tanks.
STOKED to get it back so i can piddle with it!!
Marty68 is offline   Reply With Quote
Old 11-13-2019, 09:26 AM   #3977
mick53
Power steering
I think you are spot on. Some things are better left to the professionals. I would rather pay someone to make sure some things are perfect than to try to do it myself even if it hurts the wallet. When I have parts made I try to find someone that not only will make it but is excited about making it. Usually an old guy (like me) in a small shop.
mick53 is offline   Reply With Quote
Old 11-13-2019, 09:49 AM   #3978
MARTINSR
MARTINSR's Avatar
Originally Posted by OrrieG View Post
When did you move to Boise? I have not been on the board much since work on the truck slowed down (too may honey dos!). Would like to get together some time.
I have been here since mid August, yep, we need to get together.
Got my garage painted and some of my art up, WHOOO HOOOO! Building my shed kit last night kicked my butt, I didn't want to stop had had to.
I'll be back to my truck in not too long.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 11-13-2019, 09:58 AM   #3979
mick53
Brian
That's nice, my shop is a total disaster. I wanted to build another shop this year but was stuck on a project out of state all summer.
Old 11-16-2019, 05:12 AM   #3980
MiraclePieCo
MiraclePieCo's Avatar
Just watched a movie:
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 11-16-2019, 10:55 AM   #3981
mick53
I need to put the big hole in the little cover. I'm going to try to do this myself. This will be my first attempt to make something important with my mill. I bought the big block cover from Summit for $52. My plan is to cut the big block seal holder out of the cover with my rotary vice and bore a hole to fit in my 292 cover and mind meld them together. It looks like it will just fit. I ordered this boring head. https://www.shars.com/4-adjustable-b...mbo-8-pc-set-1 It was pricey but will give me one more capability with my mill. I was going to send it out but decided to go for it. If I fail all i'm out is a $53 cover and a cover I can't use. If I pull it off I'll feel pretty good about myself.
Old 11-16-2019, 11:34 AM   #3982
DransportGarage
DransportGarage's Avatar
A secondary challenge will be alignment with the crank nose. I assume you'll be tacking it in place while it is mounted on the block. Be careful not to melt the seal! (but hey, you can always punch in another one after the smoke has cleared!)
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 11-16-2019, 01:17 PM   #3983
mick53
I figure if I set the boring head center off the existing hole on the 292 cover and cut the big block cover with the rotary vice in the big block hole I should retain the same center. Of course I have no idea what i'm doing. Succeed or fail I will be smarter when I'm done.
Old 11-16-2019, 05:46 PM   #3984
DransportGarage
As long as those Asian guys machined everything spot on, the additive error won't get you. I would at least put the BB cover in place and check concentricity before I cut it.
Bob
Old 11-16-2019, 08:58 PM   #3985
crossfire84
crossfire84's Avatar
How are you going to locate both centers in the exact same x/y axis without a common fixture for both pcs?
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 11-17-2019, 12:10 AM   #3986
mick53
I figure I will clamp the 292 cover on the mill and set the boring head to exactly the same as the existing hole and then using the same center enlarge the hole to 3.6" Then using the big block hole on the rotary vice with the self centering vise in the hole I should maintain the center and mill it down to 3.6". This keeps me just outside the collar on the big block cover and just inside the screws on the 292 cover. I should be able to drop the big block collar in the 292 hole and maintain the center. I don't think it has to be within .oo1". some of them are made out of plastic and have some play when you mount them. I realize it has to be close but not space shuttle close.
Old 11-17-2019, 12:26 AM   #3987
mick53
Didn't get much done had to make arrangements for my car hauler to be delivered from GA. It will be here Friday. I put my speedo block off on my trans after polishing of course. I have GPS speedometer. I drilled and tapped in some stainless steel 1/8" pipe plugs in my dipstick hole and the bolt hole.
Old 11-17-2019, 09:21 PM   #3988
MiraclePieCo
Slick!
Old 11-18-2019, 12:08 AM   #3989
mick53
I started working on my blower belt guard again. I had already sanded the chatter out of the cut outs and blocked it down to 600 grit. Using the sandpaper mandrel on my rotary tool I sanded the cut outs with 1000 grit, 1500 grit and 2000 grit and then polished with tripoli. I will now start sanding the faces further. I like to finish places like the cut outs first so WHEN my rotary tool slips it doesn't bum me out so much.
Old 11-18-2019, 02:10 AM   #3990
MALIBLOC
MALIBLOC's Avatar
grounded my taillights and installed blue dots
MALIBLOC is offline   Reply With Quote
Old 11-18-2019, 09:29 AM   #3991
crossfire84
LIL ERV the 50-3600
C4 rear
Porter built a arms
Old 11-18-2019, 10:07 AM   #3992
evilokc
didn't get to do much besides pulling it out and later back into the garage. been working on my house. trying to get the inside painted before my family comes over for the holidays. its getting chilly. hate the impending doom of winter.
evilokc is offline   Reply With Quote
Old 11-18-2019, 11:51 AM   #3993
mick53
Doom of winter, really, New Mexico? We had 6" of snow last week and 7 deg. I guess it's all about perception.
Old 11-18-2019, 11:58 AM   #3994
MALIBLOC
MALIBLOC's Avatar
here you go , couldn't understand why they wouldn't operate properly , does seem like driver side is a little dimmer than passenger, may have to investigate that more, just glad to find the problem and fix it.
Old 11-18-2019, 09:52 PM   #3995
mick53
I went to the courthouse today and started a Racing company (XXXX XXXXX Racing). In my county it cost $25 to file a DBA. Took that to the bank and opened a bank account. Received a debit card and checks. Sent my credentials to PRI show in Indy to get my pass in. Before this I always had to depend on others to get me passes to closed trade shows. I have a feeling this company may lose money.
Old 11-19-2019, 06:42 PM   #3996
MiraclePieCo
I've seen some really weird inexplicable electrical problems solved with better grounds.
Old 11-19-2019, 11:57 PM   #3997
mick53
I received my boring head today and started the timing cover. I installed the cover on the engine ran the screws in slowly doing the countersunk ones first to make a repeatable install. After setting the boring head to the existing hole I moved it .005" to center it. I then took cuts of .100 until I got close and did a finish cut of .005. I will reinstall it tomorrow and see how it fits. Then cut the other center out. I have no idea what I'm doing.
Old 11-20-2019, 07:01 AM   #3998
DransportGarage
Most of us wouldn't have known how to spec the boring head for purchase. You're gonna knock this one out of the park. Sounds like you're already .005" more accurate than the factory hole.
Bob
Old 11-20-2019, 09:14 AM   #3999
MARTINSR
MARTINSR's Avatar
LOL, Naaaa, you are now a professional race car driver! A guy I work with at my new job has raced his whole life! OMG every time this guy talks it's about a different wild story, Baja 1000, NASCAR, everything but drag racing. He says he doesn't want to work days on a car for a few second thrill. LOL
He is now into Sprint cars, racing is this guys life!
Brian
1948 Chevy pickup
Old 11-20-2019, 09:15 AM   #4000
MARTINSR
MARTINSR's Avatar
Good to see you guys getting stuff done on your trucks!
Brian
1948 Chevy pickup
