07-17-2023, 12:05 PM | #4026 |
Junior Member
Re: What did you do to your truck today.The 3rd chapter
Finished kilmat installation in the drivers side foot well and adjusted the clutch pedal to sit at the same height as the brake pedal, both of which are now approximately 2.5" above throttle pedal height. Unfortunately no pics here at work =(
Doug P Yorktown, Virginia 1962 C10 LBFS - in pieces currently 1967 C10 SBFS and a couple non-trucks |
07-17-2023, 12:16 PM | #4027 |
In 68 ? I highly doubt that . But it’s back together regardless.
07-17-2023, 04:27 PM | #4028 |
Well done Mark, it looks great ......... new old stock
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
07-17-2023, 05:25 PM | #4029 |
I'm not sure when part manufacturers started using powder coating but I do know it was invented in the 40's. Either way that looks great.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
07-17-2023, 06:17 PM | #4030 | |
Now the heater box looks bad . That will be this falls project should have done it when I painted the interior .
07-17-2023, 06:19 PM | #4031 |
Helps when the part is nice to begin with . Thanks for the compliment
07-17-2023, 07:41 PM | #4032 | |
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 MIKE
07-19-2023, 08:05 PM | #4033 |
Got the lighter working . I ended up buying a complete cigar lighter at Autozone it fit the bezel perfectly and had regular flat male connectors so it was easy enough to wire it up . And the chrome socket looks right at home in the truck
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 07-20-2023 at 09:21 AM. Reason: Stupid autocorrect |
07-19-2023, 10:16 PM | #4034 |
Decided to put the inner front wheel wells back on. I drove this truck for years with out them. It was easier to work around the engine compartment with out them being in the way. Plus we raced this truck and it made the truck a little lighter plus the help of other parts we took off. Every thing missing is going back on. Racing is over for me.
07-19-2023, 10:26 PM | #4035 |
Who Changed This?
Looked at prices at a couple of vendors for a replacement grill and some components. Big differences, as in hundreds of dollars for what seem to be similar products. Crazy. I really wish my FiL hadn't butchered the original grill.
07-20-2023, 10:41 AM | #4036 | |
07-20-2023, 01:05 PM | #4037 |
The rust would most likely be easier to fix than getting aftermarket inner aprons to fit right .
07-20-2023, 01:29 PM | #4038 |
These are the original GM inners and they were not fun to install. Getting all the holes to line up wasn't easy. We used Chineese inners on our 68 and they went right on. I antisapated (if that's how to spell it) the GM inners were going to be a snap. It took one complete day to install but no drill was used. Lots of putting screw drivers in the holes and lots of prying.
07-20-2023, 03:13 PM | #4039 | |
07-21-2023, 03:47 PM | #4040 |
Something every day or week . I used striping tape to get the hood lip white . Just wanted to make sure I liked it prior to painting . I posted it in my hood thread too
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 07-22-2023 at 06:27 PM. |
07-21-2023, 04:21 PM | #4041 |
Who Changed This?
^ I like it!
07-21-2023, 04:49 PM | #4042 |
Me too . Guess I’ll be painting next time I paint up some rims
07-22-2023, 12:21 PM | #4043 |
Making a new cab cover!
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!! |
07-22-2023, 10:29 PM | #4044 |
I intentionally drove off a curb I thought would be no problem and knocked my exhaust pipe loose. Guess what I'm doing tomorrow...
07-22-2023, 10:34 PM | #4045 |
That will keep the Sun out of the cab.
Home Depot sells this silver-mylar backed bubble wrap stuff by the roll. You could line that Cab Cap with the silver stuff and really keep your cab cool. Or cut out panels matching the windows and fix them on the inside. Auto parts stores sell accordian-folded sheets of the stuff pre-cut for the front windshield, but if you're parked in full sun all day, the angle shifts. The rolls are cheaper than the pre-cut shields. Long time Tucsonan here. We have the same problem.
07-23-2023, 12:56 AM | #4046 |
Getting close to being done with the A/C install. Did a leak test and it passed. Next step is to put in the refrigerant.
07-23-2023, 01:02 AM | #4047 | |
Did you always have a puke tank? I hadn't noticed before.
07-23-2023, 01:06 AM | #4048 | |
https://67-72chevytrucks.com/vboard/...d.php?t=607136 |
07-23-2023, 03:42 AM | #4049 | |
I probably need to put on longer bolts and a new gasket w/ RTV on the Thermostat housing, since I get a lot of green glycol residue there on top of the intake manifold. So the system is not ''closed'' enough. I did get a vapor lock up, after a shut down stop last Tuesday, in 112* heat outside, on a Tucson late afternoon. But the 350 started up on the 3rd or 4th try. Autometer mechanical temp gauge only indicated 180*.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 07-23-2023 at 03:52 AM. |
07-23-2023, 09:49 AM | #4050 |
