08-08-2023, 05:12 PM | #4101 | |
Re: What did you do to your truck today.The 3rd chapter
The dual Bow Ties was too much.
08-08-2023, 06:18 PM | #4102 |
Who Changed This?
Thanks, yeah I never liked that look! Should have done it when the parts cost less. But then I didn't have the money.
08-08-2023, 06:36 PM | #4103 | |
08-08-2023, 07:40 PM | #4104 | |
The Older Generation
Thanks Steven, I got lucky for sure. Grille looks GREAT! LockDoc
08-08-2023, 07:52 PM | #4105 |
Who Changed This?
Thanks! I don't do much mechanic work any more, and I got so many cuts doing this replacement that I just can't believe it. I do woodworking and keep away from the blade(s)- don't get calluses from them.
08-09-2023, 12:22 AM | #4106 | |
It raised it's ugly head again so I removed the bullet connectors and replaced with a waterproof sealed connector like used on todays new cars. It solved the problem for about a day and was back. Now I'm about ready for the rubber truck. I decided it must be another problem so I started checking voltage to the O.D. controller and was getting erratic readings of 2 volts or less and if I wiggled the wire(s) I could get 12 volts. Long story short, the main 12 volt supply wire was a very fine 10 gauge multi strand that I had put shrink tube on the connector eyes, but still had corrosion on both ends and evidently as I was wiggling and sorting wires it would make the connection to make me think the problem was solved. Ran a whole new power wire and it has 12.7 volts both ends. |
08-09-2023, 03:54 PM | #4107 |
Is that a factory grill you took out of your truck? I have never seen one of those before.
08-09-2023, 04:23 PM | #4108 |
Who Changed This?
That is a '71-'72 grille that my father in law butchered to install the park lamps/turn signals. Weird, yes? I guess 30+ years ago when he put it in, it probably looked better.
08-09-2023, 05:44 PM | #4109 |
Finally finished up the inside rewiring and the new (cheap) gauge bezel install.
08-09-2023, 06:34 PM | #4110 | |
3-3/8'' Tach [Autometer], then from lower left, digital Voltmeter, mech Water Temp, mech Vacuum Gauge, mech Oil Pressure Gauge. Autometer mechanical gauges. I might move the Wiper Switch over to Left, above Headlights. I already have a Manual Choke on right. I could add a Mechanical Hand Throttle above it, but connecting to the Accelerator linkage is a puzzle. That way the controls would mirror my '68 C/10's set up, and I wouldn't pull off the Wiper Knob trying to pull the Lights on w/o looking, again.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 08-09-2023 at 06:42 PM. |
08-10-2023, 01:36 AM | #4111 |
Beautiful
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-11-2023, 06:27 PM | #4112 |
Hopefully getting closer to figuring out my uneven front side..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
08-12-2023, 07:39 PM | #4113 |
Mr. Cheyenne
Tried to install Cab/Radiator Mounts, first off it is freaking HOT but I am about 1/2 done.
I started with the driver's side, since the radiator lower rubber was completely gone. My 1st challenge was that I am lucky to have the tack wield in the cab floor's forward bolt head. After what seemed like forever using my Dremel tool, I got it out! After that installing the forward & rear new rubber mounts was a snap. But didn't tighten things down as I needed to do the radiator's rubber mount. The nut for the radiator's bolt would not move - ugh. I soaked the nut/bolt with liquid wrench & Free-All - no help. Then I got my hobby torch out and heated up the nut/bolt to a zillion degrees - that got me going! I spent more time on the radiator rubber mount than I did on the cab mounts (including Dremel'ing). Next challenge is that I didn't get any sleeves for the front mount from GMC Pauls. On top of that I had extra (smaller) rubber mounts in cab mount bag. The whole parts fulfillment has me sooooo confused. The extra mounts I got with the cab bag had 4 smaller mounts, two washers, 2 nuts, and shorter sleeves (no bolts). So I used one of those shorter sleeves for my radiator rubber mount but I think it is to short as the lower rubber mount looks smushed. Not really happy with GMC Paul's right now - plus I ordered these last Saturday and didn't get them until today (that I believe was USPS fault). Nothing like working on your truck on the weekend LOL
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
08-12-2023, 07:57 PM | #4114 |
Finally finished buttoning up my brake lines. Clamping that stuff with the crossmember right in my teeth wasn't fun, but at least it was cool in the shade under the truck
08-13-2023, 12:09 PM | #4115 |
Mr. Cheyenne
Finished the passenger's cushion mounts, toque everything down and test drove. Cab and front end stayed on the frame - so job done. Drove great - hope that holds ;-)
Though it was stressful with a bad fulfillment of parts from GMC Paul's - the parts bag had a 4wd radiator cushions included and the 2wd radiator cushion didn't have sleeves included (luckily 2wd & 4wd sleeves are the same or I'd been fu*ked).
08-15-2023, 06:43 PM | #4116 |
Mr. Cheyenne
I bought a '72 Cheyenne Super glove box and stole its wood grain appliqué and emblem to move to my truck's glove box.
I am being naughty and up sizing my Cheyenne to Super. I have "Super" fender emblems too but that will take a bit since fenders will need to come off. My tailgate handle has been chrome for some time and I am dealing with my crapo wood grain bezel sticker next. I also have on a the way a new SPID from outintheshop.com (Jeff/chipflyer) that will re-brand my truck as Super, along with other factory type bits I have added...
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 08-15-2023 at 08:37 PM. |
08-15-2023, 07:09 PM | #4117 |
Took the 71 out for it's first spin with the new 700R4 installed. What a big difference. 75 mph at 2200 rpm nice driver on the highway now. just need some AC.
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2015 Chevy Tahoe LTZ 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 |
08-15-2023, 07:57 PM | #4118 | |
Again Truck looks nice. |
08-15-2023, 08:11 PM | #4119 | |
Mr. Cheyenne
It is one upgrade I'd love to do but then I'll have to switch my rear end gears too from the 3.07s - to much stuff to change for me LOL
08-15-2023, 09:39 PM | #4120 | |
08-16-2023, 08:40 PM | #4121 |
70+ ( Old Skool Club )
Painted a chrome glove box door with wrinkle paint last week and today installed the new spid made by Jeff from " Out in the Shop" with the upgrades I added to the truck. Next up get it on the truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-16-2023, 08:46 PM | #4122 | |
Mr. Cheyenne
I am feeling less guilty having Jeff do the same for me, I am hoping he ships soon. I have my old SPID off (intact too) and all the glue off the door. I'm keeping the old one for proper records of the truck. I have to say I am stressing about getting the label on right, so I ordered a 2nd one for a extra $10 LOL
08-16-2023, 11:18 PM | #4123 | |
08-17-2023, 08:04 AM | #4124 | |
Mr. Cheyenne
Thanks for the squeegy tip!
08-17-2023, 06:37 PM | #4125 |
Worked on my first vent window rebuild
