08-18-2023, 01:09 AM | #4126 |
Re: What did you do to your truck today.The 3rd chapter
I admire your courage and tenacity.
Pix?
08-18-2023, 04:23 PM | #4127 |
It’s going pretty well so far really. I’ve been just sneaking in a little time here and there where I can. I work in a machine & fabrication shop so I have access to a lot of tools the average shade tree mechanic may not. Even so, getting the rivets re squished nicely is not fun. I have messed up a couple and had to grind them back out and redo.
Brothers Trucks has a really nice youtube video showing the process of putting in new seals. I will say, if you want them “nice” like rechromed or powder coated or whatever you are far better off just letting someone do them for you. My truck isn’t super nice but not exactly patina either so I’m just giving the chrome a light scotchbrite and calling it good. Edit: if you are going to do this don’t forget the glass setting tape. It is not included in the precision vent window seal kit and you need it to put the glass back in the frame. |
08-18-2023, 11:36 PM | #4128 |
Fifty-something years ago, glaziers would use a thin sheet of porous rubbe, and wet it with regular motor oil. This dissolved the rubber and it got super tacky, then cured hard with the glass in the frame. I don't think you can get that stuff anymore. I replaced the regulator in my '71 Jimmy in 2006. A friendly glass shop -- they'd just replaced my windshield and trim surround -- let me use some silicone or urethane they had. Industrial stuff. Took 24 hours to harden. We taped the drivers side window and they said not to break the tape for a day. Turned out I was on location in Phoenix, summer of course, and it was at least 114*. I don't have A/C.
The vent windows were fine then. But a PO's sloppy rivet on the drivers side tells me my vent windows were not original. I kind of rely on winging the vents all the way out for forced air. Us Rednecks call it ''System 2-40.'' Roll down both windows and drive at least 40 MPH. Early this spring, the tension on the drivers side vent wing went slack. No spring tension al all.* Shaft may have broken, or retaining nut fallen off. Won't know till I pull it. A couple of years ago [pre-covid] I talked with a guy in the Northwest, who did pairs of vent windows for what I thought then was a lot. His price is double that now. OER vent window sets are spendy now too. *For now, Iuse a bunji cord to wing the vent out. Hassle when I have to lock the truck.
08-20-2023, 06:45 PM | #4129 |
70+ ( Old Skool Club )
Not today really but will be soon. I received my new battery cables from Roger Koop and they are top notch as Rogers stuff usually is. It's just time to replace the 51 year old factory battery cables, especially the negative one.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-22-2023, 04:36 PM | #4130 |
New plug wires.
Filled radiator. 5 gallons of new gas in the relined tank. Cranked for 30 seconds. Pumped go fast pedal. Cranked for another 10 seconds, she fired up and ran. Had a gas line, carb/filter leak. Fixed that. Fired right back up again. 1st time I've heard it run in over 7 years. Im giddier than a skool girl(big grin)...Don. |
08-22-2023, 04:40 PM | #4131 |
Mr. Cheyenne
nicely done, congratulations!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
08-22-2023, 05:26 PM | #4132 |
About 10 hours in wet sanding off the hard as nails black spray paint. Nothing would touch it without ruining the original orange under it. Super thin, previous spot paint repairs, scratches, faded to bare in some spots, but going to finish and coat in Sweet Patina. Labor of love or madness, but it’s getting closer! Had the rally wheels blasted and then painted with the Duplicolor Ceramic Engine paint with the van centers. C10 Intervention show in a couple of weeks so have to get it finished this weekend!
1971 Custom/10 - 350/3 speed, Orange/White roof |
08-22-2023, 05:38 PM | #4133 | |
Took my wheels over to Les Schwab for dynamic balancing. Currently, the wheels only have weights on the inside lip. |
08-22-2023, 05:41 PM | #4134 | |
Enjoy your C10 Intervention |
08-22-2023, 06:16 PM | #4135 |
Bluetooth wheels! Agreed on the color, for some reason the Light Orange has always been my favorite! I had to have Americas Tire move mine to stick on weights due to the drop spindles. Even with the lip on the lower control arm ground back they still rubbed with the outer-lip mounted ones.
08-22-2023, 06:18 PM | #4136 |
Thanks man, lots of duct tape on the fingers but still lost a lot of skin🤣! She isn’t perfect, but I am liking the results. Even my wife said she can finally see my vision in removing the black, so I must be succeeding.
08-22-2023, 06:18 PM | #4137 |
Flushed the old brake fluid it was really contaminated with water . Ordered new shoes and dropped off the drums to be turned. Found an old time garage near me that has the drum disc lathe
This is just from the front used almost a quart before it ran clean
08-22-2023, 08:24 PM | #4138 |
New technology! Stereo with bluetooth from Classic Car Stereos - "Slidebar" radio, dash "stereo" speakers and underseat subs/tweets.
Also attended the "Classic All Chevy" '55-'72 car show on Sunday
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
08-22-2023, 09:35 PM | #4139 |
I finally did the manual to power steering conversion. I'm in love again only problem she is a 68 model and I could go for something older that has matured. The 68 is named Jim Boy after a boy named Jim on a farm across the road. Now that I'm in love again I'll have to change it's name to a female calling. I think Beulah fits the bill, which is Jim Boy's mother's name. Jim Boy is his real name, quite the family. Have a good one eh! Ron
08-22-2023, 10:55 PM | #4140 |
Who Changed This?
Nice looking truck! I wish my truck was blue instead of orange...
08-23-2023, 06:13 PM | #4141 | |
08-23-2023, 07:29 PM | #4142 |
Decided to replace all the wheel cylinders rubber hoses and shoes . Found one rear wheel cylinder leaking so the others were on their way out . My next project is to get an ibeam and remove the post it’s always in the way
08-23-2023, 10:17 PM | #4143 |
Location: Herculaneum MO (20 minutes south of St. Louis
Me too, I think they are the best.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
08-24-2023, 10:44 PM | #4144 | |
Then I realized this was a C/10 Fleetside, not the C/20 long Stepside. Good luck on removing the roof support.
08-25-2023, 02:22 AM | #4145 |
I thought the exact same thing for a moment!
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
08-25-2023, 08:45 AM | #4146 | |
I got two
08-25-2023, 08:03 PM | #4147 |
New B&M transmission vacuum modulator (TH350). What a difference from my stock, 51 year old unit. I had been shifting from 1>2 at about 30mph, now it's just under 20mph, under normal driving. I bet I'll see a tick up in MPG! LOL
Now Gettin'r ready for Sunday's ALL C-10 Truck Show in Issaquah, WA
08-28-2023, 04:56 PM | #4148 |
Mr. Cheyenne
Got in my new "custom" SPID from Jeff Lampe at the Out in the Shop today. I f**k up the first one, which I knew I would do one way or the other, so I am glad I was smart enough to have ordered two.
Jeff Lampe does fabulous work - I don't think there is anywhere else you can get a SPID that looks this close to original
08-28-2023, 05:46 PM | #4149 |
Hopefully fixed the leak in the speedometer gear housing, cleaned up the PCV valve as a precautionary move, and looked for my oil leak up front. Looks like timing chain cover and if I go in that deep I guess a new gear/chain set would be in order along with water pump on this old engine. Might go ahead and get the correct set of pulleys for power steering install.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
08-28-2023, 06:45 PM | #4150 | |
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
