Old 09-05-2023, 09:36 PM   #4176
body bolt
Re: What did you do to your truck today.The 3rd chapter
Love New Mexico trucks
We sure do!
body bolt is offline   Reply With Quote
Old 09-10-2023, 08:14 PM   #4177
K10-Kansas
K10-Kansas's Avatar
Not today but recently, put in all new drum brake components
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350 and 700r4. ~ James
K10-Kansas is offline   Reply With Quote
Old 09-10-2023, 09:31 PM   #4178
Extended Power
Extended Power's Avatar
Fuel, and coolant lines finished up.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 09-11-2023, 11:55 AM   #4179
OregonNed
OregonNed's Avatar
Wanted to get going on my list of projects, so I tucked up the front sway bar.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 09-11-2023, 06:56 PM   #4180
K10-Kansas
K10-Kansas's Avatar
Those are good looking.
Old 09-13-2023, 09:17 AM   #4181
1967GMCC20
1967GMCC20's Avatar
Reverse lights without cutting M/T harness
1967GMCC20 is offline   Reply With Quote
Old 09-13-2023, 03:28 PM   #4182
72c20customcamper
72c20customcamper's Avatar
New master on the 68 Golden . Everything is now new and she stops very well . I’m guessing the master cylinder the PO installed was the problem all along, stopped ok but the rears were not working correctly. I can now lock up all 4 in a panic stop . To shiny though for the truck
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 09-14-2023, 05:41 PM   #4183
weq92f
weq92f's Avatar
My Vintage Air 4 knob controller had its fan (off, lo, med, hi ) switch go loose last season...it would spin freely a quarter round before it "caught" and would click the switch. Well, just yesterday it let go completely and would just spin, not catch and actuate the 3 way switch.
Pulled it and found that each knob has a set screw. The fan knob's screw was backed all the way out! Easy fix and with a little loctite, it'll probably never happen again...
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 09-14-2023, 06:28 PM   #4184
OregonNed
OregonNed's Avatar
Truck is on jackstands, rear shocks removed, and will be doing the shock relocator kit this weekend
Old 09-14-2023, 09:14 PM   #4185
72c20customcamper
Fixed the trans detent on the 68 golden steering column . I couldn’t get the shift lever to pull back and it really didn’t like to go into gear or into park . Took it all apart it’s amazing how 55 year old grease turns into concrete . Had to clean everything with PB Blaster and a wire brush . Lubed it put it back together and now it works like it should .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-15-2023, 01:14 AM   #4186
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Replaced the 2 core radiator that was in the truck with a new 4 core from Summit. That plus a new thermostat & radiator cap, I should be running nice and cool now.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 09-15-2023, 03:42 AM   #4187
ghackett1
68 C10 Longbed
ghackett1's Avatar
Today I installed the tow hooks on my 68:
ghackett1 is offline   Reply With Quote
Old 09-15-2023, 09:13 PM   #4188
1967GMCC20
1967GMCC20's Avatar
Drove GMC 240 ish miles.. found a new barbque place in Carrollton, burned fuel at 12mpg $4.19/gal...dang.
The best sights are on US & State Routes...
Old 09-16-2023, 05:20 AM   #4189
ghackett1
68 C10 Longbed
ghackett1's Avatar
Today I installed black wrinkled finish early LT1 style valve covers on the 355.
Old 09-16-2023, 07:03 PM   #4190
'68OrangeSunshine
'68OrangeSunshine's Avatar
They look good.
'68OrangeSunshine is online now   Reply With Quote
Old 09-16-2023, 08:22 PM   #4191
chewychevy67
I am debating putting these on my 2wd 67. Can you post more pictures of your truck with these on please at different angles?
chewychevy67 is offline   Reply With Quote
Old 09-17-2023, 05:15 PM   #4192
ghackett1
68 C10 Longbed
ghackett1's Avatar
Originally Posted by '68OrangeSunshine View Post
They look good.
Thank You!
Old 09-17-2023, 05:16 PM   #4193
ghackett1
68 C10 Longbed
ghackett1's Avatar
Yes, I’ll get a few more pics tomorrow..
Old 09-17-2023, 05:42 PM   #4194
67C10Step
67C10Step's Avatar
Not necessarily to my truck but for my truck eventually. Buddy has a 68 frame that was bent in the front and he is taking all the useable parts off before he tosses it. I grabbed the auto transmission crossmember and the auto shifter linkage pedestal thing on the frame. Two more pieces down towards the manual to auto swap.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
67C10Step is offline   Reply With Quote
Old 09-18-2023, 01:07 PM   #4195
OregonNed
OregonNed's Avatar
Installed my shock relocation kit yesterday. A little tough dealing with the rivets from below, but it worked out great.
Old 09-18-2023, 02:18 PM   #4196
67C10Step
67C10Step's Avatar
Used that same kit on my truck, but I was fortunate in the bed was off when I did it. Have put almost 2,000 miles on the truck in the last 18 months.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2020 Toyota CH-R
2020 Acura MDX
Old 09-18-2023, 06:52 PM   #4197
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I didn't do anything significant to the truck but drove it the long way home after work yesterday morning. Beautiful sunny Sunday morning with very minimal traffic about at 7:00AM so perfect day for a 75 mile drive out of the City and cross country to loop back another way. Truck was down for 18 months and our drivng season here is quickly coming to and end so been driving it as much as I can since back on the road in June.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 09-18-2023, 10:51 PM   #4198
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yeah, just drove mine to a store. Need to keep the juices swirling around, right?
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 09-19-2023, 02:31 PM   #4199
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Finished the engine bay, the battery proved a challenge to buy.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-19-2023, 07:35 PM   #4200
72c20customcamper
Very nice work
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
