06-17-2007, 01:08 AM | #401 |
Re: Its the shortbed's turn "Project Junkyard Resurrection"
Today I got the headers on...other then that the chassis just sat outside while I cleaned the shop out.
06-17-2007, 03:23 PM | #402 |
Ok,it's only been a few months w/ out pics....but here is some new ones from the new camera
Enjoy...it's changed some.I will have more pics later.These give you some idea to what it looks like now and I had to throw in a motor pic The motor is almost ready to fire... Last edited by 1969k10stepside; 06-17-2007 at 03:24 PM. |
06-17-2007, 07:27 PM | #403 |
HOLY COW.... you do have a truck!
glad to see the progress, i'm about two weeks behind that (except I didn't rebuild my engine!) I say build a roll cage right now and mud bog it!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 06-17-2007 at 07:27 PM. |
06-17-2007, 07:39 PM | #404 |
A few weeks and the cab will be back on this and hopefully I can drive it around the yard some and in and out of the garage and shop.After the motor is running then the next goal is some new u joints on the driveshafts and a cv joint swap from one front driveshaft to the other,I had a complete front driveshaft from a 67-69 but they are shorter because of the transfer case and I only have part of one for this truck so 2 will become one.Then a trip to GMC Pauls for some cab parts,a little welding and cleaning on the cab,undercoat it,and bolt it on...sounds like a plan.Less than a month from the anniversery that I bought it a year ago...
06-17-2007, 11:35 PM | #405 |
GEARHEAD
on the new camera
Truck is progressing wonderfully. RJ22... |
06-18-2007, 07:26 PM | #406 |
Noobie McNoobster
Do you have any close up pics of the 205 skid plate. Just wondering how hard it would be to fabricate.
The Stable: 1968 Chevy K20 w/tilt, working AM/FM, AC and 350/350/205 w/Disk Brakes 1990 Chevy V2500 Suburban 2005 Kawi KLR650 1983 Honda Goldwing GL1100 Standard (Naked) 1995 Miata M Fortes Fortuna adiuvat Last edited by 68K20; 06-18-2007 at 07:28 PM. |
06-18-2007, 07:58 PM | #407 |
I don't have the skidplate on but do have a few pics.I have to drill some holes in the frame before I can mount it,here is the pics I have: I can get you some close up pics this week...
06-18-2007, 11:23 PM | #408 |
Tonight I drilled some holes and got the skidplate mounted.....tomorrow I am collapsing the intermediate shaft so the modified van tilt can go in when the cab is on
06-19-2007, 08:56 AM | #409 |
Aluminum slot wheels rule...
Dustin, could you post some pics of how well the headers fit, as far as clearences and stuff goes. I'd really, really appreciate it.
06-19-2007, 01:01 PM | #410 |
Jake,I posted some pics in the 4x4 Section...
I didnt get a pic of the cab but here is some pics of part of the rest of it.... This inner grill and a good outer grill I have will become one good grill...A FREE rust free core support is hiding behind it...And the other pic is of fenders,cowl,another grill,2 average condition tailgates and a extra swb drivers side bed panel and a hood all for the truck sitting in the "dark side" of the shop.That part isnt concreted BTW,why have part of it concreted when normally a rusty old truck sits in it,cept it was kicked out for parts storage.So if you can see anything in the pics,thats good ...I was going to get a pic of the bed for the truck but its outside and its raining... Last edited by 1969k10stepside; 06-19-2007 at 01:09 PM. |
06-24-2007, 12:06 AM | #411 |
While the rain poured and I swore I seen a funnel cloud...I stayed in the shop and got the oil pressure built up,installed water pump (second one,first one wasnt right),got the pulleys on,got the valve covers on,got the valves adjusted,got out the radiator and hooked it up,filled it up with water,put in the distributor,put in plugs,ran plug wires...tomorrow bolt on the quadra-junk and put the belt on the pulley system and hope it starts
06-24-2007, 06:32 PM | #412 |
The 71 K10 is alive...
Over the weekend I worked switching water pumps (had the wrong one the first time) and hooking up lines,hoses,electrical,adjusting everything it finally roared to life I was a bit worried as it didnt have any oil pressure according to the gauge but after pulling a complete gauge cluster out of the truck to hook up in the chassis I got a good reading on the pressure so I continued on.....This afternoon I went out to the shop and after fighting with a sluggish start due to a bad ground I finally got a good ground and pushed the button and it fired up...I had to pour a little gas in the old quadra-junk to get things going a little quicker but it wanted to start and it did.It sounded great,and the rest of the town probably agrees as they probably heard it considering it is just open headers I am pleased with it,it sounds good,the timing is right and it idles good.I wish the cam was a bit more lumpy but Im not going to tear back into it to swap cams.It didnt take long to burn the paint off the headers.... The paint lasted all of 5 minutes. So,maybe if I can get the video from the camera uploaded to youtube or somethin I can share the video with y'all...as for now Im going to go start it up and listen to the motor some more.. Last edited by 1969k10stepside; 06-24-2007 at 06:38 PM. |
06-24-2007, 06:37 PM | #413 |
06-24-2007, 07:43 PM | #414 |
sweet, need to see the vid too
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
06-26-2007, 04:39 PM | #415 |
Lookin' Good!!
06-26-2007, 05:29 PM | #416 |
do you think the oil pressure is high enough?
06-26-2007, 05:35 PM | #417 |
No,its just right....
06-26-2007, 06:00 PM | #418 |
Now to do mine someday. I may have to do a rig up too, instead of waiting for all the wiring and body stuff. I am getting very impatient.
06-26-2007, 10:39 PM | #419 |
Dustin, did you paint the engine? spraycan? which brand of chevy orange was it if so? I just realized that plasti-coat and dupli-color are waaaaaay different shades. One is a burnt orange and the other is very bright....
Any idea which is closer?
06-26-2007, 10:43 PM | #420 |
Yeah,I rattle can painted it.I got the paint from Napa.I forget the brand but still have the can so I can look tomorrow...The can was about $7 if I remember right..
This pic shows the color almost,the camera makes it look a little lighter than it actually is. Last edited by 1969k10stepside; 06-26-2007 at 10:44 PM. |
06-26-2007, 10:50 PM | #421 |
I just painted mine tonight, forgot the camera though.... Yours looks more like the burnt orange.... I think mine glows in the dark I did the tranny and TC in red (kinda original). I was going to do the black after seeing yours, that should help hide the gunk as it builds up...
06-26-2007, 10:54 PM | #422 |
I was gonna paint the t-case the original color till I found out it was a mopar color and didnt want any mopar colors on it so I just painted it black...I was going to pull the aluminum covers and paint them silver but I didnt..The tranny was just a plain aluminum tranny so I painted it to match the t-case
06-26-2007, 10:57 PM | #423 |
I did chrysler red since it was the only engine red paint that looked good. I also painted my performer intake orange since the protective coating was long gone.
06-27-2007, 09:26 AM | #424 |
I used the duplicolor chevy orange-red, it looks good. Not too reddish or orangish colored.
Where the engine vid?? I wanna watch it! |
06-29-2007, 07:37 PM | #425 |
And its coming back apart some...Took the wheels off and the springs will probably be back off by weekend..going to fix the lift kit,there is several inches of difference front from rear and its not gonna stay like that!
