Old 12-21-2009, 01:16 AM   #401
Puropedo
Re: Ackattack's Pro touring restoration thread
Really, really sweet built...Im gonna have to make some time to go over the whole thing, are those sanderson headers you are using? Do they hang below the frame? Are you using the "truck" oil pan?
Puropedo is offline   Reply With Quote
Old 12-21-2009, 10:43 AM   #402
Ackattack
Ackattack's Avatar
The headers are stainless steel headers for a LS1 4th gen F-body. I got them off of ebay. They don't advertise a brand name on there. But you can find them by doing a search.
They don't hang below the frame (though my ball-flange collectors do ~1 in)
I'm using an F-body pan. The truck pan was too low.
Ackattack is offline   Reply With Quote
Old 12-21-2009, 11:26 AM   #403
Dahawk
Originally Posted by Ackattack View Post
Well I got the axles installed with the brake rotors....I used the Summit drilled and slotted ones. I did not have to have them machined like I thought I was going to have to.
Then I put the wheels on it to finally make it a roller!
that lasted for about 10 min...no longer a roller
I tore the front suspension back apart to replace the crappy ball joints. I went to put in the new moog ball joint and now the hole in the lower control arm is too big!!!! So now i don't know what I'm going to do. Probably pull a lower control arm off the parts truck...damn it...I had sand blasting!
What set up did you use for the rear brake set up. Everything please
Dahawk is offline   Reply With Quote
Old 12-21-2009, 12:48 PM   #404
Ackattack
Ackattack's Avatar
-LT1 F-body calipers and "hat bracket" (not sure what it's called)
-12 bolt rear disk caliper brackets from board member that goes by glock something
-rear disk rotors from a 94-96 Impala SS (these ones are summit drilled and slotted)
-Hawk HPS pads
Old 01-26-2010, 05:49 AM   #405
lewisaric
lewisaric's Avatar
Wow!!! I just read all 17 pages of your build. Very nice. I`m about to start on my 68 short step. I found a 5.3/4l60e out of a wrecked 05 silverado with 28000 on it. I think reading your build will help me out alot. So I may have some questions. I want to do all of my own body work, which will be a first for me, but I`m going to take my time a pay attention to detail. My biggest concern is going to be shaving my drip rail. But enough with my rant. I really like what you have done here and hope it gets finishrd soon.
lewisaric is offline   Reply With Quote
Old 01-26-2010, 10:35 AM   #406
Ackattack
Ackattack's Avatar
things have been progressing very slowly
I got the steering column and shifter installed, a few other little things finished up, and got the brakes all plumbed. I'm haveing a problem with the brakes though.
I have the rearend up on jackstands, so it won't go anywhere. I start up the engine, put it in gear, and I can hardly get the back tires to stop....holding the brake pedal in with all of my might. I bleed the whole brake system, checked for leaks, fixed some leaks, blead it again. I bench blead the MC before I installed it. The only thing that I can see now is it looks like the stainless steel braided hose in the back that goes between the frame and axle looks to be pinched. (I believe caused by when it's lowered). So I'm going replace that and re-route it slightly so it doesn't pinch. Hopefully that will fix the brake issue.
I also need to get a few things. I'm missing the rubber o-ring on my power steering line (corvette power steering pump).
Old 01-27-2010, 01:52 PM   #407
lippsgarage
lippsgarage's Avatar
Do you have a seperate proportioning valve, or is it built in to the mc? My 79 rears wouldn't work and it ended up being a bad valve. Great built...waiting to dig mine out of the snow and get started on it again
1979 Chevy C-10
1994 Olds Bravada
Nissan Skyline GTR, Saleen S7, and 67 Shelby 350 Fastback (all on a traxxas 4-tec rc, don't laugh, it'll break 60mph!!!)
lippsgarage is offline   Reply With Quote
Old 01-28-2010, 12:57 AM   #408
Ackattack
Ackattack's Avatar
I have a seperate proportioning valve. It's a disk/disk setup from CPP. I considered that maybe that was the problem.....I'm gonna replace the kinked line and go from there.
Old 02-14-2010, 08:57 PM   #409
Ackattack
Ackattack's Avatar
It moves!!!!!! I "drove" my truck for the first time today!!!!
I finally got the brakes ironed out, so I moved it out of the garage so I could do some cleaning, turned the truck around, then put it back in the garage, but hey, it moved, stopped, and turned under its own power. Seems like no big deal, but after over 2-1/2 years of work it is a big deal to me.
Old 02-14-2010, 09:00 PM   #410
menace121978
menace121978's Avatar
right on man! i can only imagine
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 02-14-2010, 09:56 PM   #411
Thealien
Thealien's Avatar
congradulations!!
Old 02-14-2010, 10:30 PM   #412
VA72C10
VA72C10
VA72C10's Avatar
congrats....can't wait for that myself. It's been 2 yrs since I drove mine....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-14-2010, 10:39 PM   #413
Frizzle Fry
Frizzle Fry's Avatar
Congrats! What was up with the brakes?
Frizzle Fry is offline   Reply With Quote
Old 02-14-2010, 10:49 PM   #414
mcbassin
Still Learning
mcbassin's Avatar
Glad to hear you got to drive it for the first time.
mcbassin is offline   Reply With Quote
Old 02-14-2010, 11:18 PM   #415
Ackattack
Ackattack's Avatar
So I think the "problem" may have been the slight mis-alignment that was fixed with some washers, and then the pads not being broken in like what would be ideally (since I can't exactly drive it down the road to really get them broken in.
Old 02-15-2010, 10:47 AM   #416
lyrikz
PITbut
lyrikz's Avatar
Man, its like i made this post. This saturday i drove mine around the block for the first time. My booster was bad so i had no power brakes. ahah
2.5 years also, i know the exact feeling. Congrats man.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 02-15-2010, 11:55 AM   #417
eagleuh1
eagleuh1's Avatar
Congrats on the movement under own power. Must feel real good. But we can't celebrate till we see the VIDEo!
eagleuh1 is offline   Reply With Quote
Old 02-15-2010, 12:10 PM   #418
68 TT
Still plays with trucks
68 TT's Avatar
Good to see you got it moving and stopping. What's next?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-15-2010, 12:34 PM   #419
Ackattack
Ackattack's Avatar
(in no particular order)
install the front sway bar
figure out the ride height and have it aligned
have the windshield installed
have a title inspection done
wiring (lights and some interior wiring)
clean up underhood wiring a little
front bumper
trim on the grill
interior
stereo
Old 02-15-2010, 10:00 PM   #420
w4625
Congrats on getting the truck running...do you have pics of the fuel filler install in the stake pocket?
w4625 is offline   Reply With Quote
Old 02-16-2010, 12:41 AM   #421
Puropedo
Congrats!....Do you have to do anything when you reprogam your PCM for the PRN321 neutral transmission switch to work properly?
Old 02-19-2010, 04:13 PM   #422
Ackattack
Ackattack's Avatar
Nope
My neutral safety switch is on the steering column, and that goes to a stand alone relay, then to the starter.
Old 02-22-2010, 07:08 PM   #423
Ackattack
Ackattack's Avatar
Got some more work done.
I got the headlights all wired up (except for ground wires....ran out of black wire), then I got the head light switch, dimmer switch, neutral safety switch, reverse switch wired.
I also have appointments set up to get it aligned and the windshield installed on Friday. I'll also get it registered. Insurance will be covered by friday.
If I can get some good work done to get a little more wiring done, get the lights installed, and get the front bumper installed, I think I'll be able to drive it!
Old 02-22-2010, 07:13 PM   #424
Normy71
Looking Good !!
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 02-23-2010, 12:21 AM   #425
Puropedo
Great progress! Dont forget to take more pics of your ride and show them to us, I have a few questions...Do you mind telling me how much did the HP tuner software cost you? Also is it pretty user friendly to use? Do you have to buy credits every time you reprogram a different PCM? Thanks in advance.
