Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-13-2010, 10:34 PM   #401
tiggamonsta
tiggamonsta's Avatar
Re: Project - '69 4x4 named "Patches"
Originally Posted by sdailey View Post
...I had I came up with the "Low Budget Drill Press". I was always taught to adapt and overcome...
...The two options that I have for mounting it are (1) having an aluminum "faceplate" machined to mount in the factory opening, similar to the piece that member "Mekdad" made for the radio location...
or (2) weld up the opening all together and cut a hole just big enough for the control to mount into...
I just saw that same tip on a show this weekend. I was thinking, why have I been killing myself all these years. It is amazing how the simplest things make are lives so much easier.
I vote weld up the space and cut it in.
tiggamonsta is offline   Reply With Quote
Old 04-14-2010, 09:17 AM   #402
sdailey
The Few, The Proud
sdailey's Avatar
Originally Posted by 4dranch View Post
Nice work Shannon on the AC controls relly looks slick,
And I agree with Dennis on the drill press, That's using your head.
Thanks David. As I'm getting older I'm really starting to figure out this "work smarter not harder" thing I've heard about from old timers over the years.
I knew that I couldn't be the only one that had the idea of using a floor jack that way.
Yeah, I'm pretty much sold on welding up the opening and cutting it to fit the control as well. Thanks for your input.
Shannon
sdailey is offline   Reply With Quote
Old 04-14-2010, 08:46 PM   #403
msgross
msgross's Avatar
Put the new radio in the old A/C control area, and mount the new A/C controls in the ashtray or radio delete area...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-18-2010, 07:44 PM   #404
sdailey
The Few, The Proud
sdailey's Avatar
I fired up the low budget drill press again this weekend and drilled the last holes needed to finish mounting the fuel tank, so at least that's checked off the list now. I still haven't decided whether to paint it or have it powdercoated or just leave it natural.
It looks like I'll be buying a new hood since the one I have seems to have been damaged when I had it sandblasted. Alan and I both looked it over before it was blasted and there wasn't anything wrong with it other than the small dents on the front of it. When I picked up the hood from the blaster it looked good. That was until we primed it. Once it was primed you could see (2) distinct ridges the entire length of the hood. Look at the picture below to see if you can spot them. I'll give you a hint, look at the area where the hood braces run.
Alan thinks it would be easier and less time consuming to find a new hood compared to working the metal on this one.
Luckily, I found a "new" hood fairly close to home. I'll be sure to take the time to sand this one by hand instead of having it blasted. Lesson learned.
I also mocked up LFD's 71-72 gas pedal conversion (for 67-70 trucks) and it fit like a glove.
http://67-72chevytrucks.com/vboard/s...d.php?t=371099
I then disassembled everything and gave it a shiny coat of paint.
Here's the bracket painted and temporarily installed for a quick picture.
Fully installed with a "modified" '72 pedal assembly.
I took it all apart, boxed it up and put it back in the parts pile for later.
Not much else going on this weekend.
Shannon
Old 04-18-2010, 09:37 PM   #405
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Nice progress. Looks great!!
Alan's Classic is offline   Reply With Quote
Old 04-18-2010, 09:42 PM   #406
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Everything looks great, and that sucks about the hood.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 04-18-2010, 10:12 PM   #407
Conroe trucker
SWBs: 67 2x4, 67 4x4, 70 4x4
I am going to Raptor my tank.
It is almost the same as yours, and although it looks good now, it is going to look like crap soon, so I am going to coat it and go down the road.
I also had some warping in my hood from blasting, although not that much.
They make a seam sealer/glue for cars that you can use to glue the hood support to the hood.
We did that and it is hell for stout now, especially after we Raptored the bottom.
Don't trash that hood, it can be saved.
FINISHED Project thread: 67 SWB 4x4
FINISHED Project thread: 67 SWB 6 cyl cruiser
Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT
01 C5 convertable
08 Z06
Conroe trucker is offline   Reply With Quote
Old 04-19-2010, 07:55 AM   #408
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good shannon......
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 04-19-2010, 07:58 AM   #409
msgross
msgross's Avatar
maybe i'll go that route since I plan on using Raptor for my cab, hood and fender undersides... post some pics when you finish.
The Garage:
Old 04-19-2010, 08:08 AM   #410
sdailey
The Few, The Proud
sdailey's Avatar
Thanks Alan.
Thanks. We had talked about drilling out the spot welds on the hood braces and taking them out so they wouldn't be in the way when the hood got blasted, but for some reason I decided to leave them in. Good ole hindsight...
I forgot about Line-X, Lizard Skin, Raptor and those kind of products. That may be the route I take with this tank. Thanks for the reminder.
Do you have any opinions on how to fix the hood? There are (2) ridges that run the entire length of the hood where the braces are located. Do you just hammer them back down?
Shannon
Old 04-20-2010, 11:45 AM   #411
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Just read your build thread yesterday and finished it just now. Your truck is going to be very nice. I really like it allot. I like that you are going with green. It reminds me of my grandparents 69 Firebird convertible. It had green interior too.
The hood. I am just guessing but I am thinking the hood stretched around the braces and hammering them would not do it. But, I am just guessing. I have no body experience. It's just a thought. Thinking how blasting works and metal heating up and maybe creating a crater affect around the braces.
Keep up the good work and pics!
LOW DOUGH is offline   Reply With Quote
Old 04-20-2010, 12:15 PM   #412
sdailey
The Few, The Proud
sdailey's Avatar
Thanks Drew. Like you, I have no bodywork experience either. What happened to the hood is just like said. The combination of the blasting process and the rigidity of the hood braces formed (2) nice ridges. Out of curiousity though I'd like to know how to fix the hood. I guess you could remove the braces and hammer the ridges back down. I guess it doesn't really matter at this point though because I have another hood lined up already.
Shannon
Old 04-20-2010, 12:17 PM   #413
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
I guess that could be done. But hay, another good hood would be much easier.
Old 04-20-2010, 01:18 PM   #414
sdailey
The Few, The Proud
sdailey's Avatar
Shannon
Old 04-20-2010, 03:01 PM   #415
4dranch
Shloooooong bed member #2
4dranch's Avatar
Nice work Shannon and sorry to hear about the hood.
You really need to name your drill press instead of "budget drill press"
That way I can look for it at the hdwr stores.
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 04-20-2010, 03:59 PM   #416
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
you would be looking for the drill press attachment for your floor jack.
Old 04-20-2010, 05:10 PM   #417
sdailey
The Few, The Proud
sdailey's Avatar
David you know how it goes, one step forward, twp steps back.
How about "The Hydraulic Arm Saver"?
Shannon
Old 04-30-2010, 08:37 AM   #418
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Catching up on many of the builds on the site. Another very nice build! Look forward to seeing the progress.
propanemudtruck is offline   Reply With Quote
Old 04-30-2010, 05:12 PM   #419
sdailey
The Few, The Proud
sdailey's Avatar
Thanks. You and me both.
Shannon
Old 05-19-2010, 10:07 AM   #420
my67chevytruck
Under Construction
Hmmmm, 19 days and no updates..... SLACKER !
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 05-19-2010, 11:01 AM   #421
sdailey
The Few, The Proud
sdailey's Avatar
Yep! You hit the nail on the head. I've been in a bad funk lately. Between having my hours cut back at work due to the economy, yard work/honey-do list, and sinus issues lately I haven't struck a lick. Such is life I know blah, blah, blah...
On a positive note though, Alan and I talked last night about starting on my cab soon. Hopefully, by the weekend we can get the cab in his shop and get to work on it.
I'll be sure to post pictures if that happens.
Thanks for proding me along.
Shannon
Old 05-19-2010, 12:07 PM   #422
my67chevytruck
Under Construction
Shannon, thats awesome. Looking forward to the progress. I finally got the bonded title and most of the cab patches for my K10, I need to button up my son's '67 but hopefully can start on the k10 soon.
Keep your head up above the FUNK, you can breathe easier
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 05-23-2010, 06:52 PM   #423
sdailey
The Few, The Proud
sdailey's Avatar
Well it happened, we got my cab back over to Alan's shop this weekend. The plan is to build a cab dolly out of wood to sit my cab on to make it easier and safer to work on, so I picked up some lumber today for that.
Stay tuned. Sparks should start flying pretty soon.
Here's a picture to prove that I actually did touch it this weekend.
Shannon
Old 05-23-2010, 06:54 PM   #424
msgross
msgross's Avatar
more than I did...
The Garage:
Old 05-24-2010, 07:38 AM   #425
my67chevytruck
Under Construction
Heading in the right direction now Shannon!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
