Old 01-30-2010, 04:39 PM   #401
G-Ring
G-Ring's Avatar
Re: Project NOT4SLE
Any word on tie rods? AutoZone has a set but they are Duralasts. Did you call Tuckers or that other place...Premier I think.
79' Big Ten
70' 1 ton 4x4 LB "Mean Green"
70' SWB "Major Project"
69' El Camino "t-boned by Camry"
G-Ring is offline   Reply With Quote
Old 01-30-2010, 07:33 PM   #402
highperf4x4
Re: Project NOT4SLE
Originally Posted by 70stroker View Post
highperf he also said hes raising the rear up about a inch.. it oughta be enough after that.
Yeah maybe so. I'll keep my fingers crossed!
highperf4x4 is offline   Reply With Quote
Old 01-30-2010, 07:37 PM   #403
vegaschevy
Re: Project NOT4SLE
Carquest stocks all Moog Tie rods. Their "house" brand is all Moog stuff, not cause some moron told you but because it also says on the box.
Anyways I returned my Moog stuff to Checkers, found some in stock at Carquest and got them.
Got home and got back to work on the truck... and guess what she is done!!! Well, for now... back on the road. Wont be driven until Monday after an alignment though.
Well I could blab and blab but you all want to see pics. Im waiting on Nate from Porterbuilt to get me my other piece I need to raise the rear an inch. Hopefully he comes through soon. I need that inch.
The rear seems way more "unlevel" then it is as the upper white/blue line slopes downhill compared to the body lines....
Well here you go
All steering cross shafts, and ball joints are Moog
vegaschevy is offline   Reply With Quote
Old 01-30-2010, 08:31 PM   #404
butternut1972
butternut1972's Avatar
Re: Project NOT4SLE
Looks good. I think it could a touch lower in the front, Just my .02. wheels look really good.
butternut1972 is offline   Reply With Quote
Old 01-30-2010, 08:40 PM   #405
Normy71
Re: Project NOT4SLE
Looks Good
Just wondering about your tie rod connections to the center link, should they not be on the back side of the center link? not the front? or are my eyes playing tricks on me?
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 01-30-2010, 09:12 PM   #406
ripdog28
ripdog28's Avatar
Re: Project NOT4SLE
If you were rolling through South Central LA that stance would be sick. But your not their so FIX IT!!!!!!!!!!!!!!
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 01-30-2010, 10:16 PM   #407
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project NOT4SLE
Like Normy71 said,... the center link is on backwards. You need to swap it "end for end" so the inner tie rods will connect on the back side of the centerlink.
Member Mondo had this problem and it eventually broke the inner tie rod due to contact with the center link.
The ends of the centerlink should point forward, not backwards.
Otherwise looks killer.
Old 01-30-2010, 10:38 PM   #408
camokid
Re: Project NOT4SLE
looks good.....but I think it needs to drop in the front a little more or bring the back up a little...(.I like the lower in the front a little better)
Keep it up...
Jeff
camokid is offline   Reply With Quote
Old 01-30-2010, 10:41 PM   #409
70stroker
70stroker's Avatar
Re: Project NOT4SLE
ya do agree on the center link.
however i think jack the rear up a inch and maybe go a little lower on the front. But man those wheels look good.
Your for sure gonna need to get a exshaust setup on that now.
70stroker is offline   Reply With Quote
Old 01-30-2010, 10:49 PM   #410
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Project NOT4SLE
Lookin' good!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-30-2010, 11:07 PM   #411
CheyenneShop
CheyenneShop's Avatar
Re: Project NOT4SLE
Once you get that stance figured out - Watch Out
I wonder if just the 1" raise in the back is going to be enough???
It looks like you have a bit of room in the front to drop her some more. Do you? Keep us posted, maybe once you get your part from Nate it will be where you want her! Looking good.
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 01-30-2010, 11:09 PM   #412
highperf4x4
Re: Project NOT4SLE
I'm voting on "raising the rear" about 2" and PAINT THOSE DRUMS!
Did you hit that muffler coming off the driveway?
Old 01-31-2010, 01:45 AM   #413
vegaschevy
Re: Project NOT4SLE
Originally Posted by Normy71 View Post
Looks Good
I thought the same thing on the center link. but I really saw no way of anything fitting the other way around. The tie rods seemed to hit the crossmember when put the other way around.
I guess Ill have to look at it again
Ya, its a 4.5" drop in front which his what everyone does with this tire size. mine for some reason seems a tad high still.
the muffler was to put something on after doing the rear suspension as the muffler had to be cut off. So it works for now!!!
Old 01-31-2010, 01:56 AM   #414
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Project NOT4SLE
Yep, centerlink on backwards. Here is a pic of mine after the rebuild.
I found I had to rotate the centerlink side to side to fit the tie rods on and they are close but about a 1/4" away from the crossmember when centered. As you move left or right, the centerlink moves away from the crossmember. That is also why the inner tie rods have the grease fittings on the end and not the back like the outer ones.
Looking good!!!! I'll have to come by next time I'm in Vegas.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-31-2010, 02:14 AM   #415
vegaschevy
Re: Project NOT4SLE
Ill switch it around tomorrow. I tried and tried an it seemed like nothing was going on with it the other way around. I was certain it went this way. So I was like maybe it goes the other way and it mounted right up. Could not find any pics on the board when I looked...
Time to remove cotter keys and get it switched... lol
Old 02-01-2010, 12:07 AM   #416
CheyenneShop
Re: Project NOT4SLE
Vegas - I needed to load some concrete up into the 68' today & I thought of you!
72 3/4 long 4X4
69 SWB "Prospector"
Old 02-01-2010, 12:14 AM   #417
lolife99
lolife99's Avatar
Re: Project NOT4SLE
Man Cheyenne,...
is that '68 for sale?
Old 02-01-2010, 12:16 AM   #418
nuke1
nuke1's Avatar
Re: Project NOT4SLE
Looks killer , losve the new ride height.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-01-2010, 01:07 AM   #419
CheyenneShop
Re: Project NOT4SLE
Man Cheyenne,...
PM'd ya
72 3/4 long 4X4
69 SWB "Prospector"
Old 02-01-2010, 01:24 AM   #420
highperf4x4
Re: Project NOT4SLE
Vegas did you get the steering straightened out today?
Old 02-01-2010, 04:31 AM   #421
vegaschevy
Re: Project NOT4SLE
This made me crack up!!! HAHAHA
Old 02-01-2010, 04:41 AM   #422
vegaschevy
Re: Project NOT4SLE
no, I got out of work and went to breakfast that lasted till noon. sitting around like that all morning after working all night pretty much makes me ready for bed. LOL
Tomorrow I will fix the steering and I am also thinking about remving the front springs and removing about 3/4 of a coil back towards the end of the notch. Im not sure this will remove much height but maybe 3/4" maybe... anyone know?
hopefully I get my piece from Porter soon as it is I think I am rubbing to much to drive it.
unless anyone has some 4" drop springs they want to trade for 5" drop springs as i have 5" in there now
Old 02-01-2010, 08:46 AM   #423
lolife99
lolife99's Avatar
Re: Project NOT4SLE
1/2 COIL = 1" of drop.
I would start with 1/2 coil first.
Bolt it back together without shocks and set it on the ground.
Just make sure the top of the spring is in the spring pocket.
Let the bottom go wherever it goes.
Old 02-01-2010, 08:48 AM   #424
lolife99
lolife99's Avatar
Re: Project NOT4SLE
What exactly is rubbing?
Too much backspace on the wheels?
Do you have the 2" drop or 3" drop on your Porterbuilt trailing arms?
Old 02-01-2010, 11:57 AM   #425
vegaschevy
Re: Project NOT4SLE
All the arms as far as I know are identical. The difference in the drop comes with a spacer provided for on top of the coil for the 2" drop and 3" drop you just use the arms no spacer for the coil.
I currently have 3 extra" of drop along with a 5" drop spring. I need to be around 7"
With my tire combo it is perfectly centered in the wheel well however it will still touch both sides of the tub under load.
im going to cut just over 1/2 coil off today on the front to get it where I want it I hope and then ill raise the rear to get clearence
