Old 10-15-2011, 11:20 PM   #401
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: '72 Chevy SWB, Project Driver
Originally Posted by VA72C10 View Post
Nice work! That's one task I never want to deal with....
Thanks, Its not that bad......I may have cheated a little though. The window felt is just glued in
Originally Posted by oldblue1968chevy View Post
Faq?...
Like this: http://67-72chevytrucks.com/vboard/s...d.php?t=351471
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 10-17-2011, 10:03 PM   #402
usmcchevy
usmcchevy's Avatar
Drop spindles showed up today
Summit sent the wrong ones
Build thread
LSx Swap FAQ index
Old 10-17-2011, 10:20 PM   #403
VA72C10
VA72C10
VA72C10's Avatar
that stinks...I've heard they're fairly quick correcting stuff like that though....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-18-2011, 08:13 AM   #404
usmcchevy
usmcchevy's Avatar
Hopefully, they are going to be drop shipped from CPP.
Build thread
LSx Swap FAQ index
Old 10-18-2011, 10:56 AM   #405
gringoloco
A guy with a truck
gringoloco's Avatar
Are you using the updated version w/ narrowed track width?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-18-2011, 02:34 PM   #406
usmcchevy
usmcchevy's Avatar
Yes Sir! I have powder coated A arms, Moog ball joints+tie rods+shafts, new stock CPP springs with 1/2 coil cut, 1.25" sway bar and KYB Excell-G (GR-2) shocks here waiting
Build thread
LSx Swap FAQ index
Old 10-18-2011, 05:39 PM   #407
gringoloco
A guy with a truck
gringoloco's Avatar
Nice! Do you plan to do before/after track width comparisons? What's your current setup?
-Chris
Old 10-18-2011, 09:53 PM   #408
usmcchevy
usmcchevy's Avatar
I'll do my best. Current set up is stock coils with 1 and 1/2 coils removed and no alignment done....rides and steers like crap.
Build thread
LSx Swap FAQ index
Old 10-19-2011, 09:16 AM   #409
gringoloco
A guy with a truck
gringoloco's Avatar
You should see and feel a HUGE improvement
Maybe take a tape measure, if you're using the same wheels after, and measure the outer edge of the wheel in comparison to the fender lip. I'd love to see where you end up. Curious if these spindles perform as advertised, and you're the only one I know of who has (or is getting) them.
Good luck with the upgrades
-Chris
Old 11-04-2011, 08:52 AM   #410
usmcchevy
usmcchevy's Avatar
Slight update. I got the spindles from CPP, this set was cast with part number CP4S4 just like the first set I recieved (I need CP4S3). I called CPP and they use casting CP4S4 for all of the 60-87 trucks and just machine that casting differently for each year range with no markings other than the part number ON THE BOX
I now have all my parts sitting here waiting for time. Right now I'm working on a '97 Honda Civic that needs: CV axles, differental seals, inner tie rod ends and boots, timing belt, all 3 other belts, plugs, wires, cap, rotor, valve cover gasket, motor mounts, fuel filter, air filter, trans fluid flush and a oil change. Hopefully will have it done tonight if the special "pulley holder" tool gets here so I can get to the timing belt.
Build thread
LSx Swap FAQ index
Old 11-04-2011, 10:32 AM   #411
fishingjred73
fishingjred73's Avatar
That sounds kinda crappy. All somebody has to do is switch parts and boxes then who knows what spindle you've got.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 11-04-2011, 11:32 AM   #412
thor
thor's Avatar
That sux! I've heard of lots of people not being happy with CPP's service. Good news is once the Honda is done, you'll be pulling down 40mpg. I do in my 93 HB Si (fully riced-out of course )
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 11-04-2011, 01:45 PM   #413
mcbassin
Still Learning
mcbassin's Avatar
Man, I hope you got the right parts this time from CPP. Sorry to hear about all the trouble. I've had pretty good luck with them.(never had to return anything yet).
Sounds like you have your hands full with the foreign project.
Hey, quick question: What size is this hole saw? Anything special about the drilling? Thanks
mcbassin is offline   Reply With Quote
Old 11-04-2011, 11:52 PM   #414
usmcchevy
usmcchevy's Avatar
Yep, I just hope these fit.
Honda belongs to my mother in law...........I fix it or she doesn't leave
4" hole saw, Use as big and slow of a drill as you have and don't let it get away.
Build thread
LSx Swap FAQ index
Old 11-05-2011, 10:15 AM   #415
mcbassin
Still Learning
mcbassin's Avatar
Thanks,
I will have to get one of those. My set only goes up to 3.25" I think.
Old 11-05-2011, 05:42 PM   #416
mad2rass
Nice build,what fuel pump did you use?and whats the part #,thanks
mad2rass is offline   Reply With Quote
Old 11-05-2011, 09:31 PM   #417
usmcchevy
usmcchevy's Avatar
Thanks and to the site!
Fuel pump is a Walbro 255LPH GSL392 from here:
http://www.ebay.com/itm/WALBRO-UNIVE...item33583461c8
Build thread
LSx Swap FAQ index
Old 11-13-2011, 06:00 PM   #418
usmcchevy
usmcchevy's Avatar
Front end done!
Powder coated A arms
New upper and lower cross shafts
New lower shaft U bolts
New ball joints
CPP drop spindles
New tie rod ends
New idler arm
New Stock CPP springs with 1/2 coil cut
KYB shocks
New bearings and seals
Turned rotors
New brake pads
Rebuilt calipers
CPP 1.25" sway bar
The spindles did push the wheels out a hair it seems. Before my wheels were 1.25" inside the fender now I'm at about 1".... However before I had no alignment what so ever so the top of my wheels were tipping in quite a bit
Out with the old.
Originals?
New and old.
Little cleaning.
Build thread
LSx Swap FAQ index
Old 11-13-2011, 06:15 PM   #419
VA72C10
VA72C10
VA72C10's Avatar
Looking great!!! Nice job!
Old 11-13-2011, 10:31 PM   #420
gringoloco
A guy with a truck
gringoloco's Avatar
Very nice!
-Chris
Old 11-14-2011, 01:23 AM   #421
mcbassin
Still Learning
mcbassin's Avatar
Man Ben, That looks great! I know how much that series of pictures took. I am looking forward to more updates bro. Keep at it!
Old 11-14-2011, 11:03 PM   #422
usmcchevy
usmcchevy's Avatar
Thanks everyone. Its nice to be able to hit bumps and not be jarred to death or turn a corner without falling out of my seat
Build thread
LSx Swap FAQ index
Old 11-15-2011, 09:12 AM   #423
JWall
Frequent Flyer
JWall's Avatar
Looking good
- Justin
1 Owner 1976 SWB
Old 11-15-2011, 09:51 AM   #424
mcbassin
Still Learning
mcbassin's Avatar
I really like this shot!
Old 12-16-2011, 11:32 PM   #425
usmcchevy
usmcchevy's Avatar
Thanks Mike.
Update, Been driving it just about every day. Rebuilt the rear suspension with poly bushings and KYB Excel-G shocks. Also stitch welded the trailing arms together to stiffen them and keep them from coming apart. Really need an alignment and find my squeak that sounds like the fan belt, but isn't...
Pics later.
Build thread
LSx Swap FAQ index
