Old 06-30-2014, 11:29 PM   #401
oldman3
oldman3's Avatar
Re: My version of the s10 swap
That should work...Jim
oldman3 is offline   Reply With Quote
Old 07-01-2014, 09:16 AM   #402
72-c20
Packrat
72-c20's Avatar
Good adjustment mechanism!
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 07-01-2014, 09:24 AM   #403
ricott
I love your truck and your attention to detail. Take lots of pictures of Goodguys and get fired up - that what I'm planning to do at Goodguys in Columbus next weekend!
ricott is offline   Reply With Quote
Old 08-04-2014, 08:47 PM   #404
BlueJeep
BlueJeep's Avatar
I had a little more repair on the running boards that I didn't get around to doing until recently. The picture pretty much sums it up.
I had some more little things to do before pulling the cab off for the last time. I ran my nylon fuel lines, that took all of about 10 minutes to do. I used a fuel filter for a 2000 chevy van that had quick disconnects on both sides which'll make changing it very easy. So far I'm a big fan of the push-connect style fittings, and no expensive AN fittings to mess with.
I bought clamps, and made the standoffs to weld to the firewall so the lines would run where I wanted them.
I also finished up some things with my inner fenders. Welded on the ECM mount, rounded some edges, and welded 5/16" rod to other edges to keep them from being sharp and to hold the contour I wanted.
Lastly, I pulled off the cab for the last time. Time to finish welding up little things on the bottom and firewall, bodywork and paint the firewall, and spray Raptor liner on the bottom of the cab.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 08-04-2014, 11:31 PM   #405
oldman3
oldman3's Avatar
Great update, and some nice work...Jim
Old 08-05-2014, 12:01 AM   #406
99 to Life
99 to Life's Avatar
very nice stuff.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 08-29-2014, 10:27 PM   #407
BlueJeep
BlueJeep's Avatar
Work continues on the cab. I've filled in the firewall where I sliced it to make room for the passenger side head.
And I got rid of the rest of the holes that I decided I didn't need.
I scratched my head a while on how to run the hoses cleanly and out of the way for the Vintage air unit. This is what I came up with. If I hadn't already welded the heater air intake hole shut, I'd have run them through that.
We then took a couple days to visit the grandparents before school started. We took our obligatory drive in the Model AA.
Back to the cab.
I had a bunch of partially finished welds that needed to be completely finished. I also built reinforcement for the seatbelt mounts in the event that they are ever needed....now I'll feel safe.
And I had some door gaps that were still bugging me. I have spent a ton of time on door gaps, makes me really respect cars that I see around that have nice gaps. This one I made the relief cut and then put the door back on (hinge side). I then needed to adjust the gap like I wanted it and then hold it in place and take the door back off so I could work. This is what I came up with to hold the panel in place. I was able to put tacks on it with the door shut and then take the door back off, worked well.
Mostly finished with this one, still a little touch up left.
As I look around to see what else I need to finish before Raptor lining the floor, I remember that it was a little tight in the tranny cooler line area with my new tunnel. I'll have to chop off a piece and weld in a patch once I find my pictures to see how much needs to be removed.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 08-29-2014, 10:34 PM   #408
99 to Life
99 to Life's Avatar
very nice work!
Old 08-29-2014, 11:15 PM   #409
oldman3
oldman3's Avatar
Nice work, love the seat belt brackets....Jim
Old 09-07-2014, 10:25 PM   #410
BlueJeep
BlueJeep's Avatar
Got the bottom prepped and ready to finish. Now all I need is a block of time to prime, seam seal, and spray the raptor liner....maybe next weekend.
I got about 5 minutes of help from one of the boys. Wasn't fun enough to keep him engaged I guess.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 09-08-2014, 12:06 AM   #411
Kodiaks53
I really like the seat belt setup, been thinking about something like that for mine. Keep up the good work, looking good !
Kodiak's 53S10 Build
Kodiaks53 is offline   Reply With Quote
Old 09-14-2014, 10:24 AM   #412
BlueJeep
BlueJeep's Avatar
Yesterday was a good day! During the week I finished up the prep work and did most of the masking.
This is how high up I decided to go:
After our soccer game yesterday I started in on it. I started with 2 coats of epoxy primer to cover up the bare spots and allow everything else to go on within the "re-coat window. Once that had set up, I seam sealed everything I could with Lord Fusor 803, and by the end I figured out that my gloved finger was the best way to smooth out the sealer (less succesfull attempts were made with a 1" paint brush and a piece of flexible plastic cut from a milk jug container).
And then it was time for the liner. For those who haven't used it this stuff is VERY easy to use. I've heard many fantastic testimonials of this product which is what led me to try it. As long as it holds up well, I'll be another positive review. Sprays easy, covers great, looks great.
Took me from this:
To this:
I'm pretty excited!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 09-14-2014, 10:43 AM   #413
oldman3
oldman3's Avatar
That looks super nice, you did a great job...Jim
Old 09-14-2014, 11:22 AM   #414
Billys68SS
Billys68SS's Avatar
Is that Herculiner?
1949 GMC PU http://67-72chevytrucks.com/vboard/s...d.php?t=608120
1966 C10 http://67-72chevytrucks.com/vboard/s...06#post6601806
1966 C10 SB Custom Cab, Fleetside, BBW.
1968 Chevelle SS 396
1937 Chevrolet Coupe
Billys68SS is offline   Reply With Quote
Old 09-14-2014, 02:56 PM   #415
99 to Life
99 to Life's Avatar
Looks top notch. I too use SPI epoxy primer. I went as far up with the bedliner as you did too. I even covered my cab corners and back wall where you won't really see it. Again, used finger for seam sealer as well. Nice feeling having the cab all sealed up. Should last another 60yrs no problem.
Old 09-14-2014, 10:03 PM   #416
BlueJeep
BlueJeep's Avatar
Thanks Jim, I'm very happy with it.
Originally Posted by Billys68SS View Post
Is that Herculiner?
Nope, Raptor liner.
Thanks! Yes, I thought about going up higher on the firewall, but refrained because I didn't want to cause problems later when I try to ground solenoids or other electrical devices to it. Trying to be as forward thinking as I can be. It really cleaned up the toeboard area where the majority of my patches were.
I'm also pretty fond of my finished tranny tunnel.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 09-14-2014, 10:39 PM   #417
rgunlock
rgunlock's Avatar
That looks really good BlueJeep. I know that it feels really good to have part of the cab DONE!!!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 10-27-2014, 01:34 PM   #418
trucktech
What kind of spacing did you have when you made your trans tunnel?
trucktech is offline   Reply With Quote
Old 10-27-2014, 01:58 PM   #419
BlueJeep
BlueJeep's Avatar
I made it pretty tight. Probably around 1/2". Also pay attention to where your tranny cooler lines hook up. I had to make an extra little tunnel for the top one on mine. I guess that helps illustrate how tight I made it!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-07-2014, 01:40 PM   #420
BlueJeep
BlueJeep's Avatar
It's been quite some time since I posted an update on my project. I've been busy with other things and home projects. I'll relate it to the build by saying I've been trying to make more room in my garage by building a shed in the back yard. Now I don't have to keep garden tools or other non-truck related things in the garage!
Don't pay attention to the child labor, I cannot seem to get a solid 8 hours out of them no matter what I try!
Finished up just as the snow started to fly. I thought the people on this forum would appreciate the vintage feel of it.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-07-2014, 01:50 PM   #421
BlueJeep
BlueJeep's Avatar
Now back on track. I haven't been getting a lot done, but I did enlist in some help from a buddy so progress does continue to be made. I had him bodywork and paint the bed for me, and then spray in color-matched Al's liner. He's set up for this type of thing, and he knows what he's doing. I wanted to do it all myself, but I'm realizing I don't have the time or facilities to get it all done and I want this thing done so I can get to working on the next project (48 Willys truck for my dad). I have three weeks or so to finish up a little work on the cab and then that goes in for body and paint too!
Here's my Black Friday present to myself!
And Friday I had a text message with these:
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-07-2014, 01:56 PM   #422
BlueJeep
BlueJeep's Avatar
So I'm cleaning up some final things on the cab. Had to fine tune my rear cab seam that I welded, and now I'm trying to raise some of my lows on the back of the cab.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 12-07-2014, 03:43 PM   #423
Russell Ashley
Russell Ashley's Avatar
Love the "Patina" you added to the shed. Truck is looking good too. Nice work on both.
Russell Ashley is offline   Reply With Quote
Old 12-07-2014, 04:43 PM   #424
99 to Life
99 to Life's Avatar
yeah that shed is off the hook, luv the shrinking discs they are a great tool.
Old 12-07-2014, 07:42 PM   #425
oldman3
oldman3's Avatar
Shed is kick a$$, looks like it's been there forever. Truck is looking good...Jim
