#401 |
Truck and auto performance nut
Re: 85 burb meets 6.0 lq4
Just plug it for now? The way I see it with mine....I'm to the point of "lets just get it going...I can always upgrade later"!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#402 |
I want to find a block off plate with no hole in it. So i can use sensors in factory locations. Cant find them anyware.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
#403 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#404 |
The big diesels i work on use them. But at work they have gaskets with them. I have to get colleters welded on any way may as well get nice ones that wont leak as often.
#405 |
Got my msd wires in mail today. They came with fancy wire lables and cool too to install the labels. Also got alt pig tail and oil psi sensor.
#406 |
Found a coolant "swithc" as abc auto parts calls it. But the box says sensor so i prety sure i is the right one. Also got my egr/air block off plates in mail today.
#407 |
Second Chance Program
Hope it works for you. Being as they say "switch" it could be for the idiot light dashes.
#408 |
He asked if it was a gauge or not. So i think it may work. The oil psi sensor was also a swithc but it is the one for a gauge. It should work....
#409 |
I got to install my plug wires today and man oh man i am happy. I have actually lost sleep worrieing if they would hit the headers or not. And they dont. I also test fitted the block off plates and drilled holes for fuel pump and regulater today. Not exactly how i wanted it to look but it is going to work fine i think.
#410 |
And the pump....
#411 |
Got my oil cooler bypass cover today. Got donated from a fellow swaper. Just need oil and coolant adapters and hose reducer so i can run steem line to my rad to put it where the factory heater hose goes. Need to find a reducer.. Think it is half inch line that the heater uses.
#412 |
man its looking good bro!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
#413 |
#414 |
Got mounts painted and bolted on. I forgot my tape measure so they are not in the right place yet. Just wanted to see the movment that have avalable. I do think these will work great. Sorry for crappy pictures not sure what happened.
#415 |
Got my show quality racing steam pipe adapter.
#416 |
thats purdee!
![]() what/how are you using it? Is there a port on your radiator that size?
#417 |
Saw a good trick on Extreme 4X4 over the weekend (2010 Episode 22 on the website) Host is putting a 6.0 in his buggy.
Because the radiator is going in the rear, he drilled and taped the thermostat housing to except the steam port. He also did a 180 on the intake to put the throttle body and air clearner in the cab (the intake is not indexed like conventional intakes).
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A |
#418 |
I am using it to put the steam port to the rad heater core return on the rad. No not going to screw it in. I plan to remove most of the exposed pipe thread and slip hose over the end and put the clamp on the part with no threads. Should work tell i find nicer way.
#419 | |
#420 |
Ordered my coolant and oil sensor adapters today. They should be here by friday they said. That means......i have everthing to swap it in but oil change stuff........YAY
#421 |
Kvn1011
#422 | |
You talking about Jesse?
#423 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Yea, she was a hottie for sure, I remember her being out for back surgery and then she came back and then disappeared.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#424 |
hey....any chic that can "build" your chassis for you and then load it up with a drivetrain and more is a keeper....and she was a looker to boot. She ought to have her own show!
#425 |
My wife pretty much put her old truck together. She used to even do her own tuneups and breaks and such. This is her truck when i first met her. We dropped it in front a nother 1 inch and put primered 15x8 with like a 255/55 tire and in rear lowered 2 or so more but put 275/75s on 15x10s for a prostreet kind of look. I lowered that truck 3 time or so.
