Old 05-20-2012, 08:34 PM   #401
Can't kech me
Can't kech me's Avatar
Re: No Limit '72 C-10
Originally Posted by robnolimit View Post
The pan is aluminum, and a fair job to modify. Now, you can get new pans from Speedway, Summit, and Jegs for cheap.
Thanks, thats what i thought, i just wanted to make sure. I measured and an fbody oil pan should fit with no mods, and are avalible fairly cheap.
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 05-20-2012, 10:57 PM   #402
robnolimit
robnolimit's Avatar
I'm so glad the new pans are available now. We used to mod truck pans all the time. It's dirty, and a general pain in the a$$.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 05-20-2012, 11:50 PM   #403
hotrod1
56 - autocross
hotrod1's Avatar
Hey Rob:
What pan for example?
hotrod1 is offline   Reply With Quote
Old 08-24-2012, 01:18 PM   #404
duallyjams
duallyjams's Avatar
What's JT been up to this summer ?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-24-2012, 03:04 PM   #405
robnolimit
robnolimit's Avatar
HotRod1, the pans we use mostly are the Holley swap pans for Chevelles and Camaros.
DJ, the JT has been doing shop runs, and landscape duty. On the plus side, we have been donig extensive shock testing and tuning. Next year we should have our own line of custom valved C10 shocks.
Old 08-24-2012, 03:53 PM   #406
gringoloco
A guy with a truck
gringoloco's Avatar
...Next year we should have our own line of custom valved C10 shocks.
You just had to report this the day AFTER I purchased my Bilsteins
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-24-2012, 07:57 PM   #407
robnolimit
robnolimit's Avatar
No worries, the Bilstiens are a great shock.
Old 08-24-2012, 08:31 PM   #408
Mike Bradbury
Mike Bradbury's Avatar
hey Rob, that's great news, are they going to be a monotube design with large valving that can handle our heavy trucks?
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 08-26-2012, 12:52 AM   #409
Can't kech me
are jt and hellboy going to be at texas motor speedway for the good guys show?
Old 08-28-2012, 12:01 PM   #410
robnolimit
robnolimit's Avatar
Yes, we'll be there. Can't miss out on Babe's chicken!
Old 08-28-2012, 12:21 PM   #411
Low Elco
You gonna be in KC this weekend? JT and Hellboy ?
Low Elco is offline   Reply With Quote
Old 11-23-2012, 08:44 PM   #412
chapster
chapster's Avatar
Hey Rob,
Would it be possible to get a dimension from JT per pic below.
i am running a 15" wide tire with a narrowed rear end and am looking to determine if your rear stabilizer will fit?
Cheers
1967 GMC shorty Parts Pile: NoLimit, Accu Air, Kore 3, Matts Classic Bowtie, March Performance, Lokar, ScottsHot Rods, Vintage Air, American Auto Wire, Circle D, Accu Air, Borla, Budnik, Ididit, One Piece Windows, Doug Thorley, Pypes, AutoLoc, Porterbuilt, CPP, Dynamat, Dakota Digital, Fesler
1968 Chevy c10 shorty Stepper (Patina LS project)
1967 gmc custom Long Box (Farm Truck Project)
chapster is offline   Reply With Quote
Old 11-27-2012, 02:53 PM   #413
Schwinn
Schwinn's Avatar
Location: San Diego, Escondido, California, Del Dios Hwy
Always fun to watch fellow members using there trucks...In this case RACING. Good seeing you again.
How did you do and what did you win? From racing and in show...
And Meeee
Schwinn is offline   Reply With Quote
Old 11-27-2012, 08:39 PM   #414
jlsanborn
jlsanborn's Avatar
Originally Posted by chapster View Post
Hey Rob,
Cheers
Just finished installing mine....
'67 C10 Long Fleetside
'71-'72 C10 five lug rear with OE drums
15x10x4.25bs Wheel Vintiques
BFG 295/50-15
No Limit adjustable panhard rod and shock relocate kit.
5" drop springs in rear with some blocks to come later.
The most useful measurement would probably be the overall, which is 45-3/4" including the fastners, although the bend in the bar makes it a little wider in that spot. Mine is more like 46-1/8" wide about 13" from the axle centerline. I'm not sure what the manufacturing tolerances are for that bar, but I bet It'd be +/- 1/8" or better for overall width???
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 11-27-2012, 08:59 PM   #415
chapster
chapster's Avatar
thanks jslanborn,
I going to go out to the garage & compare dimensions. I hope there is room....
Cheers
Old 11-27-2012, 09:07 PM   #416
jlsanborn
jlsanborn's Avatar
No problem! Glad to contribute to the forum whenever I can.
Old 11-27-2012, 10:00 PM   #417
robnolimit
robnolimit's Avatar
Sorry I was late on the sway bar info, thanks for helping out.
We finished second in the pro class, I never could catch the RideTech 33, - I think I may not help them so much in the future. lol - Then we got the pick for the Snap-On "Innovation" award. The points we got put us in the top spot for Pro-Truck, and fourth overall in the Pro class. With this weekend's fund raising, our total for he Wounded Warrior Project is over $23,000.00 !!! A nice way to end the year. It was great to see everyone out there and in Scottsdale.
Old 11-27-2012, 10:24 PM   #418
chapster
chapster's Avatar
thanks Rob,
Nice to here your success, watching you on the GG course was awesome......
I measured my clearance and unfortunately I only have 3.25" between the frame rail and the inside tire wall.
Cheers
Old 11-28-2012, 10:03 PM   #419
jlsanborn
jlsanborn's Avatar
thanks Rob,
Cheers
Man that's close! There's probably something out there that'd fit just right but I bet you might be able to "over-bend" Rob's bar and make it work. I'm not real hip on how they'd make that bar but I bet the science is in the round-bar the spring company is getting. Once they get it or treat it, I bet they simply cut it to length and bend/form/machine it to application. If you could over bend the 90* at the frame rail then "kick" the last straight section back out to the link I think it'd fit.
Rob,
You might consider tightening up the frame/spring clearances to open up the range of wheel/tire/shock/whatever combos.
Just my $0.02
Old 12-02-2012, 10:38 AM   #420
Cracksrubi
Cracksrubi's Avatar
Hey Rob on that red truck y'all built is it the one you chopped 4 inches out of the front of the bed and 2 out of the back cause im going to convert a lwb into a swb and I was really liking the idea of a shorty truck
68 c-10 lwb
Cracksrubi is offline   Reply With Quote
Old 12-17-2012, 10:00 PM   #421
jayski1010
Rob, if you could use any spindle as a starting point from scratch, what would you use and why. I am not just limiting to aftermarket such as cpp etc. I am talking any, wilwood pro spindle, scp, howe, coleman spindles or even a specific oem spindle? Im getting ready to build a 68 chevy swb and I want to optimize from the begining, I am not afraid of reworking a spindle either. I saw your rework on your 72? a arms to get 9* caster, cool way to go. I am looking at it all, ball joint heights, kpi, and how they impact issues like roll center, roll center movement, etc. thanks for your thoughts.
Jay
jayski1010 is offline   Reply With Quote
Old 10-27-2014, 08:46 PM   #422
ol_skool_chevy
ol_skool_chevy's Avatar
So of the Original truck you bought what did you use?..bed, fenders?
hood, doors and non-stock control arms?......i was lost back at page 6 or 7 as to how much of it was going to be used for a cheap simple build..
Although its entertaining to read, i did learn a lot from it
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 10-27-2014, 08:46 PM   #423
ol_skool_chevy
Mark with Chalk
Cut with a torch
Old 02-24-2015, 06:52 PM   #424
KSWes
KSWes's Avatar
"Secret Mod on page 9 I can only say thank you Rob!" With help from a buddy who can lay down some quality welds we accomplished the secret mod on my lower control arms over the weekend (70 C10 LWB) and my goodness what an improvement! It holds the road as good as our newer cars. And it does work on 15" rims with stock spindles and stock steel rallies, and stock ride height. Took your recommended specs to the alignment shop and they got me pretty close. Could have driven it home with one finger if I had wanted to.
Thanks again Rob!
Truly one of the coolest things I've done to the truck and relatively simple and it feels much safer to drive at highway speeds. I only attempted this with the help of a friend who can weld good enough so I know me and my family are safe riding around on those welds. I can't wait for the weather to improve to get it out on the road a lot more.
70 Chevy C10 LWB
My Build:http://67-72chevytrucks.com/vboard/s...d.php?t=513002
KSWes is offline   Reply With Quote
Old 08-17-2015, 01:43 AM   #425
crakarjax
crakarjax's Avatar
Looks like Rob hasn't posted in a few years... is that pretty much it for the JT truck?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
1972 chevy, c-10, no limit engineering
