Old 05-12-2011, 07:16 PM   #401
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
Getting ready to cover garnish moldings and arm rest in ultra-leather.
oldman3 is offline   Reply With Quote
Old 05-12-2011, 07:18 PM   #402
oldman3
oldman3's Avatar
Working on the door panels. Don't have pic showing much detail, but the slats have been glued in place. Then the tweed material is glued down and stapled to the first panel.
Old 05-12-2011, 07:21 PM   #403
oldman3
oldman3's Avatar
Here the upper and lower panels cover with ultra leather, then glued and stapled to the first panel, for the finish panel, with arm rest installed.
Old 05-12-2011, 07:23 PM   #404
oldman3
oldman3's Avatar
Pic 1 As viewed from the pass. side.
Pic 2 Another interior shot.
Old 05-12-2011, 07:24 PM   #405
oldman3
oldman3's Avatar
Templets made so I can get my glass cut.
Old 05-12-2011, 07:26 PM   #406
oldman3
oldman3's Avatar
Here I've installed the glass and rubber around the edges.
Old 05-12-2011, 07:28 PM   #407
oldman3
oldman3's Avatar
Here is a good shot with the new cover on the top, and the truck in the background.
Old 05-12-2011, 07:30 PM   #408
oldman3
oldman3's Avatar
Top on the truck and showing taillight setup.
Old 05-12-2011, 07:31 PM   #409
oldman3
oldman3's Avatar
Tomorrow I'll post about the top interior with lots of pics. Jim
Old 05-12-2011, 07:37 PM   #410
VA72C10
VA72C10
VA72C10's Avatar
Looks really good! Congrats!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-12-2011, 09:05 PM   #411
oldman3
oldman3's Avatar
Thanks, appreciate you checking it out.
Old 05-13-2011, 01:09 AM   #412
OrrieG
OrrieG's Avatar
What did you use to clip the panel to the door? Just a standard push type like used in mid-60's cars or ?? Also, I just realized that you are showing pics of the build from a while ago, not in real time. I was getting pretty impressed at the progress you were making from day to day.
Turned out really nice. I will admit that I have seen more bad roadster conversions than good so usually don't care for them. Yours has just the right amount of chop and great profile.
OrrieG is offline   Reply With Quote
Old 05-13-2011, 02:42 AM   #413
bmnk
bmnk's Avatar
Yes it is wood, called lauan, I always use birch but it comes in different types. It is about 1/8" thick. A lot of upholstery shops use it instead of door board.
Is the stuff that looks like Wainscoting (the stuff you used for the door and back panels) also the same lauan wood material, or is it actually regular Wainscoting -- It turned out great. It's a cool idea.
bmnk is offline   Reply With Quote
Old 05-13-2011, 03:32 PM   #414
oldman3
oldman3's Avatar
Just the standard type you can get at the auto paint store(at least at mine).
, yeah I wish I could get things done that fast, but I'm not a TV show. I agree with you about the roadster conversions, I've seen several I just did not care for. Thanks about my job, I spent a lot of time looking at real convertibles, to try and match that look. Picture of clips isn't good, can't get it to focus real close up.
Old 05-13-2011, 03:42 PM   #415
oldman3
oldman3's Avatar
It's the same lauan material, each piece is cut separtely, then glued to the first panel. Post #291 shows how I drew it on the lauan, then I had to cut the pieces. Post #293 shows the individual pieces, temporaryly screwed to the first panel, until ready to glue down.
Pic 1 shows a small piece of the lauan
Pic 2 This is the glue I use, it can also be sprayed with a sipon paint gun.
Old 05-13-2011, 04:46 PM   #416
oldman3
oldman3's Avatar
I went for about 5 years without doing the top interior. I had been working on a rebuild for a good friend (more on that later). Anyhow here is the build on the top interior.
Pic 1 I had about 80% of the interior thought out, except for the corner pieces (that's another reason for taking so long). What I finally did was take some poster board and form a piece in the corner and cover with 4 layers of fiberglass.
Pic 2 The other side. (both of these pieces are held in place with the Xmas tree type plastic clips)
Old 05-13-2011, 04:48 PM   #417
oldman3
oldman3's Avatar
Showing general shape of interior.
Old 05-13-2011, 04:50 PM   #418
oldman3
oldman3's Avatar
Pic 1 Sanded fiberglass and started adding filler to smooth out.
Pic 2 More filler.
Old 05-13-2011, 04:54 PM   #419
oldman3
oldman3's Avatar
Again a general view. Since I already had the exterior top material on the top, it made it harder to work on this, and not mess up something
Old 05-13-2011, 04:56 PM   #420
oldman3
oldman3's Avatar
Pic 1 More filler
Pic 2 Finally got it right.
Old 05-13-2011, 05:00 PM   #421
oldman3
oldman3's Avatar
Jump ahead here, loss some of my pics.
Pic 1 This is the center secion of the main piece, slats glued in place and then covered with material. I had cut the leather close to the size I needed, stapled to the edge of panel.
Pic 2 Close up.
Old 05-13-2011, 05:04 PM   #422
oldman3
oldman3's Avatar
Pic 1 The second panel is put in place, glued (contact cement) and stapled to first panel.
Pic 2 Thin close cell foam is glued to panel, and cut to fit.
Old 05-13-2011, 05:08 PM   #423
oldman3
oldman3's Avatar
Before the leather is pulled over the foam, you spray glue to both pieces, then let it tack up good, then work from center toward the outside edges, and press down. I use a bondo spreader for this. Then staple in place
Old 05-13-2011, 05:10 PM   #424
oldman3
oldman3's Avatar
Here both front panels are done and the corner pieces, covered and installed. The corner pieces are held in with plastic xmas tree door panel clips.
Old 05-13-2011, 05:13 PM   #425
oldman3
oldman3's Avatar
Pic 1 Close up of side panels with excess material now stapled down.
