02-16-2012, 05:06 PM | #401 |
Re: 1971 c10 stepside
I went by your job and hung out with you anyways, so you can breath now!!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
02-16-2012, 11:08 PM | #402 |
u need to get down here buddy !!!
I'll load the welder up and I'm on my way!!! Posted via Mobile Device
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
02-20-2012, 11:31 AM | #403 |
well guys my dad and i started the overhead engine hoist install , we mounted brackets on the wall , we now have to get some extra men power and up the beam goes , sometime this week we'll put it up and ill post some more picks
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
02-20-2012, 11:35 AM | #404 | |
02-20-2012, 11:40 AM | #405 |
Hey buddy .. what are your plans for tail lights on your stepper? Just stock ones? I'm thinking about trying to come up with something billet. Maybe re-make the factory brackets in Billet and just pull them in a little closer to the bedsides? More flush and/or a single bracket for both the tail and backup lights?
.. just curious what you were planning for this one. thanks.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
02-20-2012, 11:45 AM | #406 |
hello chad , im still on powertrain mode so for now im thinking of staying with all factory on the lamps department , but then again i may change my mind as the build goes on
02-20-2012, 03:08 PM | #407 |
Raulito "La Viga" Raulito!!!!
02-20-2012, 04:03 PM | #408 |
Wow truck looks awesome Raull
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
02-20-2012, 04:23 PM | #409 |
The Camaro is ridiculous too.. I can't stop looking at either one of them.
Raul definitly has the 'stance' department nailed. Absolutely perfect my friend.
02-20-2012, 04:30 PM | #410 |
we gona need your stregth
thanks keith tahnks chad
02-20-2012, 05:20 PM | #411 |
Let me know when!!!! Raulito
02-20-2012, 06:42 PM | #412 |
Still Learning
Your truck looks great. I love the Coys and stance. Keep the updates coming.
02-20-2012, 08:19 PM | #413 |
Love the truck! Cool build.
1972 GMC (PROJECT LONG OVERDUE) 1998 SWB 4WD |
02-20-2012, 08:33 PM | #414 |
Sick truck... looks amazing!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
02-20-2012, 11:10 PM | #415 | |
02-20-2012, 11:29 PM | #416 |
I'll bring the coquito!!!
02-21-2012, 09:40 AM | #417 |
Raull,
Your truck looks great. It makes me more motivated to complete my build. keep up the good work. Later Dillon
________________________________ 1972 SWB stepside pro tour build thread http://67-72chevytrucks.com/vboard/s...d.php?t=452840 |
02-21-2012, 12:55 PM | #418 |
For sure now I am coming.....
02-21-2012, 01:15 PM | #419 | |
teaser !!!!
02-21-2012, 01:22 PM | #420 |
67-72 parts collector,…
Raull,... are you using any "vertical" supports under those beam mounts?
Or are the beam brackets just anchored to the outside wall?
02-21-2012, 01:58 PM | #421 |
solid cement area at the top , we build two 16in wide by 10 in high by 1/2 inch thick plates and used 4 1/2 inch bolts all the way trough the outside of the wall on both sides , the beam its a 6 inch tall , the main area where one should worry is at the middle , so we welded a 1inch thread adapter in the middle for a center support just in case , dont need it but we just like to be safe than sorry , ill post some more pix as we go
02-22-2012, 12:07 AM | #422 |
Stocker to Rocker http://67-72chevytrucks.com/vboard/s...=1#post5148380 "THE GRADUATE" http://67-72chevytrucks.com/vboard/s...08#post5763408 JohnnyC http://instagram.com/texpinstriper/ |
02-22-2012, 04:15 AM | #423 |
Looking really good. As someone with a stepper, trying to sort thru what I need to fit wide wheels in the rear. I forget, did you shorten the rear end and cut the bed insides for tubs?
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
02-22-2012, 09:43 AM | #424 | |
thank's !!!!!
hello leon , i just went with some cookie cuters 265's for now but if i ever go wider i would cut bed panels and use some factory fleetside tubs and cut them to my specs.
02-22-2012, 10:29 AM | #425 |
67cheby
i have a beam running sideways through my garage....you got me thinking ! i need to see if mine is solid or one of the wood i beam ones , it is about 12 inches tall and 4 inches wide
