Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 08-02-2013, 12:16 AM   #401
mud.man.rj
mud.man.rj's Avatar
Re: Our "What are we going to do?" 66 Suburban Build
Man if someone didn't know better (lots of people) the tubs look all but stock, nice work.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 08-02-2013, 09:49 AM   #402
piratexpress1369a
piratexpress1369a's Avatar
nice job ..nos hmm got speed..lol
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 08-10-2013, 04:18 AM   #403
RockTonka
RockTonka's Avatar
Thanks, Little smoothing and some paint and you're right...most people won't pick up on it.
Thanks! Ain't got no speed yet...gotta get the wires/line run, then maybe
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 08-10-2013, 04:29 AM   #404
RockTonka
RockTonka's Avatar
Put the burb up on the lift to check things out. Had to replace the collector gaskets,put some "dead soft" AL. ones in...those should seal/last better.
Had a little seepage around the tail shaft housing, tightened that up a bit...also took measurements for a one-piece driveshaft to replace the weaker two-piece.
Other than that, everything looked alright...couple thousand miles since getting it on the road now.
Pic of the 1 1/2" spacer we made a couple months ago to drop it a bit...
My build thread
Old 08-12-2013, 02:11 PM   #405
scotts62
One day...
scotts62's Avatar
Gotta love the big meats! Looks good!
Scott
93 crew cab build
Project 62
Old 08-13-2013, 10:05 AM   #406
piratexpress1369a
wow look how clean it is under there
63
Old 08-13-2013, 10:28 PM   #407
RockTonka
RockTonka's Avatar
Thanks Scott! What's the scoop on the ride in your avatar? Looks nice...
Some is, some isn't I was thinking I need to do some wiping down under there
Edit: on the burb that is...
My build thread
Last edited by RockTonka; 08-13-2013 at 10:41 PM. Reason: "wiping down under" clarification
Old 08-15-2013, 06:57 AM   #408
scotts62
One day...
scotts62's Avatar
Was a customers car that i painted a few months back. Thanks
Scott
93 crew cab build
Project 62
Old 08-19-2013, 12:04 AM   #409
RockTonka
RockTonka's Avatar
Worked on the underside rear fenders a bit...cleaned them up, shot some primer on the bare metal, and undercoated them.
Looking at burb from this angle sure makes the frame look ratty!
My build thread
Old 08-19-2013, 12:12 AM   #410
RockTonka
RockTonka's Avatar
We've had near perfect weather around here for the last couple days...mid 80's, 5-10 mph breeze, really nice for mid-August!
Got the yard work done early, so the wife and I took the burb for a cruise down to the lake to let the dog swim and catch a sunset.
My build thread
Old 08-19-2013, 01:01 AM   #411
likaroc13
Rollin' Old Skool
Fenders look good...& don't feel bad, my frame looks ratty too! At least yours matches the character of your exterior. Like you, I kinda have a mix-match of clean stuff & areas that could use attention. Hopefully I'll get around to it one day.
Great sunset pics!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 08-19-2013, 01:59 AM   #412
RockTonka
RockTonka's Avatar
Thanks Phillip, I hear ya on the mix and match...it's just that the ratty parts sure look worse next to the clean stuff!!
My build thread
Old 08-19-2013, 02:30 AM   #413
Captainfab
60-66 Nut
That's a sunset worthy of framing
Old 08-19-2013, 07:59 PM   #414
mud.man.rj
mud.man.rj's Avatar
that's what undercoating is for. Nice sunset x2. Should stop and look at one more often, thanks.
Rick/Mudman.
5.0 4spd std.
7" lift w 35's.
Old 08-19-2013, 10:10 PM   #415
RockTonka
RockTonka's Avatar
Rick/Mudman.
Life's too short not to stop whenever you can and appreciate it...
My build thread
Old 08-20-2013, 04:22 PM   #416
piratexpress1369a
nice water sunset
63
Old 08-20-2013, 05:52 PM   #417
justcuz
justcuz's Avatar
Lots of new stuff for you guys! House with shop space upgrades to the Burb, evening cruises to the lake. Sounds like a bit of Heaven going on.
What's the plan for the back seat? With the tubs widened the stock seat no longer fits correct? How about individual buckets or maybe 2007 and up Tahoe 3rd seats.
Good thing you own that, if I did it would have become a 4x4!
justcuz is offline   Reply With Quote
Old 08-20-2013, 11:31 PM   #418
RockTonka
RockTonka's Avatar
nice water sunset
Yea, it was relaxing...
We have our moments, thanks.
Stock seats are long gone. I'll eventually have some suspension benches made to match the front buckets...long and short or maybe just a long that could fit behind or in-front of the tubs. For the time being, our lab likes it without anything in his way!
Oh trust me, we seriously considered making it a 4X...almost everything we have is! I'm really enjoying it as a road toy though...we're having a blast with it!
My build thread
Old 09-10-2013, 11:19 PM   #419
RockTonka
RockTonka's Avatar
I had an old truck driveshaft cut down to fit the burb...saved me a couple bucks but it's a bit big at 4" dia., but hey, its stronger
The old shaft had 1350 joints (plenty for what I'm doing), so I swapped out the yokes on the tranny and axle...just a little bigger
Pulled out the old two-piece and cut out the carrier mount...
The offset of the pinion caused the larger dia. shaft to ride against the pass side of the crossmember. I cut out the pass side of the reinforcing lip and moved it outboard 3/4".
Test fit before final welding...good enough clearance all around...
Welded up...
Done deal Vibrations are gone and no worries about strength!
My build thread
Old 09-10-2013, 11:30 PM   #420
likaroc13
Rollin' Old Skool
Great job!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 09-11-2013, 12:21 AM   #421
mud.man.rj
mud.man.rj's Avatar
I agree, nice job on the d shaft, well worth the effort.
5.0 4spd std.
7" lift w 35's.
Old 09-11-2013, 12:45 AM   #422
RockTonka
RockTonka's Avatar
Great job!
Thanks, got to cross something else off the list!
My build thread
Old 09-11-2013, 07:37 PM   #423
piratexpress1369a
nice job ..you shouldn't break that now
63
Old 09-15-2013, 01:16 AM   #424
RockTonka
RockTonka's Avatar
Thanks, that weak link always bugged me...no more!
My boy is out cruising the burb around tonight, said they were going to Thunder Valley to watch the drags...got this update a bit ago
My build thread
Old 09-15-2013, 01:26 AM   #425
likaroc13
Rollin' Old Skool
Great pic!
Phillip
My Build threads:
Pics:
Previous Rides:
