#1 | |
![]() Join Date: Dec 2006
Re: Project Roxy
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#2 | |
Re: Project Roxy
///Relaxed Atmosphere |
Re: Project Roxy
Hey bud take your time man. We will give you till Wednesday. That sounds fair right Eric? Lol
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
#4 | |
![]() Join Date: Nov 2008
Re: Project Roxy
Re: Project Roxy
Well, I'd have pics of the new wheels and brakes, but when I went to mount the rear wheels I found out the centerbore was incorrect.
Waiting to see what can be done.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Project Roxy
Did you tell them the wrong center bore diameter when ordering them or did Billet Specialties make them wrong?
Re: Project Roxy
Re: Project Roxy
Like this,...
Tot Roddin'
Re: Project Roxy
I'd be curious to know what center bore you ordered and what rearend they were installed on.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Re: Project Roxy
Shot sorry to hear that.
Re: Project Roxy
Yea, I didn't think to test fit the rears before mounting the tires too..
Re: Project Roxy
Ah bummer friend!
-Rus |
#13 |
Re: Project Roxy
When speaking with the person I ordered them from (a member on this board). I told them it was for a 69 C10 with stock rear axles. I reasonably assumed that it would be addressed.
There are some reasoning. Its possible that with the disk brake conversion the wheel sits further in. I have some options on the table. Worst being pulling the tire off and send the wheels back.
#14 |
Re: Project Roxy
Sorry to hear that, hope you can get it corrected. Looking forward to pics.
#15 |
Re: Project Roxy
This order form usually covers all the possible issues,...
http://www.billetspecialties.com/ass...asureGuide.pdf The member you ordered from, knows these old trucks,... so BS probably made the mistake.
#16 | |
Re: Project Roxy
#17 |
Re: Project Roxy
Ummm... Yes.. Good find!
#18 |
Re: Project Roxy
Not quite what I had in mind. I wonder what they used? I have a Bridgeport.
#19 | |
Re: Project Roxy
#20 |
Tot Roddin'
Re: Project Roxy
Zero issues when I ordered my BS SL Vintecs for my all stock '69.... I'd be curious what you find out the cause is from. Here's the specs I provided when I ordered my wheels:
Front: 20x8.5" w/ 5.5" BS - Center Bore: 3.430 - Bolt Pattern: 6 on 5.5" Rear: 20x10" w/ 4.75" BS - Center Bore: 4.250 (due to the center hub on the rear axle of my '69 [meas. 3.5"; BS only offered 3.43]) - Bolt Pattern: 6 on 5.5"
#21 |
Re: Project Roxy
The person I ordered from said a 3.43 bore size was ordered. He used the same bore size on a 65 suburban a few weeks earlier with no issues. I'm going to measure the wheel and axle tonight to see how much they are off.
#22 |
Tot Roddin'
Re: Project Roxy
The 'center' on the axle seemed large in dia. but using the caliper tool, I knew for a fact the 3.43 bore wouldn't work.
Did they use a '65 rear axle?
#23 |
Re: Project Roxy
As far as I know.
#24 |
Tot Roddin'
Re: Project Roxy
Must have a different rear axle, or another infamous change by GM.
![]() Sorry to hear that didn't work out as planned. I measured my setup countless times over a couple of months, and made sure to take into consideration other peoples measurements but knew that no two trucks are alike. Plus I had some great assistance from two people particularly in running numbers and every possible option by them. They were sick of me by the time I placed my order. Ha! Heck, if I remember correctly... I might have even contacted BS when I ran across the center bore dia. for the rear axle and I think they even stated I would be fine with 3.43" which made the order that more nerve racking. I figured with the center bore that to much wouldn't impact the function of the wheel that much, unlike backspace measurements.
#25 |
Re: Project Roxy
I just did a quick measurement of the hub portion of the axle and it's 3.5" so it's not off by much.. Maybe a 1/16th of an inch
///Relaxed Atmosphere Last edited by Rochlow; 11-26-2013 at 10:47 PM. |
