Old 05-14-2014, 07:00 AM   #401
mikeleeshields
mikeleeshields's Avatar
Re: 1970 SWB : Porterbuilt to the Extreme "Double E"
I spent the other night trying to make sure my wiring was working. I still think I have too many loose ends to have everything work properly. I will have to work on that a little more.
I blasted my brake booster bracket and manifolds yesterday. I also put a coat of POR15 on my manifolds.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 05-14-2014, 07:01 AM   #402
mikeleeshields
Originally Posted by ddubbs View Post
Wow!!! Your truck is turning out killer. Going to have to go back thru this thread. Subscribed
Hey did you use tractor fenders for the bed or did you make those?
Mike
Old 05-16-2014, 04:20 PM   #403
mikeleeshields
Finally some pictures that actually look like progress. I roughly put the bed on last night. I couldn't stand them just sitting there in the box teasing me every time I went in the garage. Tried to figure out how much I have to move the wheelwell openings. Realized I need to buy a new front sill in order to mount it properly also.
I am going to try and really hit it hard and get this thing started in the next two weeks. Wish me luck. I picked up a new starter yesterday. Once the manifolds are completely painted I will change the oil hook up the gas line and try to start this beeyatch. I hope it still does what it is supposed to.
Mike
Old 05-16-2014, 10:48 PM   #404
Bennett68C10
Bennett68C10's Avatar
Those bedsides look so good on there, nice job Mike. Are you still shooting to try to have it on the road this summer?
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-17-2014, 07:59 AM   #405
mikeleeshields
Well Keith that is the plan I am shooting for but unfortunately i think my gun is full if blanks lol. We will see. How high did you end up raising the inside lip on your bedsides?
Mike
Old 05-17-2014, 02:33 PM   #406
jtp67-72
jtp67-72's Avatar
Here's a shot of mine....10"
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 05-17-2014, 02:35 PM   #407
mikeleeshields
Is that 10" from the floor lip?
Mike
Old 05-17-2014, 09:25 PM   #408
jtp67-72
jtp67-72's Avatar
Yep....and now my wood sits on top of new lip...that 10" is figured in that....look at your rear bag fittings...that's where u have to have the final clearance....jim
Old 05-17-2014, 10:05 PM   #409
Bennett68C10
I didn't raise the inside lip of the bedsides. I plan on leaving that where it is and raising the floor similar too what Kyle(screaminchevypickup) did on Lucy. Basically just making a frame out of square tubing, making the tubs fit and laying the wood down. I'm leaving the inside lip where it is so I can still bolt the cross sills down to the frame like the stock floor would.
Keith
66 Suburban
IG: bennett68c10
Old 05-18-2014, 02:57 PM   #410
mikeleeshields
Thanks Jim. Dit looks like you just made a filler piece for the sides. Did you just leave the to portion of the inner bedside open? Did you also weld the filler pieces toy he outer bedside?
How are you not moving the inner lip? Doesn't it hit your wheels when aired out?
Mike
Old 05-18-2014, 11:19 PM   #411
Bennett68C10
Mike I cut out the inner bedside to clear the tires but I'm not moving the inner lip up like Jim did. I'm leaving it where it is so I can bolt the cross sills down to the frame like a stock application. I just cut some strips of wood to mount between the cross sills and the lip. You can see in the pic how I cut it and also the wood strip between the cross sill and the lip.
Keith
66 Suburban
IG: bennett68c10
Old 05-18-2014, 11:47 PM   #412
jtp67-72
jtp67-72's Avatar
Nothing welded to outer bedside...used panel bond..works great..that open part at top is where tubs slip under..see pic....jim
Old 05-18-2014, 11:54 PM   #413
mcbassin
Still Learning
mcbassin's Avatar
Congrats on the bed assembly. Looking good!
mcbassin is offline   Reply With Quote
Old 05-19-2014, 06:51 AM   #414
mikeleeshields
Keith, I gotcha. Looks good.
Jim, that is the ticket. That is the approach I am more than likely going to take. Are you welding the tubs in or panel bonding them also?
Mike
Old 05-19-2014, 06:52 AM   #415
mikeleeshields
Well it isn't exactly congrats yet. I have it disassembled again. I am waiting on a front cross sill to mount the bed. But Hopefully next weekend I can mount it again.
Mike
Old 05-19-2014, 12:14 PM   #416
jtp67-72
jtp67-72's Avatar
they are bolted...see the nutserts in 1st pics....heres the tubs.bolted in ..looks like magic..holding themselves up..lol.....jim
Old 05-19-2014, 01:15 PM   #417
mikeleeshields
Dang Jim. Just that easy right. Well I got an extra $50 bucks go ahead and make me a set while you are at it. I will take sheetmetal or fiberglass whichever one you don't mind making, haha.
Looks great.
Mike
Old 05-19-2014, 06:18 PM   #418
jtp67-72
jtp67-72's Avatar
I guess while i'm at it u want me to reverse the lips too so u won't have exposed bolts???........lol.........yeah they are a little work but trick is to take your time especially with a mig......jim
Old 05-19-2014, 06:23 PM   #419
knomadd
knomadd's Avatar
That's a cool trick hiding the wheel well bolts. I like it!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 05-19-2014, 08:44 PM   #420
jtp67-72
jtp67-72's Avatar
Start with a 1" by 1/8 flatbar....lots of patience...lol.....will wait to drill right before installing to get right placement...the way these things hang tight, they won't need many flange bolts....here's pic of another i did...tubs not finished but u can see how much better it looks...jim
Old 05-19-2014, 09:23 PM   #421
mikeleeshields
Well Jim I don't think they look good enough for $50 I'd give you $40 that'd be 20 a piece lol. Haha just kidding they look awesome.
Mike
Old 05-21-2014, 07:08 AM   #422
mikeleeshields
I actually feel like I accomplished a couple things yesterday. Worked on it until the wee hours of the night.
I mounted the rear frame cross member then mounted the gas tank in its new home. I hooked up the fuel line to the gas tank and installed the float.
I took apart my two columns (standard and tilt) to make a good one. I replaced the turn signal control. I also scuffed it and repainted it.
I also finished off the body work for the firewall. I am going to get some heavy build primer today and hopefully shoot it this weekend. Then I can mount my new booster, master, and plumb up my brake lines. I can also install my steering column.
I still have a goal of starting this darn thing by next week.
Mike
Old 05-21-2014, 07:57 AM   #423
mcbassin
Still Learning
mcbassin's Avatar
Looking good Mike,
Old 05-21-2014, 08:25 AM   #424
Bennett68C10
Nice job on the firewall
Keith
66 Suburban
IG: bennett68c10
Old 05-21-2014, 08:38 AM   #425
mikeleeshields
Looking good Mike,
Thanks Mike.
Thanks Keith. We will see how good when I shoot a coat of primer on it, haha.
Mike
