Old 01-20-2014, 09:06 PM   #401
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I got started on the steering wheel this weekend, need to let it cure for a couple days before I start sanding on it.
I dug out all the cracks, my Dremel battery bit the dust, so I had to improvise with my die grinder and rasp files.
Slowly filling back in... it's hard to get it just right
That's put away to cure and then the real fun will begin...
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 01-20-2014, 09:12 PM   #402
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Meanwhile, back in the garage, it was finally warm enough and I had the time to finish the last bit of metal work and get my doors in primer.
My door painting apparatus.. bailing wire is for backup, it's screwed together.
I'll come back once this dries and touch up the spots where the hooks touch. I got this idea from JMKING (thanks bud) but I didn't want to hang them from my garage door racks so I could close it down when I was done. When I actually spray the color coat I'm going to have to get a longer board, too close to ladder for that, but worked fine for primer.
Black Epoxy PPG JP377
Followed by Grey Epoxy JP205
Jimmy
.69SWB Build.
Old 01-21-2014, 01:56 PM   #403
Low Elco
Re: Project 69SWB
I like your door shootin' rig! I'll be stealing that one.
Low Elco is offline   Reply With Quote
Old 01-21-2014, 03:54 PM   #404
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
One of my many contributions to society.
Jimmy
.69SWB Build.
Old 01-21-2014, 05:17 PM   #405
mcbassin
Still Learning
mcbassin's Avatar
Re: Project 69SWB
Very nice work on the doors and steering wheel Jimmy! That gray epoxy is high build sandable primer?
I have been playing with my doors lately too.
mcbassin is offline   Reply With Quote
Old 01-21-2014, 05:35 PM   #406
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Yessir it is high build sandable. I've got everything except the bed (saving it for last) now done this way. Gonna fit and fit, then do any filler work, glazing and blocking.
Jimmy
.69SWB Build.
Old 01-21-2014, 05:40 PM   #407
Bennett68C10
Bennett68C10's Avatar
Re: Project 69SWB
Nice job on the doors Jimmy, are you spraying in your garage and is it attached to your house. Mine is and more specifically it's attached to my kitchen. Just wanting to know how the fumes are. I don't know what to do for mine.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-21-2014, 06:33 PM   #408
gdavis
gdavis's Avatar
Re: Project 69SWB
I like the way you hung the door to paint them. it will work.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 01-21-2014, 11:02 PM   #409
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Keith, Yes I am and mine goes into the laundry room then the kitchen. I keep the door shut and just go in/out the front door while the fumes are bad otherwise as soon as I open the door it's sucks it right in the house. So be wary. You'll can see in one of the pics I crack the door a bit, then crawl under to get in or out... using the remote.
Thanks George, I'll have to get a longer board to get out and away from the ladder a tad for when I lay the color, was kind hard spraying around that close to the ladder... worked fine for the primer though.
Jimmy
.69SWB Build.
Old 01-21-2014, 11:39 PM   #410
Bomp
Bomp's Avatar
Re: Project 69SWB
I bought some of that PC-7 for a wheel fix planned in the near future. How long can you mess with it before it gets too hard?
And your doors look killer along with the ladder set up.
Great progress
Bomp is offline   Reply With Quote
Old 01-22-2014, 06:19 PM   #411
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Great progress
Thanks! Says remains workable for 1 hour at 70deg on the can. I messed with it for a good 30 minutes and it was still pretty gooey. Even went and checked on it after a couple hours and it was still tacky and soft but I don't think I could have molded it at that point. I did this all in the house so it was about 68degree-ish
Jimmy
.69SWB Build.
Old 01-26-2014, 07:54 PM   #412
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I was going to work on the steering wheel resto this weekend, but I couldn't wait to get the doors back on and start lining this truck up... so I worked on putting the doors and fenders on this weekend so I can do final body work...
The doors are lined up and shutting great using GMCpauls door seals.. They're top notch. I put those on so the doors will be just where I want them as I'm working. I also rolled it out into the sunshine (it's been a while). after body work I get to take it all apart again to paint it. I still need to fit the fenders better, but the doors are shutting and fitting great. I was losing sunshine in the driveway and wanting to get some good pics so I had to stop and roll it out. Cold weather returns tomorrow. :-/
Obligatory favorite modes of transportation bff shot
and all tucked back into the garage.. time to get serious on body panel alignment.
Jimmy
.69SWB Build.
Old 01-26-2014, 08:05 PM   #413
sduckworth13
sduckworth13's Avatar
Re: Project 69SWB
Doors are looking awesome Jimmy, they look super smooth. You did a excellent job on them.
Scott
sduckworth13 is offline   Reply With Quote
Old 01-26-2014, 08:33 PM   #414
Bennett68C10
Re: Project 69SWB
Nice job Jimmy she's looking good
Keith
66 Suburban
IG: bennett68c10
Old 01-26-2014, 09:20 PM   #415
mcbassin
Still Learning
mcbassin's Avatar
Re: Project 69SWB
Awesome progress on the doors and fenders. I took advantage of that nice weather myself. Back to arctic tomorrow ...
Old 01-26-2014, 10:31 PM   #416
jmking9
jmking9's Avatar
Re: Project 69SWB
Looks great man! How's your motivation level after seeing it sitting outside like that? A 10? I pushed my cj7 outside today to wet sand the high build, and something about seeing sitting outside again, lit the fire. Anyway, your truck is gonna look awesome when you get that black on!
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 01-26-2014, 10:53 PM   #417
KSWes
KSWes's Avatar
Re: Project 69SWB
Sweet! Coming together nicely!
70 Chevy C10 LWB
My Build:http://67-72chevytrucks.com/vboard/s...d.php?t=513002
KSWes is offline   Reply With Quote
Old 01-26-2014, 10:58 PM   #418
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks Scott! I just gotta get it all smooth and level like now. The Black is very unforgiving!
Thanks Keith... Still get a long way to go but I'm happy so far.
Thanks Mike! I'm tired of this artic weather... Ready for summer so I can complain about the heat instead. ;-)
My next door neighbor offered to pull me around the block so I could take it for a spin. Ha! Yes seeing it outside the garage got me going. I just got in from the garage a bit ago. Had to at least get one side good and straight. Just got the passenger side left to do then the cowl. My hood is already painted so I'm reluctant to put it on, don't want to scratch it but I have to at some point anyway; so I guess I will, but it'll be taped up big time.
You're making me want to build another jeep with that jeep talk.
Here's my last one. I sold it though. :-(
Here my last jeep fresh out of the garage.
http://ozarksjeepthing.com/c/index.p....html#msg56305
And out in the trails during its shakedown run.
http://ozarksjeepthing.com/c/index.p....html#msg56311
Those are deep links to my build thread on that site if you ever get bored check it out... I did a ton of fabricating on that jeep. 1 ton axles, 40" pit bull rockers, locked front and rear, twin stick too.
Jimmy
.69SWB Build.
Old 01-26-2014, 11:52 PM   #419
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Thanks Wes!
Jimmy
.69SWB Build.
Old 01-27-2014, 09:27 AM   #420
Low Elco
Re: Project 69SWB
Nice and straight in prime! That's the bad part, you just wanna slap 'em the rest of the way together and go!
Old 01-27-2014, 10:18 AM   #421
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Oh do I know. The thought did cross my mind, but I've got a little filler work to do, some glazing, and lots of blocking. I want this thing to be straight! I'm working with all original metal here... save for the rockers, inner cab supports, and cab corners.
Jimmy
.69SWB Build.
Old 01-27-2014, 12:34 PM   #422
vegadesign
vegadesign's Avatar
Re: Project 69SWB
Looking good!
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 01-27-2014, 07:17 PM   #423
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by vegadesign View Post
Looking good!
Thanks a bunch. Checked out your thread. Super mad skills man!
Jimmy
.69SWB Build.
Old 02-01-2014, 01:12 AM   #424
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Re: Project 69SWB
Jimmy just got through the rest of your build. You have came along way since I last seen it. Looks really good. Now get it done so we can cruse in them this summer.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 02-01-2014, 09:40 PM   #425
CC69Rat
CC69Rat's Avatar
Re: Project 69SWB
Wow you've made some progress ! Nice job man,.. keep at it.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
1969, black, custom 10, fleetside, shortbed
