Old 11-01-2015, 08:46 PM   #401
racecougar
racecougar's Avatar
Re: Bringing the '65 back to life
Thanks. I started to install them, noted that they were indeed a pain to install but also that I didn't really like the look of them sticking through the firewall, and then went the SS route.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 11-08-2015, 05:14 PM   #402
racecougar
racecougar's Avatar
Took the weekend off from the '65 to build shelves and organize the back room of the shop, which included boxing and labeling a bunch of the parts for the truck. No more hunting the shop for random truck parts.
Old 11-14-2015, 06:54 PM   #403
racecougar
racecougar's Avatar
Deleted the antenna hole today. I'm not 100% positive where the antenna will end up yet, but it won't be here.
But in bigger news: we picked up a donor this morning. It's a '02 2WD Suburban 1500 with the 5.3L/4L60E combo. It's a boat, but it runs well.
Old 11-14-2015, 10:14 PM   #404
dwcardfan
dwcardfan's Avatar
Nice donor!
dwcardfan is offline   Reply With Quote
Old 11-15-2015, 04:04 PM   #405
racecougar
racecougar's Avatar
Yeah, I think it'll do for now.
Stripped and body-worked the outer cowl panels today.
Old 11-21-2015, 04:41 PM   #406
racecougar
racecougar's Avatar
Dad stripped the cowl during the week, and we got those pieces into primer today.
Old 11-22-2015, 04:05 PM   #407
racecougar
racecougar's Avatar
We tore down a later-model (late-70's - mid-80's) GM truck 12-bolt today to rob the backing plates off of it. The plan is to narrow the original '65 12-bolt to achieve the deep-dished wide rear wheel look we're after. While doing so, we'll incorporate Ford-style housing ends to eliminate the C-clips, and we'll switch the stock 11" x 2-1/2" drums over to the later GM truck 11-5/32" x 2-3/4" drums for a decent increase in brake shoe surface area.
Old 11-22-2015, 08:59 PM   #408
racecougar
racecougar's Avatar
EDIT: The stock drums are 11" x 2", not 2-1/2".
Old 11-25-2015, 05:25 PM   #409
racecougar
racecougar's Avatar
Took the '65 out for a spin today, literally. We turned it around and backed it into the shop, as the rear axle will be coming back out shortly.
Old 11-25-2015, 08:14 PM   #410
racecougar
racecougar's Avatar
And then the packages arrived...mamacita!
15x12" Cragar S/S's, Moser housing ends and retainers, and a set of fixture bushings for lining everything up when we cut down the axle housing.
Old 11-26-2015, 01:35 PM   #411
racecougar
racecougar's Avatar
Shooting a little primer on Turkey Day.
Old 11-26-2015, 03:51 PM   #412
deejaaa1
great build and documentation.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 11-27-2015, 05:50 PM   #413
racecougar
racecougar's Avatar
Thanks!
Pulled the rear axle this morning and drained it, then shot the first coat of satin black on the cowl pieces.
Old 11-28-2015, 02:25 PM   #414
racecougar
racecougar's Avatar
Day 195: The rear axle housing is ready to be degreased and blasted, and the cowl pieces received the final coat of satin black.
Old 11-29-2015, 04:57 PM   #415
racecougar
racecougar's Avatar
Spent the morning cleaning and priming the wiper transmission and the rain baffle for the heater inlet, then we took the rear axle over to the quarter car wash for a quick degreasing. Hoping to get it blasted and primed this week.
Old 12-01-2015, 08:38 PM   #416
racecougar
racecougar's Avatar
Dad had the axle and backing plates blasted today. I swung by after work and shot some primer to keep the rust monster away.
Old 12-05-2015, 03:55 PM   #417
racecougar
racecougar's Avatar
Installed the dome light, glovebox latch, wiper motor, wiper transmission, cowl pieces, emblems, etc. today. The outer cowl panels will come back off in order to install the front fenders later, so they're just stuck on there finger-tight for now.
Old 12-06-2015, 06:02 PM   #418
racecougar
racecougar's Avatar
Dad finished up the passenger side door and installed the door panel this morning, while I spent the day methodically welding the axle tubes to the housing.
Old 12-21-2015, 05:08 PM   #419
racecougar
racecougar's Avatar
Day 200! AKA axle choppin' day. Dad began machining the wood for the bed floor while I took 7" out of the original 12-bolt (3-1/2" off each side) and installed a pair of Moser 7950 housing ends. These ends retain the stock brake mounting pattern while converting to the big Ford 3.15" axle bearings and retainer plates, thereby eliminating the need for C-clips.
Measure fifty-eight times...cut once.
Old 12-22-2015, 03:10 PM   #420
racecougar
racecougar's Avatar
Welded up the ends today, cleaned the housing, then set it back on the trailing arms. Dad finished the machine work on the bed floor boards.
The housing is now 50" end to end. It was 57" originally; already 1-1/2" narrower than the later truck 12-bolts.
Old 12-23-2015, 04:33 PM   #421
racecougar
racecougar's Avatar
Spent the morning laying out the e-brake cable routing, removing the factory bumpstop brackets, and beginning the task of filling out the order form for axle shafts.
Old 12-24-2015, 10:12 AM   #422
Ta2Don
Ta2Don's Avatar
Looking great...
Merry Christmas to you and yours!!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 12-26-2015, 03:49 PM   #423
racecougar
racecougar's Avatar
Merry Christmas to you!
Took a couple days off to celebrate Christmas with the family, but we got back to it today. The trailing arms each received a little tapped pad to secure the e-brake cables, and we've gathered together a few parts for paint.
Old 12-27-2015, 05:35 PM   #424
racecougar
racecougar's Avatar
Long day at the shop today. Prepped and primed the trailing arms, rear coils, U-bolts, spring retainers, axle housing, backing plates, shock mounts, and steering wheel. Items in white will end up in silver hammertone. Items in red oxide will end up in gloss black.
Old 12-28-2015, 01:11 PM   #425
racecougar
racecougar's Avatar
Shot the first coat of black this morning. Also brushed the holes in the trailing arms to ensure complete coverage.
