01-12-2018, 01:22 AM | #401 |
Re: What did you do to your truck today part IV
(just the other day) I installed a much needed heater to keep the windshield from fogging up at night on these brisk LA winter nights
Not pictured, but I ran some flexible hose from two of the ports up to the windshield defroster vents. Little heater works like a champ
- 1964 Chevy C10 "Honeydew" http://instagram.com/zachiatrist http://zachiatrist.com |
01-12-2018, 12:41 PM | #402 |
"(just the other day) I installed a much needed heater to keep the windshield from fogging up at night on these brisk LA winter nights "
It is sure getting cold here I can almost see my breath in the air some mornings. |
01-12-2018, 12:53 PM | #403 |
you guys are killing me!!!
01-12-2018, 01:31 PM | #404 |
Picked up a new to me hood for Our 63
01-12-2018, 02:41 PM | #405 | |
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
01-12-2018, 02:44 PM | #406 |
Thank you! My shift-boot-hat is always a hit. Yeah I'm working on gathering up all my past photos from when I got the truck up to now and making a sort of build/progress thread.
01-13-2018, 01:58 PM | #407 |
Started the inside wiring fun now.
01-13-2018, 04:21 PM | #408 |
Some of that modern new-fangled techie wiring.
Nice looking job so far on it.
01-13-2018, 05:17 PM | #409 |
Ahh I remember the good old days of wiring up the Dakota Digital box. Looking good man
01-13-2018, 06:27 PM | #410 |
Dressed up my engine bay a bit with some aluminum stamped radiator support shrouds, carbon dipped plenum cover, and some raw aluminum coil covers
The LS3 is tucked back there pretty tight so I had to make some cuts on each one to get it to fit against the firewall.
01-13-2018, 10:56 PM | #411 |
Man, I'm loving your truck Zac. Are the rad support covers commercially available, or did you make them?
01-13-2018, 11:35 PM | #412 |
I am next in line i need a set made. lol
01-14-2018, 04:11 AM | #413 | |
I wish I had the tools to make them. But if you go modshopinc.net/store and search over on the left hand side under Radiator Support Filler Panels you'll find them there.. a few different pattern styles. They took a little massaging to get them to fit in perfectly, and I had to re-drill a couple of the pre-drilled holes to line up with the holes on my truck.. but nothing major. I also rivetted down the two front corners to keep them both snugged down and inline with eachother.
01-14-2018, 11:42 AM | #414 |
Thanks for the info. I am going to get a set.
01-14-2018, 09:23 PM | #415 |
I put some rust converter in my rear cab corner pockets. I am worried because it said to put on a second coat with in 20 minuets and after it turns black but it never turned black. I don’t know if it’s because the first coat was too heavy or because there was some navel jelly left on the surface. I hope not the latter. I tried to clean it off the best I could considering the location. I will see how it looks next weekend. I also found some rust on the interior where the door frame connects to the floor. Another set back
01-15-2018, 07:39 AM | #416 |
Junior Member
Changed the oil, love the old oil canister, and NAPA filter!
01-25-2018, 03:06 PM | #417 |
swapped the p.o.s. POL lower control arms for some Ridetech StrongArms. Some of the best money I ever spent on the old girl. Went from feeling every single little bump and crack in the road to just gliding over it like driving on a soft pad of butter haha.
02-03-2018, 07:12 PM | #418 |
Started making a speaker box in my kick board vents.
02-03-2018, 07:12 PM | #419 |
Sorry for the sideways pic
02-03-2018, 07:34 PM | #420 |
pulled the cab!
02-04-2018, 07:20 PM | #421 |
Got the insides of my doors painted. Just need to do a final coat on the interior back walls.
02-04-2018, 07:41 PM | #422 |
1965 Chevy C10, 2005 4.8L/4l60
I went to the paint shop a visited....got these pix
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-04-2018, 07:48 PM | #423 |
I put it up for sale.
02-04-2018, 09:43 PM | #424 |
It's Better With Nitro
Brian Stoner of Stoner Pinstriping came back today to finish striping the tailgate. A few shots of his work today and the hood he did a few months back:
02-05-2018, 11:11 AM | #425 |
I finally got the front clip re-assembled completely. Now to take a break for awhile and then to tackle the cab.
