Old 08-29-2020, 07:09 PM   #401
Kronald_70GMC
Kronald_70GMC's Avatar
Re: My 1970 GMC Project
Originally Posted by gmc684x4 View Post
Nice work
I have seen cardboard as backer for bondo on rusty trucks seen a bronco where the fellow rivited the patch panels over the rust spots
My aim will be after i get a mig to make my work look close to yours
Practice will help
I seen a trick one fellow showed me make the patch and the panel trimmed close to same size tack the two together use zip disk cut at a 45 degree angle back tack the fresh cut flush make the next cut and continue until you have the patch completely flush fit finish welding and watch how much heat you drive into the panel
That sounds like a pretty cool trick. And thanks for the compliment
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 08-29-2020, 11:08 PM   #402
Kronald_70GMC
Spent the evening doing a much needed tidy in the shop. After that I used my rust and paint wheel to smooth up the door and half of the cab back. I also got the rocker pulled out so that I can clean it and prep for welding that in. Its really starting to look like a full cab again......Finally
Kyle
IG: kyle_ronald
Old 09-24-2020, 11:40 PM   #403
Kronald_70GMC
Well shoot, its been damn near a month since my last post. Figured I'd better make time this evening and get some progress in. I have removed the fender and door to gain access to the inner rocker area. I spent the evening cleaning up some rust and welding up those holes where the bolts held in the cab support. I wanted to eliminate them so that the inside of my rocker will be nice and smooth and easy to clean in the future. Here's hoping that it won't be a month until I make the next post
Kyle
IG: kyle_ronald
Old 09-26-2020, 07:36 PM   #404
chewychevy67
Looks good.
chewychevy67 is offline   Reply With Quote
Old 10-25-2020, 10:12 PM   #405
Kronald_70GMC
Well so much for that. Another month gone and still nothing overly big to post about. On a positive note, my dad and I managed to get my square body front end all apart without getting hurt by the springs. Now I have alot of floor space back in the shop. I have been very occupied with home renovations still and it is taking up all my free time. I have just recently removed the single door at the back of my house and replaced it with a nice set of garden doors. Im glad that is complete before winter has shown up. Hoping to make some more shop time soon.
Kyle
IG: kyle_ronald
Old 10-25-2020, 11:05 PM   #406
TA_C10
TA_C10's Avatar
Truck looks good just sitting there bare skin.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 10-26-2020, 12:22 AM   #407
cornerstone
cornerstone's Avatar
Originally Posted by kronald_70gmc View Post
i have been very occupied with home renovations still and it is taking up all my free time.
there are a few of us who have been in this same boat!
hoping to make some more shop time soon.
i'm right there with ya man... Hoping for a fairly mild winter here in texas so i can get back to being productive again.
111
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 11-28-2020, 12:56 AM   #408
Kronald_70GMC
Well another month has gone by and tonight I decided that it was time to get another evening in. Im aiming to be back to at least one night a week on the ol girl. Tonight I have mostly got my rocker prepped and ready to weld in but im having a few issues with it fitting to the inner rocker so I will need to address that first, it also needs the usual slice and dice at the ends. Ive spent almost the whole evening playing around with panel gaps. I think that I have found the sweet spot though, it will be getting some more refinement in body work stage as well. The only gap that is not that nice is the lower door to rocker gap which is currently at 3/8". Not a big problem though as I will be re skining the lower door and can add my 1/4" to the door at that point. I even threw the cowl panel on just to see how it would line up. It appears to be wide but I'm not sure on that one yet. I also ended up having to dimple in a small recess into the windshield pillar as the front of the door was touching the cab there. I just traced the door line onto the cab and slowly chased it with a hammer and chisel until it looked right. I think it worked out nicely and I do not think it will be at all noticeable.
Kyle
IG: kyle_ronald
Old 11-29-2020, 10:02 PM   #409
Getter-Done
Getter-Done's Avatar
Those gaps are looking good I know you will get them spot on.
Time and patience pays off.
84 Chevy K-20
Old 11-29-2020, 11:14 PM   #410
Kronald_70GMC
Thank you sir. Im excited to get this rocker in but I can't rush or I will make a mistake. It will happen soon enough.
Kyle
IG: kyle_ronald
Old 12-03-2020, 12:05 AM   #411
Kronald_70GMC
Well my evening did not go as planned. I was trying to clearance my door gap at the top a bit more and I blew it. I ended up running the metal too thin and now I am back to square one on my door jamb. Not too horrible though, I started to weld up my issue and it is going ok. What is horrible is my welder! I'm just losing my mind over here. The thing will not weld hardly at all like it should. I keep having the wire melt and drip off the gun before I can make contact with the metal. I think it might be time to replace this old relic. Then maybe I can actually get something done in an evening other than waste all my wire on the floor.
Kyle
IG: kyle_ronald
Old 12-03-2020, 10:59 AM   #412
TA_C10
TA_C10's Avatar
That sucks about your welder. It's looking good though!
"It's only money".
Old 12-03-2020, 03:18 PM   #413
Kronald_70GMC
Hey thanks man! I'm thinking my welder will no longer be a problem soon....
Kyle
IG: kyle_ronald
Old 12-03-2020, 09:01 PM   #414
Kronald_70GMC
Well this will help me out im sure.
Kyle
IG: kyle_ronald
Old 12-03-2020, 11:08 PM   #415
Scurry67
Great choice! I have the same one and have been really impressed with it.
Keep up the progress!
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 12-03-2020, 11:51 PM   #416
Kronald_70GMC
Oh man I'm VERY happy with it. I didn't get a whole lot of welding done by the time I got it all set up, but I did do a bit and I'm impressed. I welded a handle onto my welder cart so that is great.
Kyle
IG: kyle_ronald
Old 12-04-2020, 09:10 AM   #417
May70
May70's Avatar
I have the 210mvp and it is incredible. Very happy with Hobart
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 12-05-2020, 07:14 PM   #418
desertnick69
desertnick69's Avatar
I just have to say I have to hand it to you guys that have to repair the whole floor and the door pillers, You have got to have a real love for these trucks or is it just the challenge. Anyway it looks real good.
desertnick69 is offline   Reply With Quote
Old 12-06-2020, 11:34 AM   #419
Kronald_70GMC
Thank you for the compliments, its a bit of both really.
Kyle
IG: kyle_ronald
Old 12-08-2020, 12:24 AM   #420
Kronald_70GMC
Tonight was a good night. I got the rest of the upper door jamb welded shut as well as fixed my hole that I made the other night.
Kyle
IG: kyle_ronald
Old 12-10-2020, 12:17 AM   #421
Kronald_70GMC
Tonight was rocker fun time. I had to make, yep you guessed it, relief cuts to accomplish the proper fit. I had one in the rocker itself and two on the lower pillar repair panel. As I had guessed, the missing curve from below the lower body line caused me a small issue. I had no backing for the three plug welds that go in that area. So I added the curve back in using two relief cuts. Looks much better now. Next task will be at the front pillar. I may have to do something along the floor as well but only time will tell for sure.
Kyle
IG: kyle_ronald
Old 12-10-2020, 11:16 AM   #422
TA_C10
TA_C10's Avatar
Precision.
"It's only money".
Old 12-22-2020, 12:03 AM   #423
Kronald_70GMC
One of these days I will have this rocker welded in. I have now fixed the fit to both pillars so the hard part is out of the way. Well maybe. I'm not sure how to address my next issue. I have about a 1/4" gap between the rocker edge and the cab floor but it is only bad like that near the front. At the rear, it sits flush. I have not decided on what to do with this issue yet. I was thinking about using some sort of a shim to get what I need but part of me wants to section the floor pan yet again to get it where I need it. What are your guys thoughts?
Kyle
IG: kyle_ronald
Old 12-22-2020, 12:04 AM   #424
Kronald_70GMC
Precision.
Thank you sir. Sometimes I feel like I'm going way to overboard but I just don't want to be unhappy with it in the end.
Kyle
IG: kyle_ronald
Old 12-22-2020, 10:25 AM   #425
1971Stepside
Almost Satisfied
1971Stepside's Avatar
You have came this far. Re-section the floor and make it perfect. You sound like me and if that is the case it will drive you nuts to do anything but the right thing....you are just way more patient than I am and a better welder, a better grinder, and better rust repair guy
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
