10-31-2019, 09:20 AM | #401 |
Re: TA_C10: Stage 1
I have the same plug in the back of my intake manifold, I was wondering what that was. I'm just leaving mine plugged since I have hydroboost.
It's exciting to see our interiors coming together!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
10-31-2019, 12:22 PM | #402 | ||
Re: TA_C10: Stage 1
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
10-31-2019, 07:22 PM | #403 |
Re: TA_C10: Stage 1
Just found out it appears the steering coupler on the rag joint is a different diameter depending on power steering gear vs manual steering gear..... I had a manual steering gear before. Now that I went power, the coupler doesn't seem to fit.... Rebuilt that for nothing...
10-31-2019, 09:10 PM | #404 |
Re: TA_C10: Stage 1
Just do the Jeep XJ shaft swap/upgrade.
10-31-2019, 11:53 PM | #405 |
Re: TA_C10: Stage 1
Damn man you're in a roll lately! Coming together nicely! Did you get your new harness in yet? Interested to see what the bulk head connector looks like.
11-01-2019, 12:07 AM | #406 |
Re: TA_C10: Stage 1
Scoti thanks, I will look into that upgrade. Siggy thanks man, I am sending back the deluxe universal I got and getting the full classic update harness. Brothers is hooking me up with this. Shipping it off tomorrow.
Blaster brought back everything tonight, it all looks great, hardly any body filler found on everything. Bed, doors, fenders, etc. So tomorrow I'm going to be painting everything with epoxy. Big day. Then over the weekend I'm going to try and get some body work done filling holes in doors and minor dent repair on fenders. I might have time to sand my hood and epoxy that too. It's been sitting bare metal now for six months or longer. I sprayed it with that dry coat stuff and it really did a great job keeping it from rusting.
11-01-2019, 09:22 AM | #407 |
Re: TA_C10: Stage 1
You can always count on your truck to surprise you. But that's good to know on the steering since I had manual gear before.
11-01-2019, 10:21 AM | #408 | |
Re: TA_C10: Stage 1
http://67-72chevytrucks.com/vboard/s...d.php?t=505196
11-01-2019, 09:37 PM | #409 | ||
Re: TA_C10: Stage 1
11-01-2019, 09:40 PM | #410 |
Re: TA_C10: Stage 1
I had to build some racks to hang parts for paint today. Hoping to get all the parts in epoxy tomorrow. Bed, grill, fenders, cowl, hood, hood hinges, rear wheel tubs, rear fender splash guards, and the LS alternator and power steering bracket.
11-02-2019, 11:31 AM | #411 |
Almost Satisfied
Re: TA_C10: Stage 1
It's amazing how much work goes into being able to do the work sometimes. I'm hoping to epoxy my bed on Monday evening.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
11-03-2019, 11:10 AM | #412 |
Re: TA_C10: Stage 1
Excellent idea for temporary racks!
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
11-03-2019, 12:05 PM | #413 | |
Re: TA_C10: Stage 1
Did you take your bed apart? Can't remember. My bed ended up being in pretty dang good shape rust wise. Very little pitting. Thanks man, I just threw these together on a whim. Two 16ft two by's, four 8 footers, and a spool of 12awg wire. Cost like $25 in wood and the wire was $12 ish I think. I already had the 2.5" drywall screws so I only spent I wanted a short rack but should have just made 2 talls. The short rack I cut the 8ft down to 6ft. When I hung the big long bed sides only 1 for per rack so the short rack hung a little low so it was kinda difficult to get the paint gun underneath. But I made it. Today is day three, still not done. I have the bed rails and doors left to spray. Glad I took Friday off jeez.... I'm hurtin boys, I'm living on Advil today and probably next two days...
11-03-2019, 11:52 PM | #414 |
Re: TA_C10: Stage 1
Well everything has epoxy now... Been a long 3 days. A couple of parts even got a little color
Pics for your viewing pleasure.
11-04-2019, 12:25 PM | #415 |
Re: TA_C10: Stage 1
Nice work on those stands. I remember how sore I was after my big day of painting haha.
11-05-2019, 11:56 AM | #416 | |
Almost Satisfied
Re: TA_C10: Stage 1
11-05-2019, 08:55 PM | #417 | ||
Re: TA_C10: Stage 1
11-07-2019, 09:15 PM | #418 |
Re: TA_C10: Stage 1
Update - Steering Shaft / Rag Joint Complete
Got the steering shaft installed. New rag joint came in. The new rag joint was a larger diameter as you can see in the photos below. It still took some manipulating however, had to use a little persuasion to get it started then it slid right on. I lined up the section in the joint that was smoothed(no teeth) with the flat end on the steering gear shaft. Then of coarse after I got the shaft installed, I noticed I forgot the retaining collar for the top part of shaft, so i had to take it back off again and beat the shaft off the steering column with a big rubber mallet... Then I finished the shaft and slid the steering column back down where it needed to be and noticed it got scratched/chipped by the firewall collar rubbing on it while i was doing all this work... Whatever. Easy fix but dang it..... Old joint New joint
11-08-2019, 01:26 AM | #419 |
Re: TA_C10: Stage 1
Killer progress man.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. Last edited by cornerstone; 11-08-2019 at 01:34 AM. |
11-11-2019, 12:26 PM | #420 |
Re: TA_C10: Stage 1
Where did you get that shift indicator? That will match my 4L80E perfect.
I just ordered a new rag joint and my rebuilt van conversion column is on order and I'm hoping it all goes together.
11-11-2019, 12:53 PM | #421 |
Re: TA_C10: Stage 1
70shortfleet built the column for me. I asked for the indicator. It's also been shorten 2" for my height, tilt, and he shipped with cruise control turn signal. He does great work.
11-11-2019, 01:37 PM | #422 |
Re: TA_C10: Stage 1
Update - Brakes
This thing can now stop on it's own! I fought leaks for 2 days. But it was all my fault really. But there was a union that was ruined because of the line flare, it wasn't even so when it made it's impression inside the union it was angled and didn't seal. I had to re-bend both of the SS lines going from frame to prop valve. Actually wasn't as bad as I though. They aren't perfect but they will do. I was able to straighten the lines completely and then start over using a large socket to make my pigtail coils. Check out post 395 to see the before pics of the SS brake lines before I re-bent them. I ended up cutting the flares off both sides of this union. I got a compression union from local hardware store to replace. It sealed perfectly and I think the compression union was a better choice anyways. This guy, the crush washers that came with the kit didn't have thick enough washers. Only one thick washer... So the passenger side sealed just fine. The driver side ended up leaking like crazy so I doubled up the washers on the caliper side. Sealing just find now. I don't think your supposed to double them up but it's all I had.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". Last edited by TA_C10; 11-11-2019 at 04:32 PM. |
11-11-2019, 02:37 PM | #423 |
Re: TA_C10: Stage 1
He's doing mine as well. I'll ask him if we can do the same indicator.
11-11-2019, 02:42 PM | #424 |
Re: TA_C10: Stage 1
I remember having the same issues on my dad's stainless lines. Almost every fitting had a leak, but eventually we got them sealed up by loosening, tightening, loosening, tightening, and tightening more than we thought necessary. We had the most trouble with the banjo bolts but eventually got them to seal up. I'm nervous about a couple of my flares that I made on mine. I guess we'll see what happens.
Stainless looks a lot nicer than mild steel!
11-11-2019, 03:54 PM | #425 | |
Re: TA_C10: Stage 1
I fought like 5 different leaks in the system. Felt like SS was the wrong way to go at that point but then I found out I just didn't tighten 3 of them. Then the one union that I had to replace, it wasn't bad after I thought about the compression sleeves. And the caliper banjo crush washers were an easy fix too, just had to go to store to get correct stuff. I bought a $30 pneumatic brake bleeder kit from HF that is really cool. Bottle sits on MC, open the valve, it keeps the fluid full for you. Then you go to each wheel like normal and the air hose creates vacuum and pulls the fluid and air out for you pretty quick. I like it EDIT: I forgot to mention also that I just dropped off my tailgate, one of the front fenders, and drivers bed side for metal repairs. Fender has rust holes and few other small things to fix, bed side has a big dent/crease from the bumper hitting it at some point in its life, and the tailgate needs a new outer skin, it wasn't worth fixing. I am running out of time and need help so I decided to let a local guy fix these for me. I still have some work to do on the other pieces but this is the big stuff and he can do a better job while I put the rest of truck together. .
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". Last edited by TA_C10; 11-11-2019 at 04:38 PM. |
