09-25-2016, 03:32 PM | #4401 |
Re: What did you do to your truck today? Chapter II
Hey jrainman,Are you a tinknocker?
09-25-2016, 07:04 PM | #4402 |
Removed an alarm system that was installed and fixed some hacked wires! Talk about a P.I.T.A. Finding wires dangling and not going anywhere! The good thing is it starts and all lights work.
1970 C-10 LWB 1998 Jeep Wrangled TJ 2009 Honda VTX 1300 2013 Buick Enclave |
09-25-2016, 07:38 PM | #4403 |
Went to the Humble swap meet this morning, found some leather seats for my truck just have to make some brackets.
09-26-2016, 09:32 PM | #4404 |
I picked up my epoxy primed original fender and dropped it off with the painter.
09-26-2016, 10:32 PM | #4405 |
I cut out the back glass, inner rocker and A and B pillars. I also trimmed up the replacements, laid in the inner rocker/ floor piece and screwed it down so I can cut out the off stuff.I also fitted up the outer rocker and clamped it down. I got along pretty good on it today. Hopefully tomorrow I can get a good bit of it welded up. Once I get both sides in I'll put it on the flipper dolly and do the cosmetics for the floor and rockers. Of course sale day is Wed so I may have to quit on it again. Normally when I get my old truck in the shop to work on it I get a transport load of wrecks soon after.
09-26-2016, 10:45 PM | #4406 |
I built my transmission crossmember.
09-26-2016, 10:52 PM | #4407 |
I got started building my new seat brackets, there just isn't enough time in a day especially when you don't get home till after 6 O'Clock.
09-26-2016, 11:11 PM | #4408 |
And I got started on strengthening my front crossmember in order to fit the new gen 5 lt 😀. In this photo I'm using cardboard to get the shapes I need to cut out of plate steel.
09-26-2016, 11:17 PM | #4409 |
Got rid of my Eddy 750 CFM on my 402 and put in a Quick Fuel 680 with Vacuum Secondaries and put it on the dyno.
Love this carb! Blows the doors off the Edelbrock. |
09-27-2016, 08:10 PM | #4410 |
Stripped down my newly acquired Buddy seat , sending frame out to powder coating & researching new foam & upholstery kit . Removed grill to have it polished .
09-27-2016, 08:17 PM | #4411 |
I received my new KKS radiator today. I inspected it out of the box and it looks very nice.
I'll try and test fit it into the core support tomorrow. |
09-28-2016, 12:35 AM | #4412 |
I went from a 12 inch oval air cleaner to a 14 inch round, 3 inch high... I like having more of the carburetor covered, and the smaller one looked a little too small.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
09-28-2016, 08:50 AM | #4413 |
Where did you get the adjusting alternator arm/bracket? It just looks cooler than the factory style bracket.
09-28-2016, 10:26 AM | #4414 |
If I remember right - from summit - along with the triangular shaped mount on the bottom. Agreed - wasn't thrilled with the black bracket covering the top. The alternator was a replacement (Power Master) because the other was faulty when I purchased the truck. The brand was March, I believe.
09-28-2016, 11:02 AM | #4415 |
Thanks! I found the March ones, Summit also had their own, much cheaper, I wonder how the quality is?
09-28-2016, 07:35 PM | #4416 |
Got my Trim Parts black carpet in and new sill plates...nice fit, just needed to trim the back by the tank.
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
09-28-2016, 09:27 PM | #4417 |
I sought new wheel cylinders- the three letter company sent ill-fitting versions... Nobody believes that I have leafs on my 67 127" 3/4 T 2wd BB V6 305.
Thanks, Kevin '67 GMC C2500 305 V6 Power Nothing |
09-28-2016, 09:28 PM | #4418 |
Sweet look and a quick cleanup. Nice!
09-28-2016, 09:47 PM | #4419 | |
Beautiful engine bay. |
09-30-2016, 10:49 AM | #4420 |
I installed my new HID lights with halo's.
09-30-2016, 10:58 AM | #4421 |
those look great! where did you get them, what brand, how much?
09-30-2016, 12:12 PM | #4422 |
Thank you, I picked them up from Octane Lighting for $218 shipped.
09-30-2016, 03:29 PM | #4423 |
I bought them at the Portland swap meet one spring. Unfortunately, I do not know the brand, but I see so many on Ebay as nostalgia style? That is also where I found the air cleaner. I just did a seach on Ebay for finned valve covers and air cleaner and found several. There was also a set on the first page advertised as tall. Thank you!
09-30-2016, 03:33 PM | #4424 |
Last night I added a new turn signal lever.
10-01-2016, 07:12 PM | #4425 |
I worked on the truck all day! Intense effort.
I put my locking gas cap back on, picked up a quart of POR 15 substitute (forgot the name of it), and ran that over to the painter. |
