Old 02-01-2009, 01:59 AM   #426
Rokcrln
Rokcrln's Avatar
Re: Project Lemon Drop: anything but stock!
Do I have to do everything for you!
http://maps.live.com/localsearch/det...Yp02&mkt=en-us
Same place I use.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 02-01-2009, 10:02 AM   #427
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Originally Posted by jugernot View Post
pcorriveau951,
Just another thought, you could probable also put the harness through this area, but of course on the drivers side.
Just a thought, how will you tighten the fittings on the other side (in vent area inside the truck), when you put all the hoses in?
FuelCellGuy is offline   Reply With Quote
Old 02-01-2009, 08:52 PM   #428
jugernot
Life, Be In It.....
jugernot's Avatar
The lower hoses (heater hoses) will go in first, one at a time. The other two there is just enough room to get an open end wrech in to tighten the fittings.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 02-01-2009, 08:55 PM   #429
jugernot
Life, Be In It.....
jugernot's Avatar
Same place I use.
Kevin
LFD Inc.
Looks light a road trip..............How are the prices?
Old 02-01-2009, 10:26 PM   #430
Rokcrln
Rokcrln's Avatar
High like everything else these days. Call first with just what you need to see how much and make sure they have it in stock. If you get it set up I can swing by and pick it up for you as well.
Kevin
LFD Inc.
Here is a sneak peak of my weekends progress!
And yes it will drive this low! I think next time you and I go to the goodguys show we need to just drive around like everyone else. It will sure make buying parts allot easier!
Old 02-03-2009, 12:29 AM   #431
jugernot
Life, Be In It.....
jugernot's Avatar
Very Nice, I Like. Did you ever find out what those rivit things in the doors were for? Goodguys, yes we do need to go to the next show, when is it. Oh here we go.......Lucky me I'm off that weekend too.
27th All American Get Together
Mar. 28 - Mar. 29, 2009
Alameda County Fairgrounds
Old 02-03-2009, 07:58 AM   #432
Rokcrln
Rokcrln's Avatar
Rivit's, I don't recall them but as for the show were their, we will be walking this time but we are so their!
Kevin
LFD Inc.
Old 02-20-2009, 08:18 PM   #433
jugernot
Life, Be In It.....
jugernot's Avatar
Angry Re: Project Lemon Drop: anything but stock!
I finally found a little drive to work on Lemon Drog and just figured out why it has stalled so long. I spend 20 minutes trying to get the lower rad hose on the water pump with no luck. So I pulled the AC compresser and got it to slip right on. Now because of the March Performance pulley system I could not just put an off the shelf lower rad hose on it. Big AL 71 helped me with a part # for the lower rad hose, which needed to be cut to fit. (He has the same pulley system). So I spent another 30 minutes trying to figure out were to cut hose to fit around the AC compresser without rubbing the frame. Well I really F#$@ that up and now the hose is useless.
So I moved onto the next project of installing the power steering hoses. Which should have been a easy 15 minute job. <<<<<<<<WRONG>>>>>>>>>. I got the hoses on with no problems, but decided I needed to adjust the high preasure hose on the pump to clean up the look a little. Well will trying to loosen the hose fitting, the pump fitting that the hose fitting attaches to came lose. Easy fit I thougt. <<<<<<<<<<<WRONG>>>>>>>> I could not get a wrench around the fitting because the low presure hose clamp and the lower power steering braket were in the way. So I removed the clamp and bracket but was still not able to get the wrech on the fitting. So now I have to remove the whole pump to tighten the fitting.
I spend about two hours and accomplished nothing.
So back to my orignal conclusion regarding the stall on Lemon Drop. Well I just a little frustrated that I have to take things part (usually more that once) to move forward.
But I guess that is what you get when you try to personalize or customize something. So Lemon Drop will sit some more, until I can modivate my self again. I have too many other things to do around my house anyway.
All right now that I have vented. Big Al 71 is going to take some more pictures of his set up and I ordered another rad hose. So it has now turned into a $60 lower radiator hose. I think I will play around with the 1st hose to figure out where to cut to new one. CROSS YOUR FINGERS.
Old 08-27-2009, 11:02 PM   #434
jugernot
Life, Be In It.....
jugernot's Avatar
No luck on the lower Rad hose, I think I will have to buy one of those metal flexible ones. I just recently ordered and received my electric fans and fan shroud from GMCPauls Truck Parts www.gmcpauls.com.
I followed this how to link and assembily was easy. http://67-72chevytrucks.com/vboard/s...d.php?t=216128
But I have a question, which electric fan relay switch should I use?
Old 08-28-2009, 12:15 AM   #435
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Personally this is the unit I am looking to use. (just using this web site to show as it has a good description of unit... actually a fairly good price too)
http://www.jaycorptech.com/pc-37-16-...version-3.aspx
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-14-2010, 03:38 PM   #436
67cheby
67cheby
67cheby's Avatar
looking back through some old builds , are there any finished pics of this truck??
67cheby is offline   Reply With Quote
Old 01-14-2010, 08:47 PM   #437
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
As far as I know he is still pluckin away at getting her done
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-16-2010, 07:22 PM   #438
jugernot
Life, Be In It.....
jugernot's Avatar
Everything came to a screetching halt do to work and home responsibilities. I have some free time now and will start things up again. I really hope to have Lemon Drop running this summer. I'm decided to seek the help of a professional to complete the Painless wire harness install. I found it to be mentally painfull and don't want it to go up in smoke when the key is turned.
I'm slowly piecing together the bits needed to bag all four corners. I only need the brains and tanks. I had to switch to bags, so I could get the truck out of my steep driveway.
I'm planning on switching out the TH350 trans for a 700R4. LFD will be helping me with aligning the front sheet metal, wet sanding and polishing. Once the above listed items are completed I think it will be a down hill run until it meets the road.
Today I picked up my first welder Lincoln 175 for a great price. I could not turn it down I paid $450.
Thanks for checking it. I will keep everyone posted on the progress. I don't think anyone wants to see Lemon Drop complete as much as I do. It has been 10 years since I started this project.
Old 01-18-2010, 02:34 PM   #439
GREASEMONKEY72
GREASEMONKEY72's Avatar
cant wait to see it out on the road
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-24-2010, 06:16 PM   #440
jugernot
Life, Be In It.....
jugernot's Avatar
I picked up another tool yesterday. It was such a good deal I could not pass on. I'm sure it will come in handy for something.
Old 01-24-2010, 07:47 PM   #441
Rokcrln
Rokcrln's Avatar
Stick to playing with guns, these tools are just going to hurt someone!
Kevin
LFD Inc.
Old 01-30-2010, 07:55 PM   #442
jugernot
Life, Be In It.....
jugernot's Avatar
I made some progress today, well kind of. I installed three out of four air bags. I have yet to install the right front bag. But I took some pictures to share. I have not yet figured out were to put the compressors or tanks.
I really happy with the out come. I really did not think the bags would make that much difference from the 4/6 drop springs that were on the truck, but it looks like it dropped an additional three inches.
Old 01-30-2010, 08:34 PM   #443
butternut1972
butternut1972's Avatar
Cool!!! I just love yellow stepsides. Your going to have a very cool truck.
butternut1972 is offline   Reply With Quote
Old 01-30-2010, 10:36 PM   #444
nuke1
nuke1's Avatar
looking good! now go finish up that fourh bag. hehe
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-14-2010, 12:34 AM   #445
jugernot
Life, Be In It.....
jugernot's Avatar
I got back to work on Lemon Drop today. I installed the fittings on the rear bags and ran a short air line to schrader valves I put on the side of the frame. The schrader valves are attached to some push on fittings.
One of the fittings is leaking where the hose line attached, so I changed the fitting and still leaked in the same place. I removed the line and cut a bit of the end of, just in case it was the problem, but nothing changed.
Am I missing something or not seating the air line completedly?
Old 02-14-2010, 08:57 PM   #446
jugernot
Life, Be In It.....
jugernot's Avatar
Here it is. Lemon Drop on bags. I think it turned out nice. I'm still only using schrader valves until I decide what size tanks to run and where to put them and the compressors.
Old 02-14-2010, 10:26 PM   #447
VA72C10
VA72C10
VA72C10's Avatar
Looks good.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-14-2010, 11:58 PM   #448
Broke1
Broke1's Avatar
your doing a great job the truck looks great
Broke1 is offline   Reply With Quote
Old 02-15-2010, 12:16 AM   #449
west9378
west9378's Avatar
Earlier it was stated that you filled or welded the rear cab roof seam can I ask why you did that and does it have any advantages.
Thank you in advance.
west9378 is offline   Reply With Quote
Old 02-15-2010, 01:31 AM   #450
19723DR
19723DR's Avatar
Love the stance.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
