Old 06-03-2009, 06:33 PM   #426
jason65
Registerd User
jason65's Avatar
Re: The 283 Rebuild Begins
jason65 is offline   Reply With Quote
Old 06-03-2009, 06:34 PM   #427
joe231
joe231's Avatar
CHEVY ONLY
Old 06-04-2009, 08:54 AM   #428
MacAttack
283 Drama Queen
MacAttack's Avatar
Saturday at about 10AM, my time: That's when I'm planning to light her off.
Being very realistic - the only thing that will prohibit that event is the weather, with the huge low-pressure system hanging off the coast here presently. It was drizzling heavily on the way home from the exhaust guy yesterday, but got a tarp over 'The Tan' before it started coming down too much.
$260 for parts and labor - really simple mounting system (yes, the pictures will be coming soon) welded to the frame rails - good and solid, but with a rubber mounting block with a rod welded to the fat ol' mufflers. Looks slick - hope they sound as good. $50 tip to both the pipe guy and the tow truck driver, and he put the C10 right where I wanted it in the driveway in front of the house.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 06-04-2009, 09:37 AM   #429
shrunken66stroker
shrunken66stroker's Avatar
[QUOTE=MacAttack;3342794]Saturday at about 10AM, my time: That's when I'm planning to light her off.
It's not the damn space shuttle! Light it off already.
shrunken66stroker is offline   Reply With Quote
Old 06-04-2009, 09:44 AM   #430
MacAttack
283 Drama Queen
MacAttack's Avatar
True dat.
But like the guys here at the shop, I should have sold tickets to this event - like when you go to the drags. They all say half the reason they go is to hear the AA fuelers light off and they think, somehow, my starting of this 44 year old pick-up ASAP is going to feed that primal need.
Mac.
Old 06-04-2009, 09:57 AM   #431
jason65
Registerd User
jason65's Avatar
Cool Mac. Fingers are crossed for ya.
Old 06-04-2009, 09:59 AM   #432
joe231
joe231's Avatar
you ain't kidding about the Drama Queen part
CHEVY ONLY
Old 06-04-2009, 10:00 AM   #433
4dranch
Shloooooong bed member #2
4dranch's Avatar
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 06-04-2009, 10:12 AM   #434
MacAttack
283 Drama Queen
MacAttack's Avatar
What? Me?
Old 06-04-2009, 10:18 AM   #435
joe231
joe231's Avatar
CHEVY ONLY
Old 06-04-2009, 10:27 AM   #436
MacAttack
283 Drama Queen
MacAttack's Avatar
Okay - initial start up pointers are coming in from the guys at the shop - see what you think:
A./ Use starting fluid - it makes it easier to get going. Didn’t do this on the Chevelle’s crate engine - fired off instantly - spit for a second until I rotated the HEI a few degrees - then smoothed right out.
B./ Don’t use starting fluid - too heavy of a load on the brand new bearings and rotating assembly.
C./ Fast idle at 2,000 - to 2,200 RPM, for 20 full minutes to break the cam in.
D./ Fast idle no quicker than 1,500 RPM, for just 10 minutes.
E./ Leave the radiator cap off so you can see if the coolant is flowing.
F./ Jack the rear end up - just clearing the tires off the ground - in case the transmission is in gear. (remember - the linkage to the shifter hasn’t been hooked up yet).
G./ Do not start the motor unless you’re sure it is in PARK only - something about tranny fluid leaking out the tail because the yoke’s extended out about 1.5" more than usual.
Comments?
Old 06-04-2009, 10:31 AM   #437
joe231
joe231's Avatar
IMHO...NEVER use starting fluid....
I have always heard to break in the cam bring it up to 2000rpm
and yes leave the radiator cap off, the level will go down and you will probably need to add some coolant.....it would go easier if you have someone to help ya......
brakes on your truck work? do you have a drive shaft in it?
CHEVY ONLY
Old 06-04-2009, 10:52 AM   #438
MacAttack
283 Drama Queen
MacAttack's Avatar
Yeah - my boy's going to be in the cab - cranking and watching the gauges.
No brakes. Drive shaft is in - but need to get it lengthened at the tranny shop.
Old 06-04-2009, 10:56 AM   #439
joe231
joe231's Avatar
cool!
yeah with no brakes I think I would jack up the rear....it would suck for it to fire and take off with no way to stop it other than kill the ignition
CHEVY ONLY
Old 06-04-2009, 11:02 AM   #440
MacAttack
283 Drama Queen
MacAttack's Avatar
Yeah, but if I was video capable - you'd sure as heck watch that on YouTube!
Old 06-04-2009, 11:06 AM   #441
protrash64
Resistance is Futile
protrash64's Avatar
Did you prime the oil system before dropping in the dizzy? I dont remember if you had mentioned this....
I always just dumped a splash of gas in the carb....make sure you're not staring down the carb when it turns over....(think of 4D's post with the mushroom cloud). It shouldnt take too long to get fuel flowing to the carb.
Ive seen different things on the cam break in. But usually the shortest time was 15 minutes. Good luck!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-04-2009, 11:14 AM   #442
joe231
joe231's Avatar
yeah I would....
CHEVY ONLY
Old 06-04-2009, 11:44 AM   #443
MacAttack
283 Drama Queen
MacAttack's Avatar
Yeah - did that on the engine stand. Love that Moroso tool. Cheap insurance.
Carb bowl is already full - kid held a gas can under the lower fuel pump hose while I gave her a couple of cranks with the remote starter switch - right after primed the oil system. The glass fuel filter filled up quick.
Left the NPT plug at the back of the block a little loose and oil came flowing right out past the threads, but not loose enough to make a mess on the floor.
Thanks for the input.
Mac.
Old 06-04-2009, 11:47 AM   #444
MacAttack
283 Drama Queen
MacAttack's Avatar
yeah I would....
Joe's just a Meanie.
Old 06-04-2009, 12:09 PM   #445
jason65
Registerd User
jason65's Avatar
Is it time yet?
Old 06-04-2009, 12:28 PM   #446
MacAttack
283 Drama Queen
MacAttack's Avatar
Originally Posted by jason65 View Post
Is it time yet?
Not even in Japan.
Old 06-04-2009, 12:37 PM   #447
joe231
joe231's Avatar
this thread is great
CHEVY ONLY
Old 06-04-2009, 01:14 PM   #448
4dranch
4dranch's Avatar
yeah it is....
I use to tune in for the truck info.....
but now I just want to see what little picture Mac posted..
David,
Daughters 66 truck:
Old 06-04-2009, 02:53 PM   #449
jason65
Registerd User
jason65's Avatar
Is it time yet? 10:00 am is what? Noon in Ok.
Old 06-04-2009, 03:49 PM   #450
MacAttack
283 Drama Queen
MacAttack's Avatar
Okay - we'll slow the baud rate down a bit for the 'fly-over' states:
S a t u r d a y at about 10AM, my time: That's when I'm planning to light her off.
