02-01-2010, 12:07 PM | #426 | |
67-72 parts collector,…
Re: Project NOT4SLE
Maybe he's making only 3" drop arms now. (And using a spacer as an option). 3" is too much for scrub line issues with 15" wheels. That why I order just the 2" drop. |
02-01-2010, 01:32 PM | #427 |
Re: Project NOT4SLE
That's what I was afraid of.
02-01-2010, 01:49 PM | #428 | |
Re: Project NOT4SLE
I need to get the rear up at least an inch though. And I need ot get the front down I think about an inch as well. |
02-01-2010, 02:49 PM | #429 | |
Re: Project NOT4SLE
I installed mine on my chassis & realized they were the 3" units & not the 2" I thought I was getting. I checked the scrub-line concern & it was flush w/the lip of a 15" wheel as measured from the lowest portion of the truck arm. The 3" shock brackets were definitely below scrub for a 15" wheel. After conversing w/Nate, he might just be offering the one arm, spacing the spring for the drop difference, & using the shorter 2" shock bracket. Check w/him to be 100% accurate though .
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-01-2010 at 02:49 PM. |
02-01-2010, 02:58 PM | #430 | |
Re: Project NOT4SLE
Ill have to call him shortly. My rear is just a tad to low. I left the front springs for now awaiting raising the rear and it may not make the front seem to tall. Switched all my steering around and the alignment shop is ready to align it tomorrow morning at 9am |
02-01-2010, 03:48 PM | #431 |
Re: Project NOT4SLE
I am really loving the rear that low, if you lower the front to match the rear watch out!!!!
I have a six inch lowering spring from ECE and a 295/40/20 on a 20x10 Coy wheel just like you and mine definetly is not even close to what yours looks like... Great progress.....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 02-01-2010 at 04:02 PM. |
02-01-2010, 04:00 PM | #432 | |
Re: Project NOT4SLE
I need to look at mine again. I know that I did order just the 2" drop. |
02-01-2010, 05:08 PM | #433 | |
Re: Project NOT4SLE
02-01-2010, 06:13 PM | #434 |
Re: Project NOT4SLE
Went and put 20 miles on the truck today before heading to work at midnight with it. Front seemed very nice the rear is harsh and bottoming out on something.... Cannot wait to get it smoothed out!!
So far everything seemed to be dialed |
02-01-2010, 07:52 PM | #435 |
Re: Project NOT4SLE
Truck is looking amazing! Glad you were able to get the steering figured out. I did notice in your post regarding the spindle nut that you were concerned about hte castle nut being too far down from the cotter pin hole. I havent taken mine apart in some time, but I wanted to ask...do you have the spindle nut tightened right against the bearing? If my memory serves me, you should have a slotted washer that goes between the bearing and the nut. I have seen too many times bearing just completely descintegrate from this if not caught early on.
- 1967 Chevy C10 shortbox - 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project - 1986 Chevy K10 LWB 350/350 Daily Driver/project Last edited by Smallz72project; 02-01-2010 at 08:20 PM. Reason: added illustration |
02-01-2010, 08:13 PM | #436 |
Re: Project NOT4SLE
I have a correction to make,...
Mine are 3" drop. (which really surprises me). I measured from the top of the plate, where the rear axle housing rests,... to the top of the 2" tube itself. I know I asked for 2" drop. Hmmm,... Last edited by lolife99; 02-01-2010 at 08:14 PM. |
02-01-2010, 08:44 PM | #437 | |
Re: Project NOT4SLE
02-01-2010, 08:54 PM | #438 |
Re: Project NOT4SLE
Let's clear up all the confusion on the arms... The trailing arms themselves ALL have 3" of drop built into them. The differences between the 2" drop and 3" drop arms are:
-The shock brackets are different -The 2" drop arms come with a cup that goes between the top of the spring and the frame. Devin- Your cups will be in the mail tomorrow.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
02-01-2010, 09:00 PM | #439 | |
Re: Project NOT4SLE
02-02-2010, 06:57 PM | #440 |
Re: Project NOT4SLE
Trucks all aligned but on the way to work last night it started making a funky noise. Like the carrier bearing has the dust cover spinning loosely and sometimes make a crazy viberation high pitch squealing sound
02-02-2010, 07:05 PM | #441 |
Re: Project NOT4SLE
Just drive faster it'll stop.
02-02-2010, 07:20 PM | #442 |
Tot Roddin'
Re: Project NOT4SLE
So what's next?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
02-02-2010, 07:43 PM | #443 | |
Re: Project NOT4SLE
Could it be too long, now that your truck is lowered? |
02-02-2010, 11:11 PM | #444 |
Truck and auto performance nut
Re: Project NOT4SLE
have had a similar sound from my trucks r/e before....spun bearing race?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
02-02-2010, 11:31 PM | #445 |
Re: Project NOT4SLE
02-02-2010, 11:47 PM | #446 | |
Re: Project NOT4SLE
Just one at the transmission, and a u-joint in the middle. I lowered a lwb truck 20 years ago,... and I had to shorten the rear shaft, of the 2-piece drive shaft. A slip yoke style setup like the later model trucks would be an improvement |
02-03-2010, 02:12 AM | #447 | |
Re: Project NOT4SLE
67 front fenders, grill, core support and cowl hood. Get the front end looking well GOOD!!! LOL I will do all new cab mount bushings, core support stuff and everything pretty much new down to the little details on the front sheet metal.
I still had play at the transmission or at least enough. I was thinking about pulling the bolts out of the carrier bearing and eggin out the holes a hair as if it is bottoming out it is VERY VERY minute. could be fixed with moving the carrier bearing forward a thousands of an inch. It does not do it at all when cold. only when hot. With the truck lowered not so easy, in fact impossible to climb underneath to figure it out... HAHAHAHA |
02-03-2010, 06:41 AM | #448 |
Re: Project NOT4SLE
Hmmm,... I didn't know it was fine before the front was done.
Got any pics of the driveshaft installed? Last edited by lolife99; 02-03-2010 at 06:41 AM. |
02-03-2010, 04:02 PM | #449 |
Re: Project NOT4SLE
Hey vegaschevy trucks lookin good i think you should bring it by on your day off so we can throw it up in the air and look at it
02-03-2010, 10:29 PM | #450 | |
Re: Project NOT4SLE
