Old 04-28-2011, 08:55 PM   #426
mooseknuckles
mooseknuckles's Avatar
Re: My 86 build
hope to get a little time in after work tomorrow.....need to make some new shock mounts to extend them , and maybe mount my battery box....
mooseknuckles is offline   Reply With Quote
Old 04-30-2011, 08:46 PM   #427
mooseknuckles
Re: My 86 build
since today was the nicest day we've had in forever, I did S.F.A!....well I did spend a couple hours polishing wheels, and managed to drill 4 holes to mount the battery box.....sorry it was almost dark when I snapped the pics.
Old 04-30-2011, 08:55 PM   #428
mooseknuckles
Re: My 86 build
and a pic or two of my polishing skillz...
Old 04-30-2011, 09:02 PM   #429
my4by2
my4by2's Avatar
Re: My 86 build
Looks killer man!!! Keep it up & keep the pics coming!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 04-30-2011, 09:08 PM   #430
mooseknuckles
Re: My 86 build
thanks!...its getting closer to the way I want it...so much fun to drive!....just need a 5.3/6.0 LS now!
Old 04-30-2011, 09:20 PM   #431
my4by2
my4by2's Avatar
Re: My 86 build
Think ALL of the non-diesel 73-87 trucks should get an LS motor!!!
Old 04-30-2011, 10:30 PM   #432
mooseknuckles
Re: My 86 build
I'd really like the new E-ROD motor from GMPP!
Old 05-01-2011, 02:56 PM   #433
Steve_aka_Violent_J
Steve_aka_Violent_J's Avatar
Re: My 86 build
Looks great bro. cant wait till mine looks as good.
Steve_aka_Violent_J is offline   Reply With Quote
Old 05-01-2011, 05:58 PM   #434
mooseknuckles
Re: My 86 build
thanks.
Old 05-01-2011, 08:29 PM   #435
mooseknuckles
Re: My 86 build
I've been feeling a slight vibration when I'm driving, thought it might have been my pinion angle out of whack, but upon closer inspection it looks like the rubber in the hanger bering is shot!
Old 05-01-2011, 08:33 PM   #436
my4by2
my4by2's Avatar
Re: My 86 build
Unless you're looking to meet local emissions laws (if you have them), then the E-Rod is kind of overkill as far as all it comes with... I went with a whole set-up from Mast Motorsports since I didn't need the exhaust with the cat's along with a few other items I didn't require. Or you can just go the cheaper route & get you a pull-out motor with the ECM & pedal assembly - their soooooo easy to find these days!!!
Old 05-01-2011, 08:43 PM   #437
mooseknuckles
Re: My 86 build
yeah..I'm just dreaming about the E-ROD, I heard that GMPP was making a new 550 hp E-ROD!....I really need to save up some cash and start checking out the wreckers for a donor...
Old 05-01-2011, 08:49 PM   #438
my4by2
my4by2's Avatar
Re: My 86 build
Even if you found an older LQ4 or LQ9 6.0L & ended up carb'ing it rather than retaining EFI it's far & away better than any of the older small blocks! But EFI will get you better mileage & drivability in the end, so I'd keep it if feasible. Looking forward to seeing what you end up with - just try not to get carried away like I did....
Old 05-01-2011, 08:57 PM   #439
mooseknuckles
Re: My 86 build
I'll def be keeping it EFI!...I plan on driving the f**k out of this thing, and the LS motors are the way to go...
Old 05-02-2011, 12:50 PM   #440
mooseknuckles
Re: My 86 build
another rain day....gonna see if I can get me a hanger bearing.
Old 05-02-2011, 03:55 PM   #441
mooseknuckles
Re: My 86 build
had one in stock!.......also ordered in some poly sway bar bushings. mine are pretty beat up.
Old 05-02-2011, 06:40 PM   #442
cletis
cletis's Avatar
Re: My 86 build
I love watching the progress, sweet build!
cletis is offline   Reply With Quote
Old 05-02-2011, 07:57 PM   #443
mooseknuckles
Re: My 86 build
thanks man.
Old 05-03-2011, 07:09 PM   #444
mooseknuckles
Re: My 86 build
not much new....just waiting on the rear disc brakes to show up!
Old 05-04-2011, 09:08 PM   #445
mooseknuckles
Re: My 86 build
...need to get a new gastank ordered in soon.....going with a 25 gal. blazer tank for the rear to replace the side-mounted tank I have now, before I punch a hole in it!
Old 05-04-2011, 09:12 PM   #446
my4by2
my4by2's Avatar
Re: My 86 build
Check out the tank that Performance Online carries - it's pretty sweet! Only 19 gallons, but still pretty good.
http://www.performanceonline.com/197...ILL-AGT7387-B/
I had an almost 40 gallon tank custom built for mine that sits between the frame rails & goes up over the rear axle - used a stock Blazer fuel door for it.
Old 05-04-2011, 09:48 PM   #447
mooseknuckles
Re: My 86 build
thanks, that is pretty sweet!.....do ya happen to know how many gal. the stock side tanks are?
Old 05-04-2011, 09:53 PM   #448
my4by2
my4by2's Avatar
Re: My 86 build
Kinda depends on the bed length - they came in 16 & 20 gallon versions - the rear mounts are usually 25 gallons. I just never cared for the look of the factory rear mount tanks, so I wanted something that looks better.
Old 05-05-2011, 09:54 PM   #449
mooseknuckles
Re: My 86 build
that def looks better!....mine is a long bed so I'm guessing 20 gal?...I've never filled it, and with these prices I prob never will!......I've priced out a 25 gal blazer/burb tank, but I may have to check into that one tho...
Old 05-05-2011, 09:59 PM   #450
my4by2
my4by2's Avatar
Re: My 86 build
That Performance Online version is probably a lot more straight-forward & easy to install than my custom version was & don't need a fuel door added to the bedside either.... Putting one in the bed floor would be pretty easy to do.
