Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 09-16-2017, 03:18 PM   #426
paintman
Re: 46 pickemup in NJ "the Rebuild"
Soooooo, as I have mentioned in previous posts, Mr. Magoo could care less. But after seeing this in the driveway.
Not to mention hearing that the paintman was looking for another project. He proceeded to show his displeasure with his master. Please no don't do it, don't do it! You swore you would never build another truck! Don't go, Don't go!
paintman is offline   Reply With Quote
Old 09-16-2017, 03:20 PM   #427
paintman
What could the Paintman possibly be up to..................................
Old 09-16-2017, 03:25 PM   #428
gokellurself
gokellurself's Avatar
hooo man here we go!
gokellurself is offline   Reply With Quote
Old 09-16-2017, 04:49 PM   #429
solidaxel
solidaxel's Avatar
Originally Posted by paintman View Post
Also still plugin away on the wiring harness. i got all my wires run up to the front for the lights. I decided to run the harness on the outside of the panels to keep the engine bay as clean possible.
[/URL]
Also got my steering linkages back in and buttoned up.
[/URL]
Christ i might just finish this thing some day! I have a couple more wire connections to make on the engine (electric choke, and T-stat) and I can fire this dam thing up! That will be my next goal. Fire up the ole 292 and check for problems befor I start bolting the reat of the body together.
Just a note to let you know that I found a problem with the knuckle set screw on the steering column to "D" shaft kept coming loose.
After I tightened it up for the second time I removed the knuckle and the set screw and found that the screw was tight BUT it was not threaded all the way to the bottom and would not tighten on the column shaft.
I don't know if you have had any trouble or maybe my stuff from Scotts was a "bad" part. but it may be worth checking before it comes lose
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-17-2017, 06:44 PM   #430
paintman
Well i guess i'm going to have to find another forum. It's amazing what you can find in an old textile mill up in Connecticut......................
home safe and sound.................
Super solid truck, about the best I have ever seen. only 2 small rust throughs on the lower corner of the doors. Great patina! i think just a coat of clear on this one will suffice!
Old 09-17-2017, 07:16 PM   #431
joedoh
joedoh's Avatar
what lies did you tell uhaul to get them to rent you that trailer? they laughed me out when I told them I was picking up a 46 chevy.
if you just keep updating on the dodge in this thread, I doubt if anyone would even throw a flag. traffic is traffic.
I like the old dodges too!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 09-17-2017, 08:03 PM   #432
paintman
Actually when I went to rent the trailer they asked what kind of truck so they could determine what size trailer I needed. I told them 46 dodge and it came right up on their computer. They said they have every vehicles dimensions from 1912 and up. never said anything about not letting me rent the trailer.
Old 09-17-2017, 10:12 PM   #433
joedoh
joedoh's Avatar
lucky! they told me I couldnt haul a "full size truck" on the trailer, I tried explaining but it was no use. I bought a trailer instead haha
Old 09-17-2017, 11:00 PM   #434
solidaxel
solidaxel's Avatar
Do I see a 2" chop and a hot rod !
LS 3 4L70E
Old 09-18-2017, 12:53 AM   #435
tune_1
I have enjoyed dropping in and following what you have done. I hope that you document the new truck in Alternate Tinkerings so I can follow that too.
Dwight
tune_1 is offline   Reply With Quote
Old 09-18-2017, 02:23 AM   #436
gokellurself
this old man's junk yard I keep raving about has far more Dodge stuff than anything for our Chevy's. If you really need to find something he's about an hour away from me, I'd be happy to work in a trip up there
absolutely awesome find! what plans do you have for it?
Old 09-22-2017, 03:50 PM   #437
paintman
[QUOTE=gokellurself;8041963 what plans do you have for it?
For now I just want to get the body apart so I can get it up in the barn for storage. Also build a crib for the cab and get it, into the garage. Then I can take a closer look at the frame and see which way to go.
I am kicking around the idea of boxing the original frame and using a Scott's front end and four bar link in the back. Or try and find a Dakota frame and make that swap. Either way I would use either a 318 or 360 to keep it all Mopar.
My last choice would be the belly button S10 /SBC swap. As with my 292 build, you can see I'm the kind of guy who likes to paddle up stream.
Whatever road I choose.......This is my inspiration.....................
[url]https://www.youtube.com/watch?v=V_trtgiIILw[/url]
Old 10-05-2017, 11:19 AM   #438
rusty76
rusty76's Avatar
I’m in for the ride now. Cool truck and thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-29-2017, 09:18 AM   #439
Diesel46
Have you been able to get any driving time in the old Chevy? What wheel/tire choice did you come up with? So close to the finish line! Next project looks good.
46 Chevy Pickup (project)
60 Chevy Biscayne 93 Caprice wagon(Impala SS style)
99 Corvette convertible 2014 Silverado 2500HD
92 Chevy 1500 (Shop/plow truck) 02 Silverwing
05 H-D Springer Classic 2011 Civic (Wifes car)
03 Highlander (beater) 96 Honda Elite 80
Diesel46 is offline   Reply With Quote
Old 12-18-2017, 04:43 PM   #440
paintman
Merry Christmas everybody from the paintman family!
Old 12-19-2017, 12:00 AM   #441
tune_1
What a great family picture.
Have a great holiday
Dwight
Old 12-19-2017, 12:08 AM   #442
streetrodchev
streetrodchev's Avatar
Merry Christmas.
Great pictures.
'46 GMC---355,TH400, 9"
'66 K20---350, SM420, T221, D44, HO72, 4.56
'87 K30---tbi 350, TH400, NP205 twinstick, D60 powerlok, 14ff Detroit, 4.10
streetrodchev is offline   Reply With Quote
Old 12-19-2017, 12:36 AM   #443
joedoh
joedoh's Avatar
merry christmas! great family pictures!
Old 12-21-2017, 03:43 PM   #444
CURSED GEARS
Merry Christmas!
Great pictures!
Congrats on the Dodge truck, Always liked the way they looked.
CURSED GEARS is offline   Reply With Quote
Old 12-21-2017, 11:34 PM   #445
solidaxel
solidaxel's Avatar
Stunning !
Wishing you all a Very Merry Christmas
LS 3 4L70E
Old 12-22-2017, 07:46 PM   #446
rusty76
rusty76's Avatar
Merry Christmas
My build thread
Crossmembers CC
Old 01-10-2018, 12:41 PM   #447
botoepfer
botoepfer's Avatar
Beautiful Family picture Indeed,, I have a few questions for you Paintman, I have a 63 C10 and I have a bad Heater core, I am looking for a bulkhead fitting to cure my AN addiction.. I too want to run braided stainless Heater lines, Also where did you get that cool Plug wire loom,,? and the cool red block for the water temp sender? Thanks Love your thread !,, all the best Bo
botoepfer is offline   Reply With Quote
Old 01-10-2018, 05:08 PM   #448
paintman
I am assuming you are refering to the stainless bulkhead fittings going through my firewall yes? I got them from Hardin Marine, they have a .com site. They were the only bulkhead fittings I could find that would match up to my heater core.
The red block that I am using for my temp. probe, I got from either Summit or Jegs. If I remember correctly
Old 01-10-2018, 06:26 PM   #449
botoepfer
botoepfer's Avatar
Yes that is what I was speaking of,, Thanks for the prompt reply , I hope I can reach out if I have more questions Thanks
Old 01-29-2018, 01:15 AM   #450
dillonv2008
what thickness did you use for your plate on floorpan where column and brake pedal are at. and also for your brake assemebly that you mounted to the frame what thickness did you use. it almost looks like 3/16 for frame and 1/8 for floor pan??
dillonv2008 is offline   Reply With Quote
