#426 |
I will post pics on hopefully Sunday Night! It is sitting on 15's now with 2 2x4's and still sits the frame. The front will lay out but I dont want to cut anymore of my wheel wells. When I had it all setup on my spare frame it layed the front out with a 28inch tire. I am still waiting for my Bonspeed 20's to come in. Its been a month! I will post soem pics on Sunday, Hopefully.
#427 |
belly dragger
I believe it, I just wanna see it. But Iwanna see everything
#428 | |
www.loweredd.com
I dont think that it would be NEARLY enough sidewall for my liking though. ![]() |
#429 |
Project92 SWB stepside
Has anyone got there tie rods hooked up with the R&P?? I really done want to use the factory tie rods and the sleeves I got from turners. I thought about using a nice aluminum adjuster and a heims joint of some kind at the spinlde. Anyone have any good ideas??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
#430 |
Yes I am installing aluminum tube tierods and heims on my Suburban from the spindles to the stock center link. Just doing this so I can flip them and takes some angle out. Also the stock tierod assemblies were laying on the steering stabilizer and pitman arm. It wouldn't let it lay all the way out. I got my heims and arms from a local dirt car supply shop. You could also contact Speedway Motors, Performance Bodies, or other dirt car shops. Hope this helps you out man. Got mine laying w/ pinch weld 1/2" off ground w/ no bodydrop.
#431 |
Here are some pics
#432 |
More!
#433 |
Now my suburban is sitting on 15's there but I have had it sitting on those wheels with 2- 2x4's under it and it still sat the rear bumper. The Bumper is sitting on the ground and wont let it go down more. The front will not go down with those wheels on it. I got stock wheels on it now but haven't taken pics yet. But this should hold you guys over for now.
#434 |
www.loweredd.com
Oh My Gosh. That is awesome looking. My friend at work has an uncle with a shorter one than that but same year. I wish he would sell it. That looks SUPER. More more more!!!
#435 | |
fastbagged....what do you mean by the front wont go down with those wheels on it?
'72 Cheyenne super, short-fleet, air-tilt-tach, fuel injected LT1, 700r4, 3.08 posi, 4WDB, step notched and bagged. "the one i wish i still had" |
#436 |
I got more recent pics but have not download them yet. With those wheels my on it they are sitting on the wheel wells. Since then I have put on stock spare tire wheels on the front. I had to cut up the frontfender alittle bit to get the tire size to fit.
#437 |
New pics of my Sub
Just posted some pics of my burb layin frame on 20's. Check it out and tell me what u think.http://www.cardomain.com/memberpage/489596/3
#438 |
Looking good!!
#439 |
Signals in the bumper.
both burbans look good fellas.
I hope to be notching my xmember and raising my rear notch more this winter. NOw I just need to read through this thread. There is a little tech article about this in Street Trucks this month and they made it sound like it would be hard to get 2" of drop by notching so I am going to have to check into that a little more. I want 2" and I am not afraid to fabricate. ![]() EDIT: After reading the whole thing, I may consider the 1.5" chop. I will see when I get in there.
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link Last edited by bagged81; 04-05-2004 at 06:31 PM. |
#440 |
Well I got back to work on mine. I got the center tacked back into place & it's ready for trial fitting to the frame. If everything aligns as it should, I hope to have it welded up within the next couple of weeks.
I wish AirRide would get off their ass & decide whether they're going to build the tubular arms for 63-87's. I guess there aren't many of these year trucks running around (wink, wink).
#441 |
grnddwn, did you ever pull your motor out and get some photos of your crossmember setup?
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
#442 | |
Under construction!
They will be available spring of this year. Check out their 2004 catalog..... ![]()
2001 Silverado bagged on 22's. *Sold* |
#443 | |
#444 |
Well... they were to be available 'early spring'..... what is early spring? Last I spoke w/'Darren' @ AirRide which was a few weeks ago, they haven't even started on them yet.
#445 |
Under construction!
We'll see what happens. Price will probably be the same as their other control arms. Either way, I'm getting them.
#446 |
So what are you guys doing about the upper bag mounts?
#447 | |
#448 |
Cool. I guess I will have to see when I get there if the my plate mounts will get me low enough.
#449 |
Couldn't you just notch the bottom of the front X-member about 1-2" to move the mounting point of the factory lower control arms up?
After doing what I did to my truck to get it much lower than it was before, I still need about 1/2-1" in the front to lay the rocker on the ground. My Lower Control arms are the lowest thing in the front, so they hit first. If I just notched the X-member where they mount (without modifying the rest of the X-member would that work? Wouldn't mess up the geometry any would it? I'm determined to get my truck all the way down on 27" tire in the front without body dropping and without going to tubular a-arms. Gonna be working on it this week, but wheel tubs and new mufflers, not the X-member, but may start doing some measuring while I got it up on jack stands to see what can be done to get an extra 1" down.
2004 Chevy Silverado 1500 RCSB 4.8v8 5 speed 2002 GMC Sierra 1500 RCSB 4.8v8 auto (wifes truck) 1986 Chevy Caprice 5.0 auto (like driving a couch down the road) 1982 Chevy C30 Crew Cab 2wd LWB - Beater Truck (I have more!) Too many to list! |
#450 |
I dont know if the 73+ frame to body is the same as 67-72, but if they are...you won't lay body without minor body drop...if your frame is laying on the ground...the body will be about 3/4" off the ground....this is what I am dealing with now.....is it worth all the extra BS for that extra 3/4 inch to "lay body" on my 72?.....hmmmm
