Old 11-11-2014, 02:01 PM   #426
61K10
61K10's Avatar
Re: 61K10 build
well along with my rear end problem I have a clutch problem. everything is new--M-cyl and slave cyl. adjusting as the book says
slave all the way in-adj rod between the arm (5/16")
pedal 1/8" of free play
seems the adj rod between the master and pedal is too short? sense this tk was org a 235-6 and where all the v-8 stuff came from. clutch works but has more free play at the pedal and grabs not too far of the floor. the adj rod needs to be longer as it runs out of threads. I'm tired of working on this tk--it might just sit for awhile!
everybody have a great Turkey-day----------
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-11-2014, 04:27 PM   #427
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Well, don't worry just a couple kinks to work out. Take a break, then when you come back you'll have everything worked out.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 11-11-2014, 04:47 PM   #428
padresag
Re: 61K10 build
the question that I ask; are you sure that you have the right release brg. there are 2, a long and a short. with your description of 1/8" freeplay and clutch grabbing at the bottom that this may be the case
ron
padresag is offline   Reply With Quote
Old 11-11-2014, 05:45 PM   #429
RANDY COX
RANDY COX's Avatar
Re: 61K10 build
Oh Lordy I have a story about the throwout bearing in one of my early projects... Hang in there Kimble...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 11-12-2014, 12:51 PM   #430
61K10
61K10's Avatar
Re: 61K10 build
ron--the t/o bearing came with the kit, seems to fit in the bell ok. diafram type clutch, not b&b 3 finger type. same type that came out of the tk when i bought it. will get it figured out lol.
1961 chevy K10
Old 11-12-2014, 01:14 PM   #431
padresag
Re: 61K10 build
came with the kit doesn't really mean anything. this mistake has been made many times over the years. drop the inspection cover and see if you can see how much space you have between the release brg and the p/plate and also see if you can get the 2 different t/o bearings together and check the differences.
ron
Old 11-12-2014, 10:05 PM   #432
argonaut
argonaut's Avatar
Re: 61K10 build
I had a similar problem on my pickup. I used the factory hydro bellhousing, slave cylinder and clutch for an 85 pickup but found that the slave cylinder was bottoming out on the circlip before completely engaging the clutch. I just cut and ground a new longer slave cyl pushrod from some 3/8 rod I have. Maybe I'm also using a throwout bearing that is too short?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 11-13-2014, 01:50 PM   #433
61K10
61K10's Avatar
Re: 61K10 build
Jason--It's something simple. my tk had an adapter that looks to be home-made? for the slave. clutch seemed to work ok but just drove it around the yard. about the t/o bearing. I have built many chevy clutch set-ups and never had a problem with the t/o bearing. for the diafram type there are two type bearings long & short because of the two type of fingers--tall and short. the stock bell doesn't have much room for the t/o/b anyway. I need a stronger clutch arm return spring also.might still have air in the system? here is a pic of the adapter that was on the tk when bought. the adj bolt from the slave was in the outside of the arm not the inside as 60-66 posted pics for me of a stock set-up.
1961 chevy K10
Old 11-13-2014, 04:23 PM   #434
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: 61K10 build
Hope ya get yer clutch fixed soon! Hope I didn't miss anything. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-15-2014, 01:49 PM   #435
61K10
61K10's Avatar
Re: 61K10 build
TJ--not much going on. well i put a 1/4" ball bearing in the master cyl hole where the push rod goes in. well now i can adj my clutch like the book says. need to build a new p/rod 1/4" longer than stock. Got a lead on a rear third member with the 3.90 gears in good shape.
1961 chevy K10
Old 11-15-2014, 03:04 PM   #436
argonaut
argonaut's Avatar
Re: 61K10 build
I wonder why they had that "adapter" plate bolted on there. Shouldn't the slave cylinder just bolt straight to the bellhousing? Seems like that might solve the issue with the too-short pushrod length.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 11-19-2014, 03:13 PM   #437
61K10
61K10's Avatar
Re: 61K10 build
Jason--I as you wonder why the adapter? I bought a nos slave on e-bay for cheap, will see if any difference from the re-pop that i have on the tk now. winter is setting in here now so been doing some winter-iszing. will find out tonight about the third-member. will rebuild with new bearings as i am not going to do this again. I will build a new 12-bolt and be done with it.
kimble
1961 chevy K10
Old 11-23-2014, 03:37 PM   #438
61K10
61K10's Avatar
Re: 61K10 build
of course the slave was not a slave just a wheel cyl! getting the third member on friday hopefully. will post up some pics of the bearing rebuild.
1961 chevy K10
Old 11-24-2014, 11:51 AM   #439
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Good to hear you got both items on the 'fix'! Went to get a 'core support' this weekend and saw a HO32 sitting on the ground. LOL
'62 Chevy K10
Old 11-24-2014, 01:17 PM   #440
61K10
61K10's Avatar
Re: 61K10 build
Mitch--I hope the r&p are good. might just take my old one and put 3.38's in it for highway use if i want to drive it a long distance.
1961 chevy K10
Old 11-25-2014, 03:31 PM   #441
61K10
61K10's Avatar
Re: 61K10 build
FREE stuff but you have to come and pick up.
1961 chevy K10
Old 11-25-2014, 03:40 PM   #442
61K10
61K10's Avatar
Re: 61K10 build
some more--alot of dents but hardly any rust. have doors but rusty on the bottom and dents. have front bed panel but full of dents.
wife say's it's time to clean up the yard ( only been there a couple yrs lol!)
1961 chevy K10
Old 11-25-2014, 04:02 PM   #443
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Get the welder out and make some stuff to put in the yard sale! People will actually buy that stuff. lol that hood would make a good door over hang.
'62 Chevy K10
Old 11-25-2014, 04:43 PM   #444
61K10
61K10's Avatar
Re: 61K10 build
Mitch--thought about the door thing also thought about yard art no cab or grill but all the other stuff. plant something in the interior and bed. WEED like everybody else grows around here lol!
1961 chevy K10
Old 11-28-2014, 11:47 AM   #445
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
Hey Kimble, Did you see this? LOL If I had a way to get it to me, I'd put a bid in! Only thing I see missing is the steering gear box!
http://www.ebay.com/itm/1960-1966-Ch...76693c&vxp=mtr
'62 Chevy K10
Old 11-28-2014, 02:16 PM   #446
61K10
61K10's Avatar
Re: 61K10 build
Mitch--have not seen that. probably a deal. A little far away for me too.
1961 chevy K10
Old 11-30-2014, 02:55 PM   #447
61K10
61K10's Avatar
Re: 61K10 build
Well, got my used third member and of course it's been blown up before!! looks like one of the pinion bearings blew or the spider gears let go. All the bearings look new and in good shape. the carrier bearings are funny looking, kinda curved rollers. you can see in the pic. ck out the modded crush sleeve. couldn't afford a new one at $3.50 I guess. even found t teeth from the spider gears in the pinion valley under neath the pinion.
going to put back together and see if it better than my other one. Hope it's quieter?? Maybe some day i will get a break and by something thats in good shape----------I guess i shouldn't have bought the tk lol!!
1961 chevy K10
Old 12-01-2014, 11:50 AM   #448
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
I think you got it now! Clutch fixed and now the rear member rebuilt. Should be good.
'62 Chevy K10
Old 12-01-2014, 03:53 PM   #449
61K10
61K10's Avatar
Re: 61K10 build
Depends on if it makes noise big time like my org one.
1961 chevy K10
Old 12-03-2014, 10:56 AM   #450
MitchFloyd
MitchFloyd's Avatar
Re: 61K10 build
just replacing that crush sleeve will make it a lot quieter! lol. That is something there.
'62 Chevy K10
