Old 09-21-2016, 12:15 PM   #426
mbisett
Re: S10 Swap how to
Great information!. I am new to this thread and ready to start a 1948 GMC truck chassis swap. Will a 1994 S10 2 wheel drive, 4 door Blazer with 117" wheelbase work as well as the S10 Truck chassis?
mbisett is offline   Reply With Quote
Old 09-21-2016, 12:27 PM   #427
tlorber
tlorber's Avatar
Re: S10 Swap how to
Bisett, from what I have read it is not the best frame to use for a pickup swap since it rises up in the bed area. There are a few threads that address this, as well as a bunch of others that have a lot of info. Here is a partial list of threads I'm subscribed to. Sorry to those who are not listed, but I subscribe to about 30 and don't want to overwhelm this thread. These are the most recent with posts...
For the 117" wheelbase, most have gone with the regular cab longbed when using an S10 chassis.
http://67-72chevytrucks.com/vboard/s...d.php?t=632686
http://67-72chevytrucks.com/vboard/s...d.php?t=562572
http://67-72chevytrucks.com/vboard/s...d.php?t=531261
http://67-72chevytrucks.com/vboard/s...d.php?t=676497
http://67-72chevytrucks.com/vboard/s...d.php?t=609082
http://67-72chevytrucks.com/vboard/s...d.php?t=384736
http://67-72chevytrucks.com/vboard/s...d.php?t=642010
http://67-72chevytrucks.com/vboard/s...d.php?t=651164
tlorber is offline   Reply With Quote
Old 09-21-2016, 03:11 PM   #428
mbisett
Re: S10 Swap how to
tlorber - thanks for the quick response, information and other threads - great stuff!
Old 09-21-2016, 08:05 PM   #429
Clay54
Re: S10 Swap how to
Here is a '96 4x4 Blazer to add to the list.
http://67-72chevytrucks.com/vboard/s...d.php?t=526387
Clay54 is offline   Reply With Quote
Old 10-06-2016, 11:08 PM   #430
DeanTX
DeanTX's Avatar
Re: S10 Swap how to
Yes msaintg has a great thread for a 4x4 Blazer frame swap. They do not rise up in the bed area. If you look at the pics in the thread he ends up with a low riding stance and only gives up about an inch of bed depth.
I have a 1951 3100 and swapped it onto a 2001 Blazer 4x4 frame. Like msaintg I took off all the front wheel drive stuff and am just using 2 wheel drive. I had to shorten the frame 9" to get to 116". Most of what you see for S10 pickup swaps will apply.
DeanTX is offline   Reply With Quote
Old 10-06-2016, 11:35 PM   #431
frankist
Re: S10 Swap how to
Hope you're doing well Chris, and to have a speedy recovery. Just to keep this thread updated with more info, anyone using any other ideas for a throttle pedal? s10 assembly was destroyed upon removing from the donor car I had and I may need to opt to another option.
This has been a fun project for me and cannot thank Chris enough for his efforts in gathering his knowledge to the community. Thanks bud!
frankist is offline   Reply With Quote
Old 10-14-2016, 04:48 PM   #432
tlorber
tlorber's Avatar
Re: S10 Swap how to
For those of you that have put an LS motor (LM7 in my case) onto the S10 chassis, do you have spec for which steering hose you used for the high pressure side? Here is a picture of the fittings I need to meet up with.
Name:  Steering Box Fittings.jpg
Thanks for any input.
Old 10-22-2016, 12:36 AM   #433
shamrock1953
Re: S10 Swap how to
New to the forum finished up my mounts from skymags type 1 design last night I must of read the thread about 5/6 times already but I'm a lil stuck I'm using early 80 sbc 350 84 to be exact want to know if I can just buy s10 to v8 sbc350 mounts and headers or am I gonna run into issues sorry I'm a newbie first truck I'm swapping btw I have 53 gmc shortbed
shamrock1953 is offline   Reply With Quote
Old 10-25-2016, 08:07 PM   #434
skymangs
skymangs's Avatar
Re: S10 Swap how to
Originally Posted by N.T.Q View Post
I don't believe Chris is back yet answering questions but does any one know the Part #'s on the Fuel pump, rotary vane - Oreillys and you - $80 there is 3 different ones they sell thanks
I am here and able your to answer your questions. I'm back by not 100%. Unfortunately I don't know the answer to your question. It is not like I can run to my shop and check now is it.
skymangs is offline   Reply With Quote
Old 10-25-2016, 08:16 PM   #435
skymangs
skymangs's Avatar
Re: S10 Swap how to
you could however, the motor won't be far enough back for you to run an electric fan
Old 10-25-2016, 08:20 PM   #436
iowaboynca
iowaboynca's Avatar
Re: S10 Swap how to
I sure hope that was supposed to be funny because i chuckled a little bit...
Welcome back and keep getting better!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 10-25-2016, 08:33 PM   #437
skymangs
skymangs's Avatar
Re: S10 Swap how to
Attachment 1580941
I just took my hose ends into O'Reillys they made me a hose to my measurements
Old 10-25-2016, 08:43 PM   #438
HUSSEY
HUSSEY's Avatar
Re: S10 Swap how to
If I understand it right you are asking about using the S10 V8 conversion mounts. If it is, that is what I did. You see how I went about it in my build thread, Post 24:
http://67-72chevytrucks.com/vboard/s...d.php?t=664837
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 10-25-2016, 08:47 PM   #439
skymangs
skymangs's Avatar
Re: S10 Swap how to
Originally Posted by BigFrz View Post
Can you plz go over the radiator section with me. I am like confused why did u buy another core support. I bought the 19 x22 radiator and it seem not to fit by milli meters lol. Thanks for your help.
Big Frz
you have two trim your current core support to fit the 19 x 22 radiator. You will also need to trim the core support below the side nuts.
Old 10-25-2016, 08:58 PM   #440
skymangs
skymangs's Avatar
Re: S10 Swap how to
It was, I burned my shop to the ground. Thank you. I hope to have my shop up and running by next all truck nats.
Old 10-25-2016, 09:10 PM   #441
skymangs
skymangs's Avatar
Re: S10 Swap how to
Big Frz
to get the 19 x 22 radiator to fit right you need to trim off the original radiator mounting holes. Then use the 68 to 72 radiator bushings I mentioned earlier.
Old 10-25-2016, 09:24 PM   #442
shamrock1953
Re: S10 Swap how to
Hussey I just looked at your build and I'm still a lil confused so did you drill out the mounts then relocated them or you redrilled the conversion mounts any help is appreciated thanks guys
Old 10-25-2016, 09:26 PM   #443
shamrock1953
Re: S10 Swap how to
Btw my s10 frame is a 1994 with the 4.3 6 banger that's coming out
Old 10-25-2016, 10:55 PM   #444
oldman3
oldman3's Avatar
Re: S10 Swap how to
Hey Chris, so glad to see you back posting. Good news on the new shop, keep kicking butt and again welcome back...Jim
oldman3 is offline   Reply With Quote
Old 10-26-2016, 12:52 PM   #445
steve aleve
Re: S10 Swap how to
Attachment 1580941
The two lines I used may be different for you because I ended up doing a hydroboost with an LM7 and s10 steering box
their part #s are
edelmann 92095 pressure hose
and edelmann 92084 pressure hose.
Maybe this will help!!
Also!!! It is so good to see that you "Skymangs" are back!!! I hope the recovery is going great!!
steve aleve is offline   Reply With Quote
Old 10-26-2016, 03:19 PM   #446
tlorber
tlorber's Avatar
Re: S10 Swap how to
Thanks for the input guys, and Chris, I'm glad to hear you are back-at least in some capacity. I ended up having a hose made, so one more project is crossed off my list.
Old 10-26-2016, 07:03 PM   #447
Clay54
Re: S10 Swap how to
Glad to see these words with your "posted by skymangs" tag. Clay
Old 10-26-2016, 07:19 PM   #448
HUSSEY
HUSSEY's Avatar
Re: S10 Swap how to
Welcome back Chris, hope your recovery is going well.
Old 10-26-2016, 07:23 PM   #449
HUSSEY
HUSSEY's Avatar
Re: S10 Swap how to
No drilling on the conversion mounts or the rubber mounts, just the two lower holes where the conversion mounts on the drivers side of the chassis. Once you have your conversion mounts it'll be more clear. But, on the passengers side you can install all three bolts to bolt the conversion mounts to the chassis. On the drivers side you can install the top bolt but will have to drill the lower two on the chassis. You can use your original mounts which have ob-longed holes in them as a guide.
Then, bolt you rubber mounts to you engine, Anchor 2713, and you're set.
Old 10-27-2016, 12:42 PM   #450
skymangs
skymangs's Avatar
Re: S10 Swap how to
thanks Jim, good to be back.
