Old 02-20-2018, 02:07 PM   #426
daddyjeep
daddyjeep's Avatar
Re: Used Parts Build
Originally Posted by tinydb84 View Post
Built a battery box. Still need to figure out the hold downs.
More nice work. Just weld a ring on there for a bungee. Not really, I'm sure you can come up with something better. Maybe a slot in the back, a piece of bar stock bent to lock into the slot that goes over the top and meets a tab on the front to bolt to. Simple, but effective.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 02-27-2018, 08:56 PM   #427
tinydb84
tinydb84's Avatar
Box is done and mounted
The rear is starting to come together
I need to figure out how to mount my limit straps still. Bought some hard line for my fuel lines so I can try to keep making progress.
David
Instagram: myfabguy
Old 02-28-2018, 10:23 AM   #428
aggie91
I'm just glad to be here!
aggie91's Avatar
Battery box looks good. If the battery ever falls out, it won't be for the box being under built!
How about mounting your limit straps in the shock bolts between the shock on the frame?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-28-2018, 03:08 PM   #429
tinydb84
tinydb84's Avatar
I used my brother battery to build the box before looking up the price of the Optima batteries...ouch!
I used your thread to set up my fuel sending unit btw. Thank you for that.
I was thinking the same thing about the limiting straps. I need to reassemble everything and mock them up to see what would work best.
David
Instagram: myfabguy
Old 03-05-2018, 02:25 PM   #430
tinydb84
tinydb84's Avatar
I need to work on my vertical up. I made a tab to bolt my ground strap to. I am trying to make everything on this thing easy to service and I though this would be a good idea.
Made a bunch of tabs to run my fuel lines and battery cable. I need to make some more for the other side to run my airline and brake line.
David
Instagram: myfabguy
Old 03-05-2018, 05:15 PM   #431
Joe Pass
Joe Pass's Avatar
cool...nice work
Joe Pass is offline   Reply With Quote
Old 03-05-2018, 06:36 PM   #432
aggie91
aggie91's Avatar
If you are going to have clamps on both sides of the tab, why not use some sex bolts to clean up how they attach to the tab?
Link: https://www.mcmaster.com/#sex-bolts/=1bucq9j
Karl
The LST Challenge:
Old 03-12-2018, 12:30 PM   #433
tinydb84
tinydb84's Avatar
Added my limit straps and fuel lines (half way at least)
Added another support bar for the 4 link
David
Instagram: myfabguy
Old 03-12-2018, 04:18 PM   #434
rip2174
What are the limit straps for?
rip2174 is offline   Reply With Quote
Old 03-12-2018, 07:01 PM   #435
tinydb84
tinydb84's Avatar
To keep the rear end from dropping too low when I jack the truck up.
There is nothing to keep my rear end from dropping down enough to damage the bags or bind up the watts link.
David
Instagram: myfabguy
Old 03-19-2018, 12:16 PM   #436
tinydb84
tinydb84's Avatar
Got the other cross member bar welded on the other side. Moved to the front for a bit to get a break from working on the back.
Shortened my lower control arms 1.5''. Still need to finish welding out the other side and add a truss on the bottom side.
David
Instagram: myfabguy
Old 03-19-2018, 03:02 PM   #437
aggie91
aggie91's Avatar
looks good!
Karl
The LST Challenge:
Old 03-19-2018, 09:38 PM   #438
Joe Pass
Joe Pass's Avatar
Your an ambitious dude...lol
Joe
Old 04-02-2018, 12:31 PM   #439
tinydb84
tinydb84's Avatar
looks good!
Thank you sir.
Joe
Ive seen the body work and paint you have been doing. That's way more work than I am doing!
David
Instagram: myfabguy
Old 04-02-2018, 12:32 PM   #440
tinydb84
tinydb84's Avatar
Shortened my upper control arms. Tacked them together just to check the fit. I went 1.5'' with the lowers and 1.25''(ish) with the uppers. Might grind a hair more off because I am near 0 degrees camber with one shim and want a bit more room for error. I clear the hood hinges now. Still a bit tight with the turning. I get why the raised cross members tuck so much now. I might still go with a CPP modular spindle for that extra 3/4''. Ill figure it out later.
Checking for any binding or issues. Seems like I should be okay to lay out.
David
Instagram: myfabguy
Old 04-02-2018, 04:45 PM   #441
rusty76
rusty76's Avatar
Looking good dude. Nice work.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-18-2018, 07:53 PM   #442
tinydb84
tinydb84's Avatar
Some terrible pictures for you...Upper control arms are done. Reassembled the front suspension. Shortened the tie rods.
Tapped the water pump for a steam port line.
Thinking it is about time to pull the cab and finish the frame work...
David
Instagram: myfabguy
Old 04-18-2018, 08:15 PM   #443
rusty76
rusty76's Avatar
Glad to see progress.
My build thread
Crossmembers CC
Old 04-18-2018, 10:02 PM   #444
Joe Pass
Joe Pass's Avatar
Nice work......anxious to see it finished...
Old 04-23-2018, 12:17 PM   #445
tinydb84
tinydb84's Avatar
Thanks guys. Here is an update.
Going to try to finish out all the chassis work over the next few weeks. Pulling the cab was a pain! I wish I had the space for a lift.
David
Instagram: myfabguy
Old 04-25-2018, 12:52 PM   #446
tinydb84
tinydb84's Avatar
Started grinding off the por15 I did a few years ago. Going to shoot it with epoxy instead. Cleaned up my boxing a bit to make it look nicer. Welded on the tops of my body mounts. Need to pull my engine and trans next.
David
Instagram: myfabguy
Old 05-14-2018, 01:00 PM   #447
tinydb84
tinydb84's Avatar
Got some work done this weekend:
Didn't like my previous steering stabilizer so I made a new one
Welded on my turbo drain
Reboxed my Z with a bit more style and all tig welded.
David
Instagram: myfabguy
Old 05-14-2018, 05:40 PM   #448
rusty76
rusty76's Avatar
Very nice.
My build thread
Crossmembers CC
Old 05-14-2018, 11:11 PM   #449
Joe Pass
Joe Pass's Avatar
Well done.....
Old 06-25-2018, 01:23 PM   #450
tinydb84
tinydb84's Avatar
Made some new motor mount towers (again..)
Weld shot for fun
Finally able to lay out without the oil pan touching
Started the trans mount
Started laying out tubes to figure out how I want to build the inner frame stiffener
David
Instagram: myfabguy
