11-13-2016, 09:04 AM | #426 |
Happy to be here
Re: 85 GMC Sierra "Scarlett"
The cluster comes out along with the HVAC controls. This allows access to the incandescent bulbs that will be replaced.
11-13-2016, 09:13 AM | #427 |
Happy to be here
I ordered the LEDS from Amazon. They were much cheaper than any other source I had found. I read the reviews and they showed to be very bright and true white with no blue cast to the light.
Take note that you will need to straighten the leads on the bulbs and they are directional. If the don't light up reverse them in the socket. I had no defective bulbs once I fixed the leads. Amazon link
11-13-2016, 09:23 AM | #428 |
Happy to be here
I won't document each step because there are detailed articles in the FAQ forum to cover what I am doing.
The objective is to get the gauges out so you can paint the housing. Use hand tools and caution removing the gauges. Most housing are brittle and the mounting pad can break.
11-13-2016, 09:29 AM | #429 |
Happy to be here
At this point I made note of what modifications were necessary to install the GM Sports tach/fuel gauge.
Note that they also offer a tach only if you want to run a small gas gauge and no clock. If you are just restoring and adding LEDS you won't need to make these modifications. GM Sports link
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-13-2016 at 09:37 AM. |
11-13-2016, 09:46 AM | #430 |
Happy to be here
After the mods were made to the housing and I was sure the new tach would fit it was time to restore and improve. Start by masking the various holes and connectors.
Since the housing has yellowed I use a bright silver to restore it's reflective ability. You can use white, but silver reflects better.
11-13-2016, 09:57 AM | #431 |
Happy to be here
An important step in making your gauges like new again is repainting the needles. They will fade over time and a fresh coat of paint makes them look new again.
If you suspect that your needles might be brittle from UV exposure you may prefer to paint with a brush. I use a folder to make masking easy and Testors fluorescent orange or the needles. I Do Not recommend removing the needles. Getting them repositioned properly with out breaking one is almost impossible.
11-13-2016, 10:07 AM | #432 |
Happy to be here
Once reassembled with fresh painted needles, LED lights and a new tach it was time to test my work.
Everything functioned properlyexcluding the tach. I still need to run the input wire to the distributor and confirm proper operation before wrapping up. Meanwhile let's look at the results so far.
11-13-2016, 11:13 AM | #433 | |
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
11-13-2016, 09:35 PM | #434 |
Happy to be here
I got it wired up today and it's very nice. Much smoother than the factory 5k tach.
11-13-2016, 10:16 PM | #435 |
Where did you pick it up?
11-13-2016, 10:25 PM | #436 |
www.gmsports.com
They sell them on eBay also. |
11-13-2016, 10:26 PM | #437 | |
11-14-2016, 01:19 PM | #438 | |
Happy to be here
Although they arent listed, I am told they offer two different fonts as well.
11-14-2016, 03:09 PM | #439 |
That Buddy was Gene Porter right? That is who I was with when you and I met at C10sinthepark.
11-14-2016, 06:35 PM | #440 | |
Happy to be here
Typical of any automotive enthusiast, I do remember what truck you drive.
11-14-2016, 06:36 PM | #441 |
That's all that matters
11-14-2016, 06:41 PM | #442 |
Happy to be here
With only 14 weeks (101 days) till Lonestar Throwdown, I need to turn it up a notch. Factor in Thanksgiving, and Christmas and thats even less time. I have to get the interior done so I can move on to the motor. Tick, tick, tick....
11-15-2016, 10:58 AM | #443 |
Happy to be here
Not much progress last night. I worked with my wife cleaning carpet and rearranging furniture. We are hosting Thanksgiving and plan to have a house full of family.
I did get the ashtray cleaned and painted. Then I started on stripping more of the interior plastic to finish dying everything to match. Tonight I will get the back of the cab pieces pulled.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-15-2016 at 11:04 AM. |
11-15-2016, 11:08 AM | #444 |
I've been wanting to do this with mine. If your using a spray can, how do you get the whole inside of the ashtray covered. It seems it would be hard to get it in there without the paint running.
And what paint did you use?
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
11-15-2016, 01:36 PM | #445 |
Happy to be here
My blasting cabinet is out of commission so I used Scoth-Brite and brake cleaner to get it cleaned up. I painted it with VHT cast stainless spray paint. I use several really light coats and fog it inside to get coverage.
11-15-2016, 03:18 PM | #446 |
I'm just glad to be here!
Ok, what is wrong with your blast cabinet? I got the same one now, and my biggest complaint is the lighting inside it. I am working on a fix for that...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
11-16-2016, 08:27 AM | #447 | |
Happy to be here
With all that combined, it's a shop ornament right now. I will get it back in operation soon. We have discovered it's such a valuable tool and saves tons of time in the clean and prep process that I can't get by without it.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-16-2016 at 08:35 AM. |
11-16-2016, 08:33 AM | #448 |
Happy to be here
I had a long work day yesterday, so my shop time was limited. I managed to get the last few pieces of the interior stripped that needs to be dyed. Fortunately these pieces have not been dyed, so they shouldn't take long to prepare.
11-16-2016, 09:52 AM | #449 |
Still Learning
Awesome work as always Ken!
11-16-2016, 02:12 PM | #450 |
Your cabinet is a harbor freight cabinet right? We are about to get one in our town next month so I was planning to make that my first purchase!
