Old 07-19-2021, 07:48 PM   #426
skymangs
skymangs's Avatar
Re: Orson the 49 GMC ~ Chris C.
We discovered a leak in your fuel tank, this needs to be addressed!
The wheel tubs are in paint and the bed subfloor is in for the last time! Tomorrow we put the bedwood in.
skymangs is offline   Reply With Quote
Old 07-20-2021, 09:25 PM   #427
skymangs
skymangs's Avatar
so Wyatt drilled a hole through the existing speedo glass for the button
We finished up your bedwood, I found bedstrips in KC... $20 a piece! That’s authentic 125 y/o barn wood!
Christian finished the sound/heat barrier
I think I found a solution for the crooked indicators, Wyatt is making an Aluminum bezel!
Old 07-21-2021, 08:37 PM   #428
skymangs
skymangs's Avatar
this is what we had to replace from the fire.
It’s all replaced now accept for the 5/16 quick connect (return line) which we had to ordern.
We also installed the wiper posts and Transmissions. The windshields are being installed on Monday by Mark's Moble Glass.
Old 07-21-2021, 08:40 PM   #429
skymangs
skymangs's Avatar
We also installed all the AC vents and controls.
And the grill went in for the last time!
Old 07-22-2021, 08:24 PM   #430
skymangs
skymangs's Avatar
Here we are chasing the courtesy light wire up the windshield pillar
Here’s a little issue we had. Wyatt dropped the spring for the gearshift in the column. In order to retrieve it the whole column had to come apart, but on these aftermarket columns, the turn signal switch is bigger than the hole in the end of the column! Made for an interesting couple of hours!
Then we put the lever on the bottom of the column
Old 07-22-2021, 08:26 PM   #431
skymangs
skymangs's Avatar
Here’s the column all back together with the steering wheel back on
The new gas tank being prepped for install
Finished up the shift linkage today!
Old 07-22-2021, 08:33 PM   #432
skymangs
skymangs's Avatar
Old 07-23-2021, 07:53 PM   #433
skymangs
skymangs's Avatar
Today we installed the new fuel tank and increased the capacity by 4 gallons
Old 07-23-2021, 07:54 PM   #434
skymangs
skymangs's Avatar
Then the task was moving that unsightly Brake Switch up out of the line of signt. Where we moved it you can’t see unless you get way down
we also decided the 10-24 shift rod was just to flimsy and not quality enough for my builds. We bought the heims and rod to build a 1/4” setups and will do so on Monday
Old 07-26-2021, 08:09 PM   #435
skymangs
skymangs's Avatar
Mark’s showed up today, but apparently Classic parts sold me the incorrect windshield seal. This one is for a locking strip, I need a solid rubber one!
We installed the defrost vents and hoses today
The new gas tank is finished and the bed went in for the last time!
Tomorrow it’s off to the city to exchange windshield gaskets and get door glass.
Old 07-27-2021, 08:04 PM   #436
skymangs
skymangs's Avatar
Driver side glass done! That was a ton of work! Tomorrow, the passenger side
Old 07-27-2021, 08:06 PM   #437
skymangs
skymangs's Avatar
We spent from 10-3:30 in the city buying parts
Christian put together the AC vents
The bed strips cost me $20 each! Tomorrow we bolt them down
We also prepped al the headliner trim for paint
Old 07-28-2021, 07:14 PM   #438
skymangs
skymangs's Avatar
Replaced the passenger door glass today
Here’s the new stronger shift rod
And here’s the marking for trimming the 1 piece ABS headliner
Old 07-29-2021, 08:38 PM   #439
skymangs
skymangs's Avatar
My son tilted the core support slightly, so we had to compensate. We cut and added metal to the Radiator cover
The headliner was a royal PITA, but we got it done
Here it is out in the sunlight!
Just FYI, we drove it a bit today and it made a loud clanking noise in the rear end, upon further inspection turning the driveshaft didn’t always result in the wheels turning. More diagnostics tomorrow, but I suspect That yahoo sold me a bad rear end! Not to worry, we have another!
Old 07-30-2021, 09:17 PM   #440
skymangs
skymangs's Avatar
not much of an Update tonight. We seem to have a MAF issue, no one’s working tomorrow so we will continue diagnostics on Monday.
We think we may have figured out the rear end issue. My newest mechanic installed the hanger bearing incorrectly. We’ve fixed that and hope to get it out for a test drive on Monday.
The passenger door is all back together
Wyatt forgot to take a picture of the bedstrips, but they are finished (what a horrible undertaking!)
Old 08-02-2021, 09:40 PM   #441
skymangs
skymangs's Avatar
Here’s the picture of the bedstrips
And we finished up painting around the tailgate
I think tomorrow we’ll tackle the tail lights and the seat
Old 08-03-2021, 08:08 AM   #442
6DoF
6DoF's Avatar
damn, smashing this thing out
6DoF is offline   Reply With Quote
Old 08-03-2021, 08:22 AM   #443
skymangs
skymangs's Avatar
Thank you
Old 08-03-2021, 10:18 PM   #444
skymangs
skymangs's Avatar
The tail lights are in! They were listed for a Ford (I couldn’t find any Chevy specific ones). But we made them work.
They’re LED, so they’re super bright
We also finished up the bedstrips and filled the rear end.
The gauge decals will be ready tomorrow, here’s the proof
Old 08-04-2021, 09:16 PM   #445
skymangs
skymangs's Avatar
so what day are we shipping? I’m glad it’s not tomorrow, I had an appointment at 2pm to put in the windshield, at 2:15 I called. I was informed that my installer was out with COVID. Well that’s just great, it’s supposed to ship tomorrow, what are you going to do about it? Long story short, they’re coming at 11AM tomorrow.
We ran into another issue as well. As of today it won’t start. No fuel pressure. Changed pump and filter, blew out lines. Both pump and filter are brand new. You can hear the pump, but no fuel comes out. We can’t even get it to run out of a gas can! More diagnostics tomorrow.
We wired the tail lights
And hung/adjusted the drivers door.
Sorry it’s not ready, the no start issue really consumed our time.
Old 08-05-2021, 08:36 PM   #446
skymangs
skymangs's Avatar
We finally figured out what was going on, it seems that one of my mechanics put the feed and return line on backwards at the tank!
https://www.facebook.com/sarge2017/v...59548065748751
Wyatt spent a little time customizing the glovebox liner.
Tomorrow the gauges and the seat!
Old 08-07-2021, 09:19 AM   #447
skymangs
skymangs's Avatar
We’ve started building the gauges, but we ran into a bit of a snag
While wiring the gauge cluster we realized that our junkyard cluster was missing the switched Ignition post
We’ll need a new fuel gauge, looks like I’m going to the city Tuesday!
Old 08-09-2021, 08:37 PM   #448
skymangs
skymangs's Avatar
we got the AC all wired up and functional today
Including Wiring the binary switch and Compressor
Old 08-10-2021, 08:37 PM   #449
skymangs
skymangs's Avatar
so my guy was supposed to show an hour early on Friday to meet the tech from Mark's Moble Glass, he missed the appointment. Now Mark's tells me that the soonest they can have someone out is next Monday. So I told Wyatt his pennance was to make this right. So we bought the glass this morning, and put it in this afternoon!
We also picked up the fuel gauge and will be doing that tomorrow (the fuel gauge had a broken post on the back)
Old 08-11-2021, 07:43 AM   #450
6DoF
6DoF's Avatar
haha, you run a tight ship!
lookin good
