10-14-2016, 09:29 PM | #4501 |
Re: What did you do to your truck today? Chapter II
10-14-2016, 09:46 PM | #4502 |
10-15-2016, 07:01 PM | #4503 |
Rattle canned some more fautina. Few more panels to complete bodywork. Sanded rust off the vent windows. Got all the bolts in my reclaimed wood bed.
10-15-2016, 09:00 PM | #4504 |
70+ ( Old Skool Club )
You did real good with your purchase, most of the time the wood floors are shot in these trucks.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-16-2016, 01:03 PM | #4505 |
I posted on page 178. Today I hugged my truck because it is officially mine! I also removed the box, let the work begin.
10-16-2016, 07:58 PM | #4506 |
Picked up the driver's side outer fender from the painter. The other fender still needs a bit of work though. Soon, she should be ready for reassembly!
10-16-2016, 09:13 PM | #4507 |
I switched to clear parking light lenses
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
10-16-2016, 10:24 PM | #4508 |
Yesterday I replaced my broken vent window. Today I refurbished my door panels. They will need replacing in the future but they look pretty ok for now. Also treated them both with rust inhibitor paint. I didn't get to the dash replacement this weekend, and I have to go out of town tomorrow, so that'll have to wait till next weekend.
10-17-2016, 09:35 AM | #4509 |
This has given me some inspiration, I have thought of using rustoleum brand rattle cans, about how many did it take for you to cover your truck?
10-17-2016, 10:06 AM | #4510 | |
10-17-2016, 10:19 AM | #4511 |
I was thinking about an orbital sander with a scotch brite pad on it first, then sanding as needed to remove runs. I don't have time to remove panels either, but, I'm going to try it anyway! I'm thinking of tackling the bed first - will have to order some hardware for replacing the ones I'm sure I'll have to grind away!
10-17-2016, 04:07 PM | #4512 |
Added some rally's and 35's
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
10-17-2016, 04:42 PM | #4513 |
I started my build I guess you could say. I got down under my truck and removed the driveshaft, hanger, the exhaust, radiator and supports and got it ready to remove the motor and transmission. I will be degreasing it all underneath and cleaning it up for the new motor which I will bolt onto the transmission after I clean it up and add new seals, filter, and gasket. I am also dropping off the radiator to be flushed and pressure tested. I was surprised to see it full and still bright green after all these years sitting. Since 96 or a few years before.
10-17-2016, 04:54 PM | #4514 | |
Just messing with you, technically these are "engines" as "motors" are electric, but most everyone wants to use the wrong term, even saying "crate motor" instead of "crate engine." All I did was inquire about a cluster, buy some cluster parts, and figure out a new use for my truck (when running). I just now bought a boat that I plan to haul in my truck. |
10-18-2016, 07:38 AM | #4515 |
10-18-2016, 11:21 AM | #4516 |
laying low
Whoa son. He's got the sun visor, wide whites, contintental kit, mag wheels, bikes, coke trailer. You won't find another one like it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-18-2016, 12:29 PM | #4517 |
one day his wife probably said get rid of all of that junk laying around the house"
he said "that's all good stuff, I'm not throwing it away, it's for my project" She said "it's junk, throw it away!" he just had to prove her wrong! |
10-18-2016, 12:30 PM | #4518 |
double post
10-18-2016, 11:28 PM | #4519 |
Snark alert !
This just goes to prove that in matters of taste, every one else is WRONG .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
10-19-2016, 05:28 PM | #4520 |
Got busy and welded up the old mirror holes today in prep for my new sport mirrors. It was a quicky job, weld, grind, spot prime, and rattle can some color and we're good to go.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
10-19-2016, 05:30 PM | #4521 |
Upper holes in the window frame.
10-19-2016, 06:49 PM | #4522 |
Finished up installing Jeep fan conversion.....test it in the morning.
1970 C10 Short Stepper with 71/72 front clip. |
10-19-2016, 08:50 PM | #4523 |
Tonight I worked on my DBW pedal and was able to mount the 71-72 pad on the 03 Silverado assembly. Still need to make a bracket for it in the cab.
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now..... Needed: paint and lots of it. and i'm sure lots more misc. parts. Project 67 short step Build Thread 01 Sierra Crew 6.0 2015 Ford F150 Work gave me truck i really wouldn't buy a ford. |
10-21-2016, 11:42 AM | #4524 |
Finished installing and setting lash (E-O,I-C) comp Cam Ultra Roller Rocker and New Magnum push rods...test drive later
10-21-2016, 12:18 PM | #4525 |
Well now you have to show us more pictures.
1972 Chevy C10 Custom Deluxe Highlander 1972 Chevy C10 Custom Deluxe Medium Green |
