#4551 |
C/10 junkie
Re: What did you do to your truck today!
I have an extra charcoal canister off my 72 if you are in need of one.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#4552 |
Well ;
It's part of the SMOG equipments so maybe ~ some states still want it there . If it's in good shape , and properly connected (takes at least three different hoses) it doesn't make the truck run badly atall . I found the full A.I.R. pump , branch manifold & gulp valve for my '69's L6 and have been seriously considering installing it just because ........... ![]() FWIW , A.I.R. pumps are bad for your exhaust valves but they're also dead simple to make look fine yet not harm anything .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#4553 |
Getting the 69 ready to do a intake and carb swap, also going to install a new MSD streetfire HEI unit.
Going to a dual plane Holley intake and a 670 holley , new MSD plug wires as well. Posted via Mobile Device |
#4554 |
Grand PooBaa Member
Took one side of the 327 heads off to see if I need to hot tank them or just rebuild the engine. Of course as I was using my breaker bar to loosen the head bolts, I turn to far and slammed my finger into the 50lb intake manifold I have sitting near the engine. Dang it smarts to heck!! LOL
#4555 |
![]() Join Date: Feb 2012
installed a pitman arm and done an alignment before I left work. I do need to buya new door any suggestions ?????
#4556 |
Finally put in rear shock relocators from ECE and all new KYB shocks. Will post pictures tomorrow. Got too late!
#4557 |
no. if you had it there will be a bracket on the core or you'll be able to see where it was(provided it hasn't been repainted)..i not sure what years it's on or if it was state to state. i normally only see them on the 72s only or truck that have had the tank moved out of the cab. i have seen a couple of 71s from cali, but it's either been removed on the years i've dealt with or wasn't there from factory.
is it done yet? |
#4558 |
Went and visited her in paint prison. They should be shooting some primer on her in the next week or so. Body panels and floor repairs look good. shop took her down to base metal to start from there. Only a few more months to go!
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#4559 |
#4560 |
I just washed mine and realize i have to repaint the bumper since the paints peeling off...
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
#4561 | |
Mostly interested in your wheels. In process of moving from 20inch flat black wheels to 15 inch classic rally's I plan to blast and paint. |
#4562 |
_____________________________________ Dennis 1969 C10 250 w/3 on the tree - project/weekend warrior ![]() 2010 Subaru Impreza - daily driver |
#4563 |
Stopped at MAR-K in Oklahoma City and bought all new mouldings for the 72. They are beautiful. I can't wait to get home and install them.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
#4564 |
Here some more pics, i used to have trim ring but someone stole them
![]() Been actually thinkin aboot painting my valve covers black and polishing the fins and doing the same to my air cleaner
#4565 |
If you notice my mirrors are now square when the used to be circles.
#4566 |
I filled my gas tank for the first time, by the time I got back in my truck gas was running out of my sending unit. I pulled it out today and silver soldered it to stop the leak. Now I just have to get the gas smell out of the cab.
#4567 |
Put some more go juice in and went to a local cruise inn.$48.00 to be exact.
#4568 |
![]() Join Date: May 2012
well today i got to do some sanding...and more sanding....etc. etc. etc.....but one of these days....i hope i get ole dollar completely sanded down...
#4569 |
I tightened the bolts that hold the steering rack to the frame.
A little bit every day, had the wheels off for over a month now. Maybe by September it will be rolling again. |
#4570 |
Grand PooBaa Member
Found more fun facts about the 327 after tear down. WHEEEEEEEE!!!!!!!
#4571 |
![]() Join Date: Oct 2011
Look on the bright side the anti-freez looks fresh.
#4572 |
Grand PooBaa Member
#4573 |
My 67 chevy c10 lwb has been a long 2 year project. So far we installed a 250/th350. 250 got new freeze plugs,intake&exaust gaskets,starter,flywheel,oilpan&valve cover gaskets,new oil line to Original gauges,Water temp to Origianl gauges, Th350 was rebuilt, 4 core radiator, 15x6 steelies, 69-70 automatic steering column/Cpp Linkage but kept my original 67 steering wheel on. We have the Original electrical but just patched up some wires. Next is hopefully a new Ignition coil and then I can move onto the brake work. Gonna keep that all drums for now. Someday disc brake up front.
Stovebolt-It is painted |
#4574 | |
![]() Quote:
Just to - day I went to Pick-A-Part on Blinn West of PCH in Long Beach and discovered SIX '67 ~ '72 C/10's & C/20's , several Customs , several rust free cabs , many dent & rust free fenders , inner fenders , core supports and so on..... all Long Bed Fleet Sides sadly . I considered the 1970 C/20 cab for my '69 as it's rust free and has A/C.... I got a nice set of original green factory seat belts , mine are badly frayed and sun bleached to the point of me worrying if they're safe , now I'll be golden once I wash these out , dry and install them . ALL these are V-8 rigs , PS , PB , AC etc. - it's all there . ![]()
#4575 |
![]() Join Date: Dec 2006
Installed my Billet Specialties Serpentine Conversion Kit and accessories
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
