#4626 |
Re: What did you do to your truck today!
Drove it..Needs its weekly bath
#4627 |
Grand PooBaa Member
#4628 |
Past two weeks, also went for a drive to go shoot my pistol.
#4629 |
RAT1968 '68 Cab/'71 Parts
Got the hood on (still have to move the lines around a little and trim out the sound deadener) ; slapped the trim on the lights in the rear, put the plate on the rear (waiting for the new tags), put on the wipers.
Earlier in the week, I put the wheels and tires on after she was up on blocks for a long time. When I stepped back to look at the hood all closed up, something seemed wrong. The drivers side was a tad higher..... Oh No! I thought I'd already lined everything up. I took a measure...It was about 1/2 inch plus off. So I did a visual....Huh? Seems somebody put both rears (275/20's) on the driver's side, and both fronts (245 x 20's) on the passenger side. I wonder who was stupid (and/or tired) enough to do *that*? Same guy will fix it on Monday.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#4630 | |
#4631 |
Have had new carpet, seat cover and seat belts sitting in the garage waiting for the weather to cool down a little bit. Got the carpet down, then the wife announced she wanted to go shopping. So in the best interest of my bank account, I stopped and went with her. Hopefully, I can get it finished up tommorrow.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#4632 | |
I had already ground down the rotor "nose". So the back wheel fit on the front really, really well! ![]()
#4633 |
Well I decided to go to the Woodward Dream Cruise , since it is only 10 minutes from home .. I normally take Ol'blue and drive up it once , then park at my buddys place and hang out on the side of the road and watch cars.. Well this time we had a few problems .. It quit in the middle of traffic , you know the kind that uis travelling at 2mph .. Luck we were on the inside lane so we pushed it onto the median .. found a wire had shorted out and caused a splice in the wiring to let go .. lucky I had a length of wire in the back of the truck and and a screw driver on my key ring .. so my son and I got that fixed and started crusing again and I noticed I didnt hear the fan for the radiator running .. turns out it fried .. so we decided to head home .. at 30mph it cools just fine with out the fan ... so at all the lights before the highway we just shut it off and fired it up when it turned green... made it home and now I have to decide what wiring system to buy ,and what BRAND name fan to install..... other than that it waS A GREAT TIME WITH MY SON..........
#4634 |
Drove it to work to - day (junkyard hopping for parts) then drove it home in the afternoon and tinkered a few things to be ready for to - morrow's So. Cal. Meet & Greet .
I may wash it in the AM but it's too dang hot here .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#4635 |
Fabbed a nifty little bracket to use a '64 horn button instead of the ugly Grant one. Also got started on the rear section.
#4636 |
laying low
![]() Join Date: Mar 2001
That cylinder rust isnt too bad. I once bought a 69 Impala for the 327 and T400 in it for one of my trucks. Flood water had gotten into 2 cylinders. One was substantial. I broke a piston getting it out. Rust was too deep to save it. It was a low mile engine so little wear. I had the one cylinder sleeved to put it all back to stock size. It was a great little motor that I ran for 8 yrs or so then sold the truck. New owner was tickled pink with it.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#4637 |
picked up a posi 3:37 rearend for $130 today, time to clean it up!
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#4638 |
There's two of these threads. Oh well, might as well post in both.
Out with the old, in with the new: |
#4639 |
nec absolutum
Got my '69 fired up, and got my '97 3/4 ton to move under her own power...
For the first time in almost a year, I got to hear 3 out of 4 of my trucks run. If I hadn't run out of daylight, I would have made it 4 out of 4. ![]()
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants."~ Thomas Jefferson 1967 GMC C1500 LWB 250/3 on the tree- 1969 Chevy C/10 SWB 350/TH350 1996 Chevy Silverado LWB 350/4L60E 1997 Chevy K2500 350/4L80E ![]() ![]() |
#4640 | |
Fun Stuff
![]() Join Date: Jan 2010
Good looking interior! I like the gauge cluster.
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
#4641 |
#4642 |
Fun Stuff
#4643 |
10/30/19
The wife and I went for a cruise in the 68. Got the title and vin plate worked out friday. Finally legal.
Posted via Mobile Device |
#4644 |
Took her out to Low Rollers!
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
#4645 |
![]() Join Date: Dec 2006
Congrats Billet, I miss going to Lowrollers End of Summer, hopefully mine will be done for next years show.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#4646 |
Just got around to working on the carb yesterday. After changing the oil / filter and also draining enough water to get my anti freeze in, re installed thermostat, made sure block was full as well as the radiator. Started right up after about 1/4 throttle. It seemed sluggish so I advanced the timing a little (started at 12 btdc) and switched my vacuum advance line to the full time vacuum port. Still seemed to want a lot of throttle to start and spit a little till it cleared out. Neighbor stopped by (manages a local garage, good gear head) and said to take a bigger swing at it with a lot more advance. We cranked that sucker around A LOT and wow it sprang to life. Started with just a tap of the throttle, idled great and great throttle response. It seems to want around 18 degrees advance. I need to get a dial back timing light on it. I need to see what my total is. Neighbor said he thinks it is a tooth off. Moved the distributor one tooth clockwise. Tried to start it and noticed the fuel pressure was low...checked the gauge and was out of gas
#4647 |
Painted the cab!
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
#4648 |
Well we got the timing and carb adjusted. Still a little too much advance but I still have a few things to do. I was able to take it out around the neighborhood tonight. The first time to drive it in 12 years. It felt really good. Everything worked well. Transmission is crisp, brakes are firm, runs on the cool side (even though it is new and tight) and sounds great. I have a couple of rattles to work on, fix a small exhaust leak, check the adjustment on the valves but mechanically I've pretty much got it done. I am just going to fill and seal the seams in the bed sides for now. Lots of work to do on the interior. Should have sound deadener, carpet, stainless sill plates and sound system in this weekend. For those who have access to facebook here is a link to a video
www.facebook.com/groups/Norhtwestc10s/ |
#4649 |
Took off my grill finally. I am getting new inner and out grills tomorrow from LMC
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350 1966 Caprice 1968 Impala (Frame Off LSX Project) 2001 Tahoe LT 2013 Hyundai Elantra 2010 Kawasaki Z1000 |
#4650 |
Painted the hood latch and all sorts of miscellaneous things.
71 K20 64 GMC mud truck |
