Old 07-23-2013, 01:35 PM   #451
vegadesign
vegadesign's Avatar
Re: Tricked-out Chevy six cylinder engines
Originally Posted by T.J. MCCAULEY View Post
The one they sell is probably the offenhouser.
yea it is, it runs for about $300
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline   Reply With Quote
Old 07-23-2013, 04:45 PM   #452
Twisted6
Twisted6's Avatar
Originally Posted by Vernski View Post
But that's why they make re-jet kits so you can lean em' out to the sweet spot
for air & fuel not just slap em' on there and sink & swim that is if you think outside the box. You just want to start a pissing match, just try to be happy with yourself now..Vernski
I used to run a 600 holley stock out of the box and a BONE stock 250 with a offey intake. Another thing to think about. If you unhook the secondarys on any 4b carb You'll only use half of what it is. 600 cfm / 300cfm, 450 /225cfm.
Larry /aka Twisted6
Twisted6 is offline   Reply With Quote
Old 07-23-2013, 06:36 PM   #453
Vernski
I don't really see why you can't use the smaller weber 32-36 DGEV in a multi carb application just one of them is designed for 1.9-2.0 liter motor and they are in use on motorcycles also re-jeted down or up depending what size Hog it is. All I said in my earlier post was I liked the looks of multi carbs, but it morphed into hear-say info after that cause someone had there own agenda.,Vernski
http://www.webercarbsdirect.com/category_s/690.htm
Vernski is offline   Reply With Quote
Old 07-23-2013, 09:44 PM   #454
inthearmynow
WOW you guys have some crazy setups
inthearmynow is offline   Reply With Quote
Old 07-23-2013, 11:14 PM   #455
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Does anybody know the cfm of a weber 32/36 or the 38? I thought that the 32/36 was around 270 cfm....I could be wrong. It seems like dual weber 38's are just over 600 cfm.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 07-23-2013, 11:28 PM   #456
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
That webercarbdirect sight that vernski put on makes sence. The 32/36 is made for a 2.0 liter so the dual system would be just fine on a four liter or just a tad lean on a 4.8(292). The 38 is made for a 2.8 so the dual would be four a 5.6(327) a little rich for the 250. Know what really cool is on page 153 on the power manual you can see dual 1150 holley dominator carbs on a chevy 292(I think). Love the looks of that!
Old 07-25-2013, 09:56 AM   #457
JR25
JR25's Avatar
I posted this on my build thread, instead of rehashing it out, I will just copy paste! Anyway, i have been watching this thread for a long time now since my first build will be powered by an inline 6!
Originally Posted by JR25 View Post
Any of y'all ever built one of these stove bolt 6s? Turns out there is a collar that holds the oil pump in the bottom of the block. This collar is attached by two bolts from the outside of the block, which I now know was not supposed to be removed...... Yep, got mine out! The block was casted so that after what must have been a double shoulder bolt was installed, they were cut off flush, which makes them appear to be round head bolts! It looked to me like a rounded off standard bolt with all the years of grime in the hole, so I drilled into the heads and used an easy out! Now I have been told that the block is a paper weight! I think that is the "answer" that everyone will give you, along with several opinions why, but I don't give up that easy! I have had EVERYTHING machined for this block and crank, and would just have a box of parts if I abandoned it now, unless I wanted to buy another block of the same year (or as much as a couple of years newer) and have it ored 80 over.
It seems that the biggest problem with removing the bolts is that there is now way to get them back in, at least not to someone less determined and less creative than me! I plan to clean up the holes that I drilled in the bolts for the easy out, tap those holes, and use a bolt to turn the original bolts back into their old holes. Then I could either cut of the slave bolts, or just remove them! The holes don't even go in as deep as the original threads, so I really don't think strength would be an issue.
ANYONE have any input on this? Am I really screwed?
Inline 6s aren't too popular on here it seems, and yes I know about all the forums dedicated to them......but quite frankly, no one on the other sites are nearly as helpful as you guys! The first reply would most likely be "use the search function!" really? Don't you think that a guy who might have just made a thousand dollar rookie mistake hasn't panicked and searched EVERY thread on the net that he can find?
Anyway, if it don't work, I guess I ruin my cam and dizzy gear, and have to back up and punt, but for now it's "third down and long!"
Anyway, I have reinstalled it like planned, and will post pics when I get them uploaded. Just curious if anyone else has "ruined" then saved a block by removing those stupid bolts that shoild have been WELDED in place if they are that sacred...... I know I know......if I would have read all the books that I spent good money on, it wouldn't have happened!
John
1955 Chevy 3200
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=582898
JR25 is offline   Reply With Quote
Old 07-25-2013, 10:47 AM   #458
chevy_mike
Never Ending Projects
chevy_mike's Avatar
John
Actually, that quoted text is referring to the Stovebolt Inline 6 engine series which is not the same series that was introduced in '62 and ran into the late 80's. The 194/230/250/292 series engines share nothing in common outside of having 6 pistons inline, with the older series. Based on what I had read, I don't even think I want to mess with the earlier series as they don't have a lot of the modern "tech" built into them. Stovebolts are the old school engine.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-25-2013, 11:10 AM   #459
JR25
JR25's Avatar
Yep, mine is a 235....... Old school! That was my quoted text, I just posted it here as well hoping someone on this thread had dealt with it before.
I hope to be able to post pics of my engine on here when it is done..... If yall dont mind seeing "old school" 6's!
1955 Chevy 3200
my build thread:
Old 07-25-2013, 11:56 AM   #460
Vernski
I think some pic's of the area in question would help, I would think you could JB-weld the holes that were drilled after you re-installed the bolts. Just make sure it's free of oil so it will stick good. I've had a few 235's overhauled but sent the block out to have them checked out and then re-installed the rotating assembly, just never had encountered your specific problem..Vernski
Old 07-25-2013, 01:53 PM   #461
JR25
JR25's Avatar
Im working a little faster than Im posting, great minds think alike!
I used the steel reinforced JB Weld on them yesterday!
Give me a bit and I will upload the pics of what I did!
1955 Chevy 3200
my build thread:
Old 07-25-2013, 02:16 PM   #462
JR25
JR25's Avatar
As requested:
Should be obvious that they are supposed to stay in now!
1955 Chevy 3200
my build thread:
Old 07-25-2013, 03:09 PM   #463
chevy_mike
chevy_mike's Avatar
Wow, that's just a crazy design. LOL Sounds like you have it handeled
Old 07-25-2013, 05:08 PM   #464
Vernski
X2 what mike said, I think as long as the collar& bolts hold the oil pump firmly and the cam turns I think it will be ok, that's not an implied warrenty you understand, but I think you saved it from being a boat anchor good luck..Vernski
Old 07-26-2013, 02:25 AM   #465
JR25
JR25's Avatar
Thanks guys, I will keep yall posted!!
1955 Chevy 3200
my build thread:
Old 07-26-2013, 08:31 AM   #466
K98AL
K98AL's Avatar
I put a Weber 32/36 on my 235 - I'm running Fenton headers, HEI ignition, everything else is pretty stock. Had engine rebuilt 15,000 miles ago.
The standard 140/140 jets left me way too rich, I swapped for 135/155. (thanks Rich!!!)
Still too rich, I put a 130 in primary side. Not much difference. With idle screw not touching the linkage, and idle mix screw adjusted for good running, (around 1 turn out) - I'm still running more RPMs than I should....
Does a 120 or 125 primary jet sound right to you with Weber experience?
K98AL is offline   Reply With Quote
Old 07-27-2013, 08:03 PM   #467
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I think your best bet if your going to stay mostly stock would be two stock 1 barrels. I don't think it would run to rich with those. Do you know if the 235 is larger or smaller than a 2 liter? The 32/36 is made for that size. But most of the webers I have seen were on 4 cylinders... What type of hei are you running? You could go with a hotter hei and spark plugs and that would help.
I am running a 40,000 volt pertronix ignitor with ngk 4es spark plugs and its actually running to hot! Not even close to rich. Going to swap the pertronix for a DUI and go back to a cooler spark( ngk 6es). My buck and a half.
Old 07-28-2013, 11:43 PM   #468
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Got the engine in my sons truck!
Still some stuff to get done, but here is the basics!
Yes, I know the motor mount is missing... The one from the 230 does not fit on that side. Looking for a new one! Bell housing and passenger side in and bolted though!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 07-29-2013, 10:12 AM   #469
JR25
JR25's Avatar
Nice and clean Jason..... I like it!
1955 Chevy 3200
my build thread:
Old 07-29-2013, 10:17 AM   #470
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Thanks JR25!!
Jason
Old 07-29-2013, 04:54 PM   #471
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Originally Posted by chevy_man5 View Post
Thanks JR25!!
Great job! Love the paint job!
Old 07-29-2013, 05:58 PM   #472
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Thanks T.J.!
Jason
Old 07-30-2013, 05:19 AM   #473
Vernski
Here is a cool link this would be quite a motor it' a Chevy vortec 4200 I6 24 valve dual overhead cam all aluminum block and it produces 270 hp from 256 cu. 90% of the torque from 1600-5600 rpm. "Holy crap Batman"..Vernski
http://www.chevyhiperformance.com/te...ne_six_engine/
Old 07-31-2013, 11:06 AM   #474
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I'll bet that thing gets great milage to! Cool motor! Never even knew they were made.
Old 08-04-2013, 08:22 AM   #475
JR25
JR25's Avatar
Ok......... I think I finally finished the engine build, not in the truck and running, but here is as close as I could get to "tricked out" for an old timed 235!
1955 Chevy 3200
my build thread:
