#451 |
6.0 powered square
Re: my 80 build
well got a frame today
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#452 |
Re: my 80 build
I am doing the same thing you are right now, swapping frames. It doesn't seem too bad so far. I know this is snowball stuff but do yourself a favor and go ahead and put new bushings, ball joints, ect in it while you are this far down. No since in doing it again later. Of course if this is your DD you may not be able to have it down that long. Looks good man. Have fun with it.
#453 |
6.0 powered square
Re: my 80 build
Four years ago when I started working on my truck I replaced all the bushing and steering components, so I will be using them on the new frame, and yes this is my daily I will be able to borrow my grand pa's jeep wile its down
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 09-05-2010 at 11:30 AM. |
#454 |
6.0 powered square
Re: my 80 build
Cleaned up the frame today
#455 |
Re: my 80 build
LOoking good man.
#456 |
Re: my 80 build
oh yea!! going to do her up right!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#457 |
6.0 powered square
Re: my 80 build
yep I have a different perspective on quality of work now since I work at a top notch auto repair shop, if it wasn't done right the first or dressed up it will be this time.
I did get a little work done today a was able to cut the rivets off for the factory tail pipe hanger, but I still have the rear bump stop brackets to cut off, the cross member that holds the disc brake valve has a loose rivet so I may cut all the rivets out and replace with bolts
#458 |
6.0 powered square
Re: my 80 build
#459 |
6.0 powered square
Re: my 80 build
I got the rear end unbolted so tomorrow I'll move the frame to the back yard and start stripping the paint I plan on have frame sanded and painted by the end of the month
#460 |
Re: my 80 build
I think I noticed that frame on C-list. Smart way to get the swb rails & get it all slicked/painted w/o down time on the truck.
#462 |
Re: my 80 build
Nice score on the frame man. Like Scoti mentioned that's a good way to go about it. Keep us updated.
#463 |
6.0 powered square
Re: my 80 build
It was on Craigslist for a couple of months
#464 |
6.0 powered square
Re: my 80 build
its mostly my parents stuff
#465 |
6.0 powered square
Re: my 80 build
#466 |
6.0 powered square
Re: my 80 build
moved the frame to back yard and started on removing the rear bump stop brackets, then I still need to weld on washer to the front left shock mount since its wallered out
#467 |
Re: my 80 build
Just my opinion, but I don't think those wheels will look good on your truck.
![]() Looking good man, keep it up! |
#468 |
6.0 powered square
Re: my 80 build
there chrome plated though
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 09-13-2010 at 06:52 PM. |
#469 |
Re: my 80 build
I have a question for you my shortbed sits kind of high i have 8 leafs on my leaf springs my sons longbed only has 4 leafs should i take out some leafs
or just replace them |
#470 |
Re: my 80 build
At your current drop, I would just swap on some shock relocators up front vs. the washer idea. Measure your shocks & see if it's a good idea.
#471 |
6.0 powered square
Re: my 80 build
if you still want your towing capacity go with some drop shackles
#472 |
6.0 powered square
Re: my 80 build
I look in to it
#473 |
6.0 powered square
Re: my 80 build
#474 |
Re: my 80 build
man you are making some good progress!
#475 |
6.0 powered square
Re: my 80 build
thanks
